My washer seems to just agitate forever. The knob is not wanting to advance. That's the main problem.
  • Washing Mach... Master
  • 473 Answers
The knob not advancing I assume is the timer where you pick the cycle you want. This would be called a mechanical type timer which is turned by a small clock type motor inside. It looks like that drive motor is defective and is usually part of the complete timer assembly You need to replace the timer assembly.
Posted on Apr 05, 2015
Washer will not cycle
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Oct 24, 2008 | Kenmore 15864/15862 Top Load Washer
I have a Whirlpool washing machine LA8800XT. It seems the timer knob can no longer engage the timer shaft. Part number of the timer is 3352091. I am positive the machine and the timer are fine. I tried...
I have a Whirlpool washer #LA8800XT and want to remove the Fabric Softener dispenser so I can remove the agitator. Does it just screw off? It seems to be stuck and I didn't want to break it if it didn't screw off.
Oct 09, 2010 | Whirlpool 3362624 Washer Control Timer...
Kenmore 70 Series Washer Won't advance in the
Bad timer. Try to find a used one if possible, this item is a little expensive.
Aug 23, 2010 | Kenmore Washing Machines
Agitation, agitation, agitation
HI. This problem concerns the integrity of the actual timer mechanism. The dial cogs seems to be worn, and the timer motor may be failing to advance in that particular section of the dial plate. This type of malfunction will require you to replace the timer control mechanism, asap.
Feb 15, 2010 | Whirlpool LSR5132PQ Top Load Washer
Frigidaire washing machine gets stuck on cycles
Apr 01, 2009 | Frigidaire Washing Machines
Washer only works by manually advancing the dial.
yes this sounds like a timer it sounds like it is getting stuck in the cycle. replace the timer and this will clear up the problem
Dec 29, 2008 | Maytag SAV3710AWW Washer
GE washer does not agitate. Water does not stop filling.
If it does not agitate at all, then it is either the motor, the clutch/motor control or the agitator.
If the machine start agitating only when you advance manually the control knob, and at the same time is overfilling, that is probably because of the problem with the water inlet valve, or the water level switch, and that is also cusing the cycle to stop.
See:It's overfilling
Nov 20, 2008 | Washing Machines
Washing Machines Logo
47 people viewed this question
Top Washing Machines Experts
