Question about Kenmore Kitchen Ranges
Melted aluminum foil on inside of stove bottom how do we get it off?
    Champion:
  • 208 Answers
Oven cleaner.
Posted on Apr 05, 2015
  • Kenmore Master
  • 932 Answers
Cynthia,
I would suggest using something wooden so that you do not damage the surface of the oven. You could try a wooden dowel that you cut at an angle so that you have a point. Also, most manufacturers do not recommend putting aluminum foil under the elements or on any of the racks. One of the things that can happen is what has happened to you and it also can cause premature failure of the heating element if you put it under the heating element. The same goes with putting foil in the drip pans, not a good idea. Hope this helps!
Single element stove oven, doesn't get hot enough
Your oven probably has a feature called a hidden bake element. The element is located beneath the floor of the oven. (Because of this, NEVER put aluminum foil on the bottom of the oven because it will get hot enough to melt the aluminum foil and make it bond to the bottom of your oven.) You can adjust the temperature of your oven through the electronic oven controls. Check your owner's manual for how to do this.
Oct 08, 2014 | Kenmore Kitchen Ranges
MELTED ALUMINUM FOIL ON BOTTOM OF OVEN FLOOR: Have a Kenmore ceramic smooth top range. We placed a piece of aluminum foil on the very bottom of the oven as we like to bake our pizza on the rack but...
I would try a copper scouring pad.
Aluminium is very soft - Mohs hardness of 2.75
Copper has a Mohs hardness of 3, just slightly harder.
https://en.wikipedia.org/wiki/Hardnesses_of_the_elements_(data_page)
Ceramic tile has a hardness of 7
Mohs Hardness Scale
This means the copper scouring pad should be able to remove the melted foil without scratching the ceramic - but test first to be sure.
Mar 10, 2017 | Ovens
My new oven has melted the tin foil onto the bottom of the oven that I put to catch cake drips. I don't know how to get it off as it has adhered. The smell right from the start of the oven and during my...
With the older models of self-cleaning ovens one could put aluminum foil on the bottom tray of the oven, but with the newer models there is a warning (hidden in the last line) of your booklet for models of stoves where aluminum foil should 'not' be used! Even though print in small and many consumers are complaining regarding their stoves and melted aluminum stuck to the bottom tray of their oven (nothing will get it off) all manufacturer do 'not' cover this problem under warranty and thus, it will cost you $44 to buy a new tray. You unscrew the two screws to the bottom of the damaged tray of your oven and then install the new one and put back the screws. Letters of complaint should be written to the manufacturers to have them put this warning in clear bold print right on the front cover of the instruction brochure.
Jan 20, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
I had some aluminum foil to melt onto the stovetop and can't seem to get it off
go to ehow.com and just type in how to remove aluminum foil from your stove top. the solution is there . good luck!
Jan 04, 2011 | GE Spectra JBP78 Electric Kitchen Range
I don't have a Kenmore I have a Fridgidare and I have burned on foil on the bottom and cannot remove it. It is a self cleaning overn and I am afraid to turn it on??? I have tried scrapping, soaking, but...
With the older models of self-cleaning ovens one could put aluminum foil on the bottom tray of the oven, but with the newer models there is a warning (hidden in the last line) of your booklet for models of stoves where aluminum foil should 'not' be used! Even though print in small and many consumers are complaining regarding their stoves and melted aluminum stuck to the bottom tray of their oven (nothing will get it off) all manufacturer do 'not' cover this problem under warranty and thus, it will cost you money to buy a new tray. You unscrew the two screws to the bottom of the damaged tray of your oven and then install the new one and put back the screws. Letters of complaint should be written to the manufacturers to have them put this warning in clear bold print right on the front cover of the instruction brochure.
Apr 26, 2010 | Kenmore 33169 Gas Single Oven
Aluminum foil melted to bottom of oven. how can I
If the foil is melted to the bottom, most oven liners are porcelain, so it will probably scrape off fairly easy. You want to try something non-metallic first. If you need to use something metallic to scrape it off be very careful not to scrape or chip the porcelain, you might try a scraper used to clean glass top cooktops. Remember porcelain is glass, so make sure you wear eye protection.
Dec 16, 2009 | Kitchen Ranges
Laid sheet of AL foil on bottom of oven to collect spills and ran over at 400 and foil melted and adhered to bottom of oven. How do I clean or replace bottom metal surface of oven?
This is not proven but worth trying. Get a can of "canned air" for removing dust from computers, etc at wallmart/staples whereever. Be careful because this following will get very cold and could give you frost bite. Place the straw in the spray head and turn it upside down then spray the melted aluminum foil, in 1 to 2 second bursts. Frost will appear on the melted aluminum. Keep spraying 3 to 5 times to make sure it is very cold. Then use a wooden spoon to scrape it off (you can press pretty hard without damaging the oven). The cold from the liquid air will cause one of the aluminum to contract faster than the steel and you may get it to pop apart and scrape the aluminum off. If it works a little, repeat as needed.
Good luck and please rate me.
Nov 20, 2009 | Cars & Trucks
Aluminum foil stuck to new oven bottom - how to remove
(Wear a professional n95 mask and rubber gloves). Use a straight razor and scrape off as much foil as possible. Get a hold of Mercuric or sulfuric acid. BE CAREFUL not to spill anywhere, work close to a stainless steal sink. Poor a little in a small glass container and bring over stove porcelain surface. Pour the acid onto the foil and wait 3-4 minutes, use paper towel to wipe off the acid, and then a soapy wet rag. Repeat process until all foil is dissolved. Then wash surface thoroughly and repeatedly with a soapy dish towel. Once complete run water in the sink for 5 minutes till any possible remaining accid is flushed from the sink. The foil is gone and the porcelain is preserved. Works great! (Don't breathe the fumes and ventelate the area or move the stove outside)
Jan 20, 2009 | Kenmore 47783 Electric Single Oven
Foil stuck to bottom of oven
A bit of chemistry first. Aluminum foil reacts to acid. A black substance referred to as aluminum salts is formed. This is simply wiped away. How quickly the foil is converted depends on the strength of the acid. Vinegar has a safe level of acid content. Within two hours, some aluminum salt should have formed. Wipe it away. Repeat. And keep repeating until all gone. Yes, the process takes time but you can be doing something else. And the salts are black, so you don't want your clothes or hands covered by the black. Expect this to take a long time. And you may get frustrated and decide to buy a new liner! But if you work at it long enough, it will remove the foil. You may be pickled by the end of the process but repetitions of this will remove the foil ... in good time ...with enough applications and wipings. And you haven't been exposed to fumes or effects of sodium hydroxide.
Jan 10, 2018 | LG LRE30757ST (Electric) Stainless Steel...
Kitchen Ranges Logo
124 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
