Question about Water Filters & Coolers
I broke the plug off in back of cooler. Can I get replacement?
Can i plug the hoses that come off the oil cooler the male piece that connects to the hoses broke off into the hoses. It would be a temporary fix till I can take it apart
Sure you can do that for a short drives but don't for get that the coolers are in place for a reason to cool the fluids and if you drive for long time then the fluids start to burn and everopate and that could spell trouble.
Jan 22, 2017 | Cars & Trucks
Can I get a replacement filter for my cp35 I dropped mine and broke it
http://www.appliancefactoryparts.com/evaporativecoolers/ultracool/cp35.html#Other-Parts
Jun 07, 2011 | Champion International Champion Cooler...
Cold water spiget handle broke off . can i get a replacment ?
Yes. Call Sears parts direct at 1-800-252-1698 or go to repairclinic.com
Dec 19, 2010 | Avanti Hot and Cold Water Cooler
Broke the 12v DC plug on our Rubbermaid/Vector Thermoelectric cooler. Can't find a specific replacement plug. Any specific specs I need to look for in a replacement?
A generic plug should work...just be sure to size the fuse correctly to protect the unit. Most thermoelectric units draw about 4 to 5 amps...so a 10 amp fuse usually works.
Dec 09, 2009 | Refrigerators
Shifting in high gears after transmission serviced my dealer
it is supposed to downshift depending on how much/hard you are accelerating.
Jul 30, 2009 | 2005 Nissan Pathfinder
Need a drian plug for 32 qt coleman cooler where or web site to order part
You're probably out of luck. Coolers are relatively inexpensive, so they don't usually make drain plugs. I broke mine off and the best solution was a shaved down wine cork. I put it on the inside and it worked great. Use the newer plastic style and it will hold up forever. Good luck Alley
Jul 07, 2009 | Coleman 36qt Xtreme Cooler
Water Filters & Coolers Logo
430 people viewed this question
Top Water Filters & Coolers Experts
Tom Chichester
Are you a Water Filter and Cooler Expert? Answer questions, earn points and help others
