Question about KitchenAid KSM150PS Artisan Series Stand Mixer
Kitchenaid mixer shot sparks when turned to high
I was whipping cream and when I turned the speed to 10 there was a loud pop and sparks flew out the back of my mixer (it popped the GFCI). Tried to turn it back on and same thing happened. When I opened the back there is a charred spot and a wire (not electrical) is burned off and left a welded spot on the body. Brushes appear to be in good condition.
    Novelist:
    Scholar:
  • KitchenAid Expert
  • 134 Answers
Tanya, it sounds like there might have been a short to ground, that is when a wire comes loose and touches the housing. So you will definitely have to rewire/fix the wiring in the mixer, there is a wiring diagram in the KitchenAid service manual (http://ep.yimg.com/ty/cdn/mendingshed/kitchenaidservicemanual.pdf)
There may have also been damage to the speed control plate or phase board, either part would have burn marks on it in most cases.
Kitchenaid mixer shot sparks when turned to high - kitchenaid-mixer-shot-sparks-when-turned-mz0mnwb1nd52ertzwibinpxu-3-0.jpg
You can find replacement parts here: http://www.mendingshed.com/regmixerparts.html
And as always if you have any questions give us a call, we have technicians that work on these every day at our repair shop that can help guide you in the repair.
-Colleen @Mending Shed
Posted on Apr 23, 2015
    Novelist:
  • KitchenAid Expert
  • 185 Answers
This is a simple fix, the speed control switch needs to be replaced and you are probably going to have to do a rewire job on the wires that got welded to the frame, this really requires a trained tech to repair. If you do it wrong you will burn up the motor.
Posted on Apr 05, 2015
How do you fix a KitchenAid stand mixer speed ? Speed is only on high.
The speed selector may be defective and will have to be replaced.
Feb 10, 2018 | KitchenAid Food Mixers
Kitchenaid Hobart K45SS when set at 1-2 accelerates to high speed when making dough. How can I fix this?
Usually when the mixer runs only on high speed it is caused by the control plate adjusted incorrectly or the control plate spring unhooked. Remove the trim & end cover on the mixer and check the control plate spring, if unhooked, attach to bottom of the control plate and squeeze the spring end, also check the speed control plate screws,there are 3 screws on this plate, one at the bottom two at the top, see if adjusting the top screws slows your mixer down.
Next check the wiring of the mixer, Insure everything is wired correctly, to get wiring diagram go to the last page of the service manual. Here is a link to the service manual: http://lib.store.yahoo.net/lib/mendingshed/kitchenaidservicemanual.pdf
If neither of those fixes the problem it is probably a bad phase control board, or a shorted phase control board. With the line cord disconnected, pull the t-bar contacts to open and insert a piece of paper between them so they cannot close. Reapply power-the mixer should just run or buzz trying to run, if it operates at full speed the phase control is defective and needs to be replaced.
Use the service manual to aid you in taking apart the mixer, trouble shooting the problem and putting the mixer back together, based on the mixer only running at high speed some of the time I would assume it is the speed control phase board.
If you have any questions let me know.
Thank you,
Colleen
Customer Service
MendingShed.com
Apr 24, 2013 | KitchenAid Food Mixers
KitchenAid mixer speed surges high and low uncontrolably
You can get the high speed back if you want to play with those three screws. there is a timing scheme for your mixer and it is set and adjusted by manipulating those 3 screws. The bottom center screw is for speeds 6 8 and 10. The best choice is to replace this switch, about $10 bucks on ebay.
Nov 13, 2012 | KitchenAid K45SS Classic Stand Mixer
The top part of my mixer is sitting about 1/4 inch lower than it should. It's placing the beater too low in the bowl and therefore won't mix. (I tried to whip up some whipping cream but it pushes...
Get a copy of the Repair Part List for your model at Kitchenaid.com
Download the following Kitchenaid Service Manual:
http://www.kitchenaidparts.be/centers/servicemanual/mixer.pdf
It covers several models including yours.
1. Check/Adjust the Flat Beater to Bowl Clearance:
Turn screw (A) SLIGHTLY counter clockwise (left) to raise the flat
beater or clockwise (right) to lower the flat beater
2. Check the Beater Shaft (Agitator Shaft) making sure the Retaining ring
is flushed with the surface of the Planetary Assembly
Constant Pulling and Removal of the beaters can cause the Agitator shaft to move
3. If the above two still don't solve your problem, follow the service manual
directions to disassemble the Planetary Assembly and check for loose screws
Jul 04, 2011 | KitchenAid KSM150PS Artisan Series Stand...
I was making a standard cake with my kitchenaid and in the middle of creaming butter and sugar together, it stopped working. Turned it off, switched plugs, let it cool down, etc - it won't turn on now and...
either the electrical motor brushes are worn down on the motors commutator and can no longer contact the motors commutator bands,or if its a newer style mixer the triac that controls the speeds on the unit could have opened up and can no longer supply variable or even high speeds
Aug 01, 2010 | KitchenAid Food Mixers
Will not spin fast enough to whip cream
Do you have more than one size beaters, if you do use the smalest ones that will rase the rpm DFD
Apr 12, 2009 | Sunbeam 2350 Stand Mixer
Clicking
I have the same mixer. Make sure the bowl is firmly latched into the base. also, make sure the bowl didn't get bent in shipping. If the paddle hits at a regular timed interval, it's must likely a problem with the way the bowl seats. As long as you don't hear a loud hit verses just a click, it shouldn't be a problem, just an annoyance. In time, you will probably heat tapping when you use the wire wisk. I am glad I bought mine. I hope you enjoy the difference a good mixer makes.
Jan 03, 2009 | KitchenAid K5SS Heavy Duty Commercial...
Mixer motor shut down
Mine did almost the exact same thing one day. I have the Artisian Model, It would do it on any of the lowest speeds. Dont know if this will help you or not but I just ran mine the next day on all the way high with the spash guard on for making whipped cream for about 6 minutes full throttle and for some reason it hasnt went slow and shut itself off since then. Mine is about 7 months old. I called Kitchen Aid but their customer service all of a sudden seems to not know english worth a poo...
Try running yours on full blast for 5 minutes with something simple in the bowl. If its a 250 watt or higher make whipped water out of 2 cups of water and a tablespoon of cornstarch. Run it till you get what looks like whipped cream. Oh yea. Use the Balloon whip. The lubrication in the motor is supposed to last for at least 5 years but I have seen on numerous post's that if you run them on all the way for at least 5 minutes the oil will even out in the motor. Running the mixers at low speed alot will cause the oil inside not to move as freely since the motor doesnt heat up the oil in the gears.
Good luck.
Nov 15, 2007 | KitchenAid KITCHEN AID 5 Quart Artisan...
Problem with the RPMs
These mixers have a spring inside the back cover to make the control plate follow the speed control knob. Sometimes it unhooks and you only get on, and 1 or 2 speeds.
Jun 19, 2007 | KitchenAid KSM5PS Heavy Duty Stand Mixer
KitchenAid KSM150PS Artisan Series Stand Mixer Logo
711 people viewed this question
Top KitchenAid Food Mixers Experts
jack arons
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
