Question about Craftsman 10.5 Hp 33" Commercial Cutting Width Zero Turn Lawn Mower
Zero turn mower less than 24 hrs old just quit moving while in use. It still runs but push the levers forward or back produce nothing.
    Top Expert:
  • Craftsman Master
  • 47,630 Answers
Return to place of purchase for replacement
Posted on Apr 05, 2015
    Champion:
  • 208 Answers
Take it back! Don't try and fix this or you will void the warranty!
My RZT 50 turns blades on when levers are pulled back instead of shutting of and shuts off when in forward position ? could it be a switch is bad if yes what switch?
Sounds like someone has been working on the wiring, probably trying to bypass the reverse cut out switches . If you follow your steer control lever down under the plastic console covers there will be a switch, one on each steer lever by where it hinges. I don't think the switch is bad because it would not work at all if it was.It is like a door bell switch, when you pull back on the steer control lever it pushes it in and disconects the circuit to the PTO switch and the blades quit until you push them forwards and lets the curent through again. Also check the push pull PTO switch .Every safety switch on the tractor will meet at that switch and plug into it, . That model cub RZT50 has to have the worst switches ever made, but they are available and cheap on ebay. Plunger Switch 430362 430 362 for Cub Cadet Troy Bilt MTD 700 Series 725... PTO Switch MTD Cub Cadet Mowers GT RZT LT Force Mowers 925 04175
Apr 25, 2016 | Cub Cadet RZT L50 50" 23HP Zero Turn Mower...
It will run backwards but not forward
If you are able to move in reverse but not forward, you need to adjust the levers. First you will need to elevate the rear wheels and set the neutral. This will then allow you to set the levers for proper forward and reverse movements.
May 03, 2015 | Husqvarna Zero Turn Mower Z5426
Zero turn will not move forward reverse or turn
These units use Hydraulic pumps for motivation. If the unit stopped all at one time, I suspect a drive belt came off.
For both pumps to fail at the same time would be very odd. Check the v-belt driving the wheel pumps.
Apr 12, 2015 | Husqvarna Zero Turn Mower RZ4619
Mower starts and runs but won't move forward or reverse and brakes don't work.
If your transmission is automatic on the drive axle, look for a small lever inside the frame and below the seat. It can be hard to find the first time. This lever disengages the drive inside the auto gearbox so the mower can be pushed by hand. If the lever is not not moved, pushing the mower also tries to turn over the engine making it impossible to move. With the lever moved accidentally the drive is disengaged and the mower won't move in either direction. The lever operates a flexible cable that comes out from the auto transmission.
Dec 12, 2012 | Craftsman 24 Hp 48" Deck Yard Tractor
Toro Z5000 won't move
did the belt break or fall off? are the trans release levers pulled out ?the ones you release to push it around
Apr 14, 2012 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
MOWER WILL NOT MOVE
check the belts then make sure the levers you pull to be able to push it around are released
Apr 04, 2012 | Toro 74360 Zero Turn Rider Lawn Mower
This ZR4625 is new. It will not track straight. With both levers forward it tracks to the left, I can pull back on the right lever and it tracks ok but it slows down a little. What do you adjust?
First check both rear tyre pressures, if ok you need to adjust the rod that runs between the left lever and the hydrostatic drive on the left rear wheel so that the short lever on the hydrostatic drive travels further when push the drive lever forward. Regards Phil
Apr 14, 2011 | Husqvarna Zero Turn Mower Z5426
Mower will not free wheel.brakes off and hydros released
You have to do one more thing to move this tractor without the motor running.
It takes two people to move the Revolution. One needs to sit on the seat and hold the forward pedal down. It will then freewheel.
So, brake off, both hydro release levers pulled (do NOT pull hard or you will break the springs) and the forward (right hand side, big pedal) pedal pushed down.
Any other question? I know this unit pretty well.
Dec 30, 2010 | Craftsman Revolution 42" Briggs Stratton...
Hydrostatic mower goes in reverse but not forward. Only 73 hrs on it!
On my hydrostatic there is an adjustment on the forward/back lever which can be made to run all reverse or all forward. Normal setting gives both of course. Look at that adjustment. Maybe something let go.
Oct 14, 2008 | Garden
Craftsman 10.5 Hp 33" Commercial Cutting Width Zero Turn Lawn Mower Logo
140 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
