Question about Hoover Washing Machines
Does not agitate
Rest of cycle ok.
    Genius:
  • Hoover Master
  • 1,585 Answers
Check belt
Posted on Apr 12, 2015
It has a continuous cycling problem. The slides keep playing at a quick pace
You are describing "continuous cycle", a wear issue requiring an adjustment to the projector. To make this adjustment, unplug the projector, remove the lamp module and turn the projector upside down. Locate & remove the six T-15 TORX screws (or Phillips screws, depending on the generation of the projector). Gently pull off the bottom cover - be careful as the power cord is secured to both the bottom cover and the projector wiring. With the bottom cover open, locate the cycle contact near the center of the projector (see the diagram below for visual detail). When at rest (the projector on ), the clutch lever("J"-shaped wire) should be resting near the middle of the pad on the shaft assembly. With the projector unplugged(!), carefully bend ( so it doesn't break off!) the clutch lever slightly. Then plug in the projector, turn it on (be careful- 120volts exposed!) and cycle it a few times.Observe the position of the clutch lever to the pad. If it's OK, you're done.If not, unplug it & bend it a little more. Repeat as necessary.It usually takes 4 or 5 little adjustments to get it right.
Jun 09, 2015 | Kodak Carousel 5600 Slide Projector
Water drains but spin will not spin
This can be due to problems in the program cycle as it seems to over ride the program.
This can also be due to fault in the program controller unit , please try this with a separate program, also clean the drain , check the connections to the controller, check for fault in the level sensor.
Jan 01, 2013 | Washing Machines
Maytag LAT8426AAM agitator only works in delicate cycle
Best guess is a timer contact problem, usually caused by advancing the timer by hand without pushing the dial in to stop the machine first.This causes burnt contacts.
Aug 27, 2017 | Maytag LAT2301AAE
HI, I use the dough cycle and it takes 1 hour 20 minutes, but it actually only kneads the first 10 minutes and then here and there a minute for all together about 15 minutes of kneading. Is my machine not...
It sounds like everything is OK...machines knead a while,,,,rest a long time....knead a little rest along time etc......that resting allows the dough to rise....
Feb 27, 2011 | Breadman TR555LC Bread Maker
My Whirlpool Washer (top load) will not go into the rinse cycle and then finish the rest of the cycles and any setting.
If it fills up and starts the agitation mode (you can hear the motor running), open the hood to verify it is agitating (center post turning back and forth). If it is not phisicaly agitating then you most likely have a defective coupler. (couples the motor to the transmission) They are about $20 and require you to tilt the washer on its back to gain acsess to the bottom at the motor.
Sep 22, 2010 | Whirlpool Washing Machines
My dishwasher stops at the brush part of the cycle- as though it is just stuck. Rest of it works ok.
Probably a heating fault, heater or stat. You have not included a make or model so I am limited to the amount of assistance I can offer.
Aug 13, 2010 | Dishwashers
Washer fills but will not agitate
When you say the rest of the cycles. make sure it is spinning. That washer will fill up and drain and not agitate or spin if you have broken the couplier between the motor and transmission the motor reverses. tip the machine back and feel right behind the motor for a plastic coupler. In wash check the bottom part of the agitator if its moving and the top is not you will have to replace the doggets in the agittator.
Apr 26, 2010 | Whirlpool LSR5132PQ Top Load Washer
Washing Machines Logo
26 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
