How do I access the settings to change the area for local fm frequencies?
  • 509 Answers
Which radio do you own, first of all? Also you MUST unplug any cables from the audio connector - THEN - you can go to "MENU" and select your frequency. If you have an audio cable inserted, nearly every unit will NOT let you select the FM frequency. Okay? Thanks.
Posted on Apr 13, 2015
4 Suggested Answers
MrScary66613
  • 1990 Answers
SOURCE: cannot set fm frequency on radio
Go through the Settings Menu on the Reciever until you see Frequency Select It and then turn the dial until it matches the same frequency that you are using on the Radio.
Posted on Jan 01, 2009
SOURCE: Delphi SkyFi3 will not play through the FM radio into the speaker
i tried all the freq
Posted on Jun 28, 2009
TOLhamRadio
  • 509 Answers
SOURCE: what frequency should car radio be on to access xm
Go to your radio's MENU and set a frequency, then set your car to the same frequency.
Posted on May 27, 2010
How do i tune Mazda Demio (2004 model) radio to Southern African frequencies?
fm frequencies are just that fm frequencies ( not japanese, chinese ,english or anything else
it is a range of frequencies in the fm band that local stations broadcast on
so all you have to do is to turn the tuner knob until you get 107 fm
so as you turn the knob you will loose 89 and it will go probably 90.5 , 100.20, 102.7 etc and if there is a station broadcasting that your radio will pick up it will come in and then fade out as you keep moving the knob
you may have to change the mode as there are fm 1 ,fm 2,fm 3 bands to get your fm 107 as it will depend on what megahertz 107 is operating on
Oct 05, 2015 | Mazda Cars & Trucks
What frequency should car radio be on to access xm
Apr 24, 2010 | Delphi Roady XT XM Radio Receiver
What fm station do i use in the car
You need to find a clear radio frequency in your area then in the SIRIUS sat radio you will find a FM transmitter frequency adjustment menu. set it to the same as your fm radio and your all set.
Feb 19, 2010 | Audiovox SIR-PNP3 SIRIUS Radio Receiver
No sound when put on 88.3 fm
I didn't think this unit had an included FM transmitter - so I looked around for more info, and everything I've found indicates it does not.
It will however play audio via the built-in speaker or headphone jack. Use of a third party FM transmitter will allow playing audio (navigation, alerts, MP3 or audio books) when connected to the headphone jack and with both the FM transmitter and FM radio set to the same frequency.
The FM transmitter will work best when set to a frequency that is unused and has the least amount of interference from adjacent stations. Check by tuning the car radio across the FM band and note frequencies that have those qualities. Leave the radio on one of the clear frequencies and set the FM transmitter to the same displayed on the radio. You should try several to find the one that works best. Also, be aware that as you travel, you may enter an area where that frequency (or one close by) is in use by a broadcaster. This will require repeating the process as needed to reduce interference.
Oct 16, 2009 | Garmin Nuvi 350 Car GPS Receiver
Cannot set fm frequency on radio
Jan 01, 2009 | Sirius Satellite Radio Receiver
Pioneer GEX-FM903XM, system works great, however it often drops out and has just static. The signal indicator is strong. I think there is a bad connection into the radio. Where should I start...
It may be possible that the FM frequency chosen during setup, is in use in your area by a strong signal from a local station. Change to another frequency and see if the situation improves.
The following is from the Operation's Manual:
FM Modulator Setting
You can adjust FM Modulator frequency and output level.
7 Frequency
If output from the FM Modulator is hard to hear due to interference from a strong broadcast
station transmission, you can switch to another frequency.
You can adjust frequency between 87.9 and 90.1MHz.
7 Level
If the output sound is too quiet, too loud or distorted, you can adjust FM Modulator output
level.
You can adjust level between “LEVEL–1” and “LEVEL–7”.
1. Press the POWER button for 2 seconds to enter the FM Modulator Setting
mode.
2. Select the desired frequency
with the left/right arrow buttons.
3. Increase or decrease the Level
with the up/down arrows (buttons).
4. To cancel the FM Modulator Setting mode, press the POWER button again
for 2 seconds.
Note:
• After entering the FM Modulator Setting mode, if you do not perform an operation within about 8 seconds, the FM Modulator Setting is automatically canceled.
Nov 29, 2008 | Pioneer Car Audio & Video
Sirius S-50 Portable
Go to device settings - FM Frequencies - select the FM 1 or FM 2 or FM 3, turn the dial to move the FM frequency to that which you want. Press the Sirius Dog to enter this frequency. That's it.
Oct 20, 2008 | Sirius Satellite Radio S50-TK1 Satellite...
Radio set up on samsung j700
FM radio works the same way that AM radio works. The difference is in how the carrier wave is modulated, or altered. With AM radio, the amplitude, or overall strength, of the signal is varied to incorporate the sound information. With FM, the frequency (the number of times each second that the current changes direction) of the carrier signal is varied. FM signals have a great advantage over AM signals. Both signals are susceptible to slight changes in amplitude. With an AM broadcast, these changes result in static. With an FM broadcast, slight changes in amplitude don't matter -- since the audio signal is conveyed through changes in frequency, the FM receiver can just ignore changes in amplitude. The result: no static at all.
For sellecting frenquencies, go to radio, options, set frequency and search...
Jun 13, 2008 | Samsung Cell Phones
876 people viewed this question
 Grubhead
Grubhead
