Question about Sewing Machines
No how do you thread a HD110 - Sewing Machines
    Top Expert:
  • Sewing Machines Master
  • 10,875 Answers
Singer HD 110 Instruction Book
No how do you thread a HD110 - 25628349-sc4j0cxndsp5lf2xkgmobp5h-1-9.pngges/25628349-sc4j0cxndsp5lf2xkgmobp5h-1-9.png" alt="25628349-sc4j0cxndsp5lf2xkgmobp5h-1-9.png" class="h_mi" />
Posted on Apr 04, 2015
How to thread HD110 heavy duty singer
Here's a link to the manual for the machine. You should find your answer there.
Singer Sewing Machine User Manual ManualsOnline com
Apr 04, 2015 | Singer Sewing Machines
How do you time a hd110 singer sewing machine
Be sure to try a brand new needle first. If it still doesn't pick up the bobbin thread, then it possibly is out of time. Search for: sewing machine timing.
Jan 18, 2014 | Singer HD-110 Mechanical Sewing Machine
White 2037 twin needle keeps breaking thread
Thread breakage occurs commonly with mis-threading. Be sure to ALWAYS RAISE the presser foot when threading the top thread. Also, since you are using 2 threads, thread one completely and then thread the other so the threads do not get twisted in the thread path. If your machine has duel tension disks, thread each tension disk separately with a single thread. Setting the thread spools to turn opposite directions may help.
Also, make sure the needle eye is the right size for the thread. Thick or thin thread could break easily in the wrong needle.
Also, use only good quality thread--no bargain bin or old threads!
twin needle thread breakage Google Search
Nov 25, 2017 | White Sewing 2037 Mechanical Sewing...
How to thread the machine
Hello
Place spool of thread on the spool pin, found inside the carrying handle on the top right side of the machine facing the back.
Lead thread through the upper thread guide, located just beyond the machine's handle.
Lead thread through the second upper thread guide, found a few spaces to the left of the first upper thread guide mentioned in Step 2.
Bring thread around the second upper thread guide down into the thread guide.
Lead thread toward you down through the tension discs.
Continue to pull thread down through the ****. Forming a "U" shape, bring thread back up the left side of the guide, catching the check spring as the thread moves back up through the guide on the left side.
Bring thread up to the take-up lever and insert thread through the eye of the lever in a right-to-left motion.
Lead thread downwards, slipping it down through the horizontal thread guide.
Guide thread through the wire thread guide that is attached to the needle clamp.
Insert thread through needle from front to back, pulling thread four to six inches to create a thread extension. The machine is now threaded.
Aug 01, 2011 | Euro-Pro Shark Mini Mechanical Sewing...
How to put feed dog down on HD110
You either have a cover in your accessories pack, or there is a lever next to your bobbin case door. I suspect with the drop in bobbin that you have a little dark plastic cover to put over the feed dogs when you darn etc. Your manual should explain all of its uses. If, you didn't get a manual with your machine, call Singer and complain because it is a very important piece. Their number is 1-800-4singer. Make sure that you register your machine with them, also on their site www.singerco.com Good luck and happy sewing.
Dec 30, 2010 | Singer HD-110 Mechanical Sewing Machine
I have replaced the plastic bobbin case on the HD110 twice since I purchased the machine two years ago. I sew for a bit and then the case cracks at the edge; this catches the thread and causes tangling....
Yes, if I remember right, it uses a #15 bobbin which is available in metal, but I think that your timing or needle are not right. It may need a good old fashioned tuneup because that is not normal to be breaking a bobbin. Tuneups are usually is not a lot of money and well worth it.
Sep 25, 2010 | Singer HD-110 Mechanical Sewing Machine
My Singer HD110 is sewing very slow> It just started doing this when I turned it on today. It was fine last week. HELP!
the machine may need oiling
check the bobbin area for lint or loose thread
your belt might be getting loose & need to be tighten up
Aug 22, 2010 | Singer HD-110 Mechanical Sewing Machine
Thread bunches up on Singer HD-110
my wife's hd110 singer machine is not keeping tension. what can I do/ look at to try and help this
Jul 07, 2009 | Singer HD-110 Mechanical Sewing Machine
Threading a husqvarna huskylock 1001L serger
Solution taken from "Handbook for Huskylock Sewing Machine Models 1001L/1000L/1000"
1. Raise the presser foot by using presser foot lever. When the presser foot is raised, the two thread tension discs in the thread tension control panel are released so that thread passes freely between them. Otherwise thread tension may not be correct.
Important! When threading the needle, always be sure to lift the presser foot lever, and also take care to thread in the proper order.
Threading order:
1. Upper looper thread (green)
2. Lower looper thread (blue)
3. Double chain stitch looper thread (purple) in case of 5 thread stitch or double chain stitch
4. Right needle thread (red)
5. Left needle thread or double chain needle thread (yellow)
Caution!
Because the left thread tension dial (yellow) is used for either the left needle or the double chain stitch needle, these needles will never be used at the same time.
Upper looper (green) sequence:
1. Thread holder (silver triangle openings attached to thread holder stand)
2. Thread guide (flat silver clips just behind thread tension disc)
3. Thread tension disc (circular knobs with numbers for tension setting)
4. Pull thread around upper looper guide and upper looper
5. Pull thread into hole of upper looper
Lower looper (blue)
Repeat 1, 2, 3.
4. Pull thread around guide (see color coded chart inside front serger cover).
Easy threading mechanism (for lower looper)
1. Pull out the lower looper threading lever
2. Thread the lower looper and position the thread on hook of the lower looper
threading lever.
3. Push the lower looper threading lever back to its basic position while
holding the end of the thread.
Caution:
When returning the lower looper threading lever, always make sure that the two
blue triangle marks (directional arrows) meet each other.
Left needle thread (yellow)
Important: Thread the needles after threading of lower looper and upper looper.
First raise the presser foot lever, and then thread the needle threads in order shown in color coded thread guide.
Jun 24, 2008 | Sewing Machines
Sewing Machines Logo
26 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
