Question about Kenmore Dryers
I just purchase this and it has a gas connector and I don't have one. Do I need it use the gas line in order for it to work?
697267 model mumber
  • 774 Answers
This model is a gas powered clothes dryer. The electric plug is for the automatic igniter that turns the flame on. I suggest you take it back to Sears and get an electric one, if your home doesn't have a plumbed propane gas line.
Posted on Apr 04, 2015
The fuel filter has a normal screw type on one end the other looks like a "snap-in" app?
  • Hi, I can help.
  • The "snap in" side of the fuel line is removed with a GM fuel line gas tool. This can be purchased at any parts store for $5usd or so. You put the fuel line tool around the line with the round end facing towards the fuel filter and press firmly towards the fuel filter and this release the fuel line from the fuel filter.
  • When in stalling the new fuel filter make sure to have the point of the arrow on the fuel filter facing away from the pump as this indicates the direction the fuel flows. Where you use the fuel line tool to remove that line will just snap into place during install.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa
Regards, Tony
Sep 01, 2011 | 2002 Chevrolet Tahoe
I don't know which wire goes where on my car I have a 1994 Honda del sol and I don't know hot to connect the wires from the radio to the connector in my car
I recommend you purchase a wiring harness. You can order one specific to your vehicle. This will take the guess work out of what wire is which. Hope this helps.
Aug 15, 2011 | Car Audio & Video
How do i drop the fuel tank to replace my fuel pump on my 2006 chevy trailblazer LS. There are 3 lines that I don't know what they are used for after you drop the tank 4 or 5 inches.
their are two fuel line at the front of the tank one is the fuel feed and the other is the return line! Now the ones at the back of the tank are for emission you don't want to break or damage those make sure you disconnect all of those line and the is a red connector also at the rear of the top of the tank make sure you disconnect that. And just make sure careful when remove fuel pump it has a tight fit coming out also when your done make sure all your hoses and lines are reconnected and the red ont too! GOOD LUCK !
May 23, 2011 | 2006 Chevrolet Trailblazer
Kenmore electric dryer 697267... dryer will not start
We read the answer to someone else's question and tried it out... it worked! We replaced the thermal fuse and the thermostat, and everything is running fine now.
Jan 02, 2010 | Kenmore 73952 Gas Dryer
Where is the gas input located on the back of a duets dryer. I need exact location to purchase correct length gas line prior to delivery tomorrow.
The standard dryer BTU rating is 22,000 btus. A 3/8 connector by 60 inch will be good enough to handle it. Just make sure that you get the size that matches you gas line valve flare fitting. The connector should hook directly up to the gas line valve without an adapter. The adapter will come with the connector and that goes on the pipe thread connection at the back of the dryer. You only need to use PTFE tape or sealent on the pipe thread at the back of the dryer. You do use any tape or sealent on the flare fittings.
Oct 13, 2009 | Dryers
Craftman leaf blower when I press primer bulb I get air in line. It seems to be coming from block that choke is attached to hoses look good.
Diaphram gasket in carb is swelled and air is getting through,get a carb reduild kit and it should be fine.
Aug 05, 2009 | Craftsman Blower Attachment
Need pin number
Try going here and clicking on your specific model. Each models page has instructions included.
http://www.aclickawayremotes.com/Liftmaster/help.html
Mar 13, 2009 | Sears Craftsman LiftMaster Chamberlain...
I would check your thermal cutouts near the heater element. If they have continuity, see if your element is getting voltage. If it is, relplace the element.
Oct 27, 2008 | Kenmore 73952 Gas Dryer
Washing Machine Motor Missing Wire Harness
Go to www.repairclinic.com and order the complete wire harness and cap.
Easy place to do business.
Jan 23, 2008 | Washing Machines
Dryers Logo
81 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
