Http://www.scilogex.com/docs/SCILOGEX_DM1424_Hematocrit_Centrifuge_Manual.pdf
Parts for Centrifuges
there are 2 plastic tabs on each side,squeeze them in and push switch out.
The brake light switch is mounted to the brake pedal bracket assembly, under the instrument panel. The stop lamp switch attached to the mounting bracket.
Before continuing with this procedure, make sure to have available a new steering wheel retaining bolt and two lock cylinder retaining bolts. Once removed, these parts lose their torque holding ability (or retention capability) and must not be reused.
Unfasten the ignition and shifter interlock cable mounting bracket bolt, and position the assembly to one side
Use a chisel and hammer to cut a groove in the ignition cylinder bracket bolts-1991-96 models shown; 1997-99 models similar
To install:
