Question about Campbell Hausfeld Airless Spray Guns & Accessories Airless Sprayer 0.42 Gpm, 2/3 Hp, 50 Foot Hose, S150G Gun, X Tip & Filter, Sv Cart
I have a 50hp outbard that I just replaced the impeller due to it not draining water out of the indicator. It is still not draining. We've checked all hoses and cleared them out. No luck?!
    Scholar:
    New Friend:
  • 49 Answers
What about the water pump and filter ?
Perry
Posted on Apr 05, 2015
Where can Iget impeller #16622B010 for a shur dri water pump
I can only help on a Honda 50hp 2003. Any Honda center or parts center. That's all I know. JMC
Jun 09, 2014 | Honda Water Pump Impeller Outboard 35, 40,...
Tip
LG Dishwasher Fault Codes
Failure Code > Condition : Check/Repair
  • 1E Water inlet problem > Condition : Not reached to the normal water level in spite of 10 minute water supply. Water supply problem. The inlet hose is kinked. The water pressure is to low (10psi) Inlet valve. The inlet water valve filter is clogged. The hall sensor. The impeller of Air guide is bound. Remedy : Check resistance of inlet valve ( 950-1300ohms) Clean valve. Check pressure. Replace the Air braker.
  • OE Drain error > Condition: The drain hose kinked or blocked. Wiring connections. The drain outlet of sump is blocked. The drain pump/motor or circuit is troubled : Remove kink. Check wiring. Measure the resistance of drain motor (20-40ohms) Replace the drain motor or repair the circuit.
  • E1 Leakage error > Conditon: Excessive RPM of washing motor happened during wash cycle due to water leakage. Possible cause: Water leakage in hose connections,water is leaked by damages. The motor water seal leakage of sump assembly. The height of drain hose connection ( sink drain hose ) is not over 20". Impeller of the washing pump is worn away.Replace the connections of hose. Check the point of damages and repair or replace the related parts. Correct drain connections. Replace the impeller of the washing pump.
  • FE Excess Error > Condition : Excessive water is supplied than normal water level (automatically drain pump operated. Possible cause: The inlet valve is troubled,or the controller.Possible cause: The inlet valve is troubled,or the controller. Replace valve or the controller.
  • BE (Thermal error) > Condition: the resistance of the thermistor not normally out put. Possible cause the inlet water temperature is very high(over 194°F) Wiring connections. Thermistor problem.Check temps to dishwasher 120°F needed. Check thermistor 11-14kohms at 77°F. Replace the PCB.
  • LE( Motor error ) > Condition : The motor is working abnormally. Possible cause : Wiring connections. The impeller of washing pump is locked. The rotor of washing motor is locked. The blade is locked.Correct wiring connections. Replace the cause of resrtiction. Replace the washing motor. Replace the PCB.
on Feb 26, 2011 | Dishwashers
Washing machine will not drain
Since you've already checked the pump, hoses and motor, here are some additional issues to look at:
1. Faulty timer: Does your machine fill with water and begin agitating, but the cycle never advances far enough to allow the water to drain? The timer that controls the cycles may be broken. Arrange for washing machine repair service.
2. Worn or loose belts: Are clothes still soaked at the end of a wash, even though the washing machine appears to go through the spin and drain cycles? The timer that controls the cycles may be broken. This is a job for the pros.
3. Faulty or jammed internal impeller on pump: When the spin cycle starts, do you hear a humming noise? The internal impeller that moves the water through the drain pump may be faulty or jammed. A grinding or grating sound is almost always an indication of a coin, button or other object colliding with the impeller. Have a washing machine repair expert determine if the impeller is jammed and can be cleared, or if the pump needs to be replaced.
For more troubleshooting steps, see Washing machine won't drain. I hope this helps!
Oct 08, 2012 | Washing Machines
Error E1 on Candy dishwasher CDI 45
Hi
E1 is a leakage error in your dishwasher; it is usually displayed either due to a clogged drain or due to water leakage in hose connections. If the drain pump assembly is not clogged then check the motor water seal leakage of sump assembly and also check the impeller of washing pump, if it is worn then replace the impeller. You can also make sure that the height of drain hose is not over 20". Hope this helps...please post back for further assistance.
Daniel
Aug 30, 2011 | Dishwashers
I have an 1E error code. The manual says a blocked water feed hose. Ive checked all hoses and they are fine. Good water pressure. No water restriction. Is there a water flow sensor or something in the line...
Hi
E1 is a leakage error in your LG dishwasher; it is usually displayed either due to a clogged drain or due to water leakage in hose connections. If the drain pump assembly is not clogged then check the motor water seal leakage of sump assembly and also check the impeller of washing pump, if it is worn then replace the impeller. You can also make sure that the height of drain hose is not over 20". Hope this helps...please post back for further assistance.
Daniel
Aug 27, 2011 | LG 24 in. LDS 5811 Built-in Dishwasher
Wont fill with water. error E1 faucets is not opened. have water in mains.
Hi
Daniel
Aug 27, 2011 | Dishwashers
Is showing a 'E1' error and dings loudly.
Hi
Daniel
Aug 01, 2011 | LG 24 in. LD-12BS6 Stainless Steel...
E1 comes up on screen and alarm goes off, how do I fix it?
Leakage error > Condition: Excessive RPM of washing motor happened during wash cycle due to water leakage. Possible cause: Water leakage in hose connections,water is leaked by damages. The motor water seal leakage of sump assembly. The height of drain hose connection ( sink drain hose ) is not over 20". Impeller of the washing pump is worn away.
Solution:
Mar 25, 2010 | LG LDS4821WW 24 in. Built-in Dishwasher
I get an E1 error code. If I check the water level it is low so if I put in about two quirts of water it runs for only that water cycle, then I have to put in another quirt for the next cycle. The water...
Mar 23, 2010 | LG Dishwashers
Getting error message E1 what does this mean
E1 leakage error
The excessive RPM of Washing Motor happened during Wash cycle due to water leakage.
Water leakage in Hose connections. Water is leaked by damages. The Motor Water Seal leakage of Sump assembly. The height of Drain Hose connection (sink-Drain Hose) is not over 20 . Impeller of the Washing Pump is worn away.
Replace the connections of Hose. Check the point of damages and repair or replace the related parts.
Replace the Impeller of the Washing Pump.
Sep 03, 2009 | LG LDF6810ST Stainless Steel Built-in...
Campbell Hausfeld Airless Spray Guns & Accessories Airless Sprayer 0.42 Gpm, 2/3 Hp, 50 Foot Hose, S150G Gun, X Tip & Filter, Sv Cart Logo
571 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
