Question about Elite Kitchen Appliances - Others
Bolw for Elite model #epm-300 where can I find it
Where can I find a replacement wheel for the top of the popcorn Kettle for the Elite Cuisine by Maxi-Matic Model EPM-400? Our fell off and is lost.
That part, or any kind of substitute part is not sold in the USA. Return the machine to where you bought it if you can.
Oct 11, 2014 | Kitchen Appliances - Others
Heats up runs properly but not hot enough to actually pop kernels Elite cuisine by maxi max (r) Model No. EPM-400
Double check the corn measurements, and adequate power supply. Other then that you have to return it, you cannot repair that brand.
Aug 28, 2013 | Nostalgia Electrics KPM-508 Popcorn Maker
May I ask how much popcorn can the Elite Epm 250 Popcorn maker can produce?
The manufacturer rates it as a 2.5 ounce kettle. This means 2.5 ounces of raw kernels each batch.
1 ounce of kernels = 1 quart of popped popcorn.
Roughly a half gallon of popcorn every 3-4 minutes.
May 06, 2013 | Elite Epm250 Popcorn Maker
How much popcorn kennerls and oil do i add?
This is a 4oz popper. 1/2 cup kernels, 1/8 cup oil, 1 tsp popcorn salt in kettle per batch.
Feb 26, 2013 | Maximatic Epm450 Maxi-matic Epm-450 Elite...
Elite Epm250 Popcorn Maker instructions
Turn on the heater and let heat for 2-3 minutes. The Elite EPM 250 popcorn maker uses a 2.5 oz kettle. This is for 1/3 cup of uncooked kernels. Add kernels with a tablespoon of popcorn oil (available in markets) and a 1/3 teaspoon of what's called "Flavacol". It's a seasoning that they use in movie theaters to add flavor, saltiness and color. It's available online (ebay) or at Smart and Final. Use this combo and you can't go wrong. For cleaning, let kettle cool, the add 1/2 cup water. Turn on kettle and let boil for 2-3 minutes. Then empty it out.
Jan 15, 2012 | Elite Epm250 Popcorn Maker
Where to get parts for a Elite Cuisine EPM 400 Popcorn machine?
Model EPM-400 Elite Popcorn Maker
Distributed by: MAXI-MATICĀ® , USA 18401 E. Arenth Ave. Building B. City of Industry, CA 91748 Customer Service Department: (626) 912-9877 Ext. 116/120 MON-FRI 9am-5pm PCT Email: info@maxi-matic.com
Dec 08, 2011 | Kitchen Appliances - Others
Soundcraft EPM12, need power suply schematic pls.
This isn't your model BUT it is likely so similar as to be close enough to work a power supply problem.
http://elektrotanya.com/soundcraft_folio_f1-6-i-p_mixer.pdf/download.html
These companies don't change designs very much between different models.
Feb 07, 2011 | Soundcraft Epm12 Analog Mixer - Epm 12
Elite Cuisine EPM 400 popcorn machine
Maximatic Deluxe Popcorn Trolley Elite Cuisine EPM 400 popcorn machine burner is burnt out. where can i find a replacement pot?
Jul 23, 2009 | Maximatic Deluxe Popcorn Trolley Popcorn...
Not all kernals are popping
Heat the oil longer before you put the kernals in.
Dec 16, 2008 | Maximatic Elite 8oz. Deluxe Popcorn...
Kitchen Appliances - Others Logo
262 people viewed this question
Top Elite Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Ruth summersides
Andrew Taylor
Andrew Taylor
Are you an Elite Kitchen Appliances - Other Expert? Answer questions, earn points and help others
