Question about Dryers
Will not come on. But light is on in dryer - Dryers
  • Dryers Master
  • 5,323 Answers
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ut push start button for continuity with a meter when pushed in the on position, it may have gone bad.
Posted on Apr 06, 2015
Front panel wont light up, why?
I have the same issue. Dryer lights when door is opened, but no panel display, and no function.
Jul 26, 2014 | Kenmore Elite HE4 Electric Dryer
The dryer buttons don't work - there is electricity to the machine as the interior light goes on when door is open. However lights on front panel do not light and a cycle cannot be chosen. circuit...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 08, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
E03 error code
Error Codes
f01 light 4, motor triac
f02 light 3 motor, jammed/ tacho
f03 lights 3&4 Ntc fault
f04 light 2. pressure sw stuck on empty
f05 lights 2&4, pressure sw stuck on full
f06 lights 2&3, N/A?
f07 lights 2&3&4 heater relay
f08 light 1. heater relay
f09 lights 1&4 eprom/setup error
f10 lights 1&3, pressure switch not sensing
f11 lights 1&3&4, pump/draining error
f12 lights 1&2, communication error
f13 lights 1&2&4, dryer ntc/ fan motor
f14 lights 1&2&3, dryer heater
f15 lights 1&2&3&4, dryer heater relay
f16 N/A
f17 light 4, door lock
f18 light 3 comms error (3 phase motor) power board
Aug 09, 2010 | Siemens WTXD8300 Electric Dryer
Light in dryer does not work. Replaced light,
Check power with a voltmeter to the light socket. If there is no power, than either there is a broken wire, or disconnected wire from the door switch.
Dec 07, 2009 | Dryers
Dryer wont run but lights are on
check the door switch.or you may need to replce the main control panel. but you also need to check the thermal fuses inside the dryer cabinet,one of those can be bad.
Sep 26, 2009 | Frigidaire Electric Dryer
Hot water heater went out when they replaced our dryer doesn't
Make sure the gas valve at the dryer is turned on. Dryers use a glow plug or electronic ignitor to light the gas. There is no pilot light. Plug the dryer in and start it. Look inside the front lower panel to see if the ignitor glows. If it does and the gas does not light then the gas to the dryer is probably turned off. Look for a valve in the supply line to the dryer. Also inside near the front underneath.
Aug 05, 2009 | Dryers
The control lock light will not go off and the dryer will not work at all, I tried holding the end of cycle button for three seconds, but the light remains on. i have tried unplugging the dryer, but when I...
The control lock light will not go off and the dryer will not work at all, I tried holding the end of cycle button for three seconds, but the light remains on. i have tried unplugging the dryer, but when I plug it back in the control lock light come back on. Whirlpool Duet gew9250plg
Aug 05, 2009 | Whirlpool GEW9250 Electric Dryer
Whirlpool duet washer dryer, Dryer is stuck on control lock
look to the far right buttons labled control lock, hold it in for 3-5 secs, to unlock
Mar 23, 2009 | Whirlpool ET8CHEXSQ Dryer
Dryer does not work
Dryer just beeps, lights work, panel lights change, dryer just wont start. before this dryer worked but kept beeping thru the whole cycle. now nothing but lights.
Mar 13, 2009 | Whirlpool GEX9868J Electric Dryer
Pilot light
Pilot Light? Are you sure? All the gas dryers I've ever worked on were pilot-less. There should be a glow-type ignitor that heats up when the dryer is turned on. When it reaches a certain current potential a gas valve is opened and the burner ignites. How old is this dryer? Maybe this is something I've never seen before.
Jun 05, 2007 | Kenmore 72802 Gas Dryer
Dryers Logo
48 people viewed this question
Top Dryers Experts
