Question about Lenovo Computers & Internet
My lenovo got a new harddrive and won't boot at all not even bios what to do? It's a g 560
    Sergeant:
  • 268 Answers
Unplug the data and power cables from the new hard drive and try to start the computer and see if it runs the BIOS. If you are able to get into the BIOS, and have your Windows or other operating system install disk, you may also be able to get into the boot menu of the BIOS and try booting from a CD. That will tell you if the rest of the computer hardware is generally working. If you get into the BIOS with the hard drive disconnected, then try rebooting with first the hard drive power cable connected and then with power and data connected. If the computer boots into BIOS with just the power cable connected, but not the data cable, you could have either a bad data cable, or the wrong data cable for your laptop. If it won't boot with the power cable only connected, you likely have a bad hard drive.
Posted on Apr 08, 2015
If you shure that bios worked before...than its no chance that the hard drive is broken..2:load without bios without hard drive first..and if go into change bios default values standard..then restart cmo battery..put the hard drive in..restart it several times..and than if you got into than you must no how to create partitions...and read your manual for lenovo there is max value for hard drives
  • 509 Answers
You have to recover your MBR looks like, but first you need to remove the hard drive and see if it will boot without the HDD installed then get back to me ok. Also sounds like the BIOS may have failed if it wont boot without the HDD installed. But first things first.
Posted on Apr 04, 2015
  • Shade Tree All Repair
    Well have you done this yet? I will check back in a couple days if no reply I will have to remove the question for being a dead subject. When we are trying to help you time is important to all of us here especially free time.
My Lenovo mouse won't work. It connects and registers but won't move? Is there any help?
Try booting to safe mode and check if your mouse works inside safe mode.
Restart the computer and tap F8 until you see the options to boot to safe mode. Use the arrow keys to highlight either safe mode or safe mode with networking. Hit enter.
Once you are inside safe mode, check if your mouse works. If it works, then you just need to update the mouse driver. You can use RadarSync to search and install the update into your computer. You better use Safe Mode with Networking because RadarSync needs the internet or even the manual updating process needs an internet connection.
I hope this helps!
David
Apr 12, 2013 | Lenovo Computers & Internet
My dell inspiron 560 wont recognize any disc it acts like nothings in it how do i fix it?
Check Device Manager in Safe Mode by pressing F8 during boot. Right click My Computer > Manage. Select Device Manager > View > Show Hidden Devices. Now delete all DVD/CD-ROMs and reboot. Windows will say "New Hardware Found" and install. Check BIOS by pressing F key (correct F key is noted during boot) and make sure BIOS see's the Optical Drive.
Nov 20, 2012 | Dell Inspiron 560 (Intel Pentium Dual Core...
Hello, im having trouble with my motherboard (Gigabyte GA-8IPE775-G) im trying to re-install Windows XP on a brand new HDD and it can see it in Bios (set 1st boot to CD 2nd HDD) but won't let me...
Owners manual can be found here : http://www.retrevo.com/support/Gigabyte-GA-8IPE775-G-manual/id/23285bh940/t/2/
As to the boot process, its been my experience that if you can actually get into bios, then there isn't any problem with it. Problems usualy arise becoase of a setting chianged inside bios. Have you tried resetting bios to defaults to see if that changes anything?
BTW, have you formatted the new harddrive? Re-install works a heck of a lot better with a properly formatted harddrive.
Hope that helps.
Cheers from NZ
May 24, 2011 | Gigabyte GA-8IPE775-G (818313002198)...
Hello I have a LENOVO-Y430 laptop, suddenly my laptop stopped functioning, It gets stuck in the STARTUP LENOVO SCREEN, I get two options in the bottom of the screen, press F2 for SETUP & Press F12 for...
Welcome to Fixya
Make sure first that there are no devices plug in to the usb when you boot up the computer. Check if the harddrive is being detected by the computer. Press F2 to go to BIOS menu and see if the computer can detect you harddrive. It should be under the main menu and will say below harddrive. It should give you infromation of the harddrive. If there is no information of the harddrive then the problem there is the harddrive already.
Please reply to this email for any update.
Thank you for using Fixya!
Feb 02, 2011 | Lenovo IdeaPad Y430-3231U Notebook
I updated the bios and now it will not boot up
There is NO real reason why you cannot reflash your bios back to the way it was.... You simply need to find out what type your, bios is... and there are many programs that will address your BIOS and re-flash it. This is unless your BIOS is so broken that the machine will NOT even read a DVD memory stick or driver at all. What happens if you try again?
Some links below... all about it.
forums.lenovo.com/t5/Lenovo-3000-and-Value-line/.../198717 forum.lenovo.com/t5/T61-and-prior-T-series...bad-bios/.../true;...
Mar 01, 2010 | Lenovo 3000 C200 8922 - Celeron M 420 1.6...
How to format a lenovo laptop
If you have the OEM Lenovo XP disc are you have to do is insert and follow the instruction. If you are using off the shelf software, then switch the BIOS SATA to compatibility mode, and boot from your CD drive with the disc in it, and format the harddrive followed by installing the software.( like Windows XP or the Vista)
Jan 04, 2010 | Lenovo 3000 N100 0768 - Pentium Dual Core...
I put new harddrive in lenovo x60 while ruuning setting for xp installation .set up loading file then setup is starting window i receive following messege stop : 0x0000007B
I think 7b stopcode is hardware failure. Which means your hard drive is bad.
First I would try getting into your BIOS,(pressing F2 or DELETE or something upon turning your PC on) and finding a setting that says "SATA operation".... i think. You are looking for something that gives you 2 choices... either 'AHCI' or 'ATA'. It may not be called SATA operation, but it will definitely say 'AHCI' and 'ATA' as the two choices. Move the selection to whatever one it is not set on. Then try booting normally, or even re-installing again.
Try that BIOS setting first, that may be the only issue.
Good Luck.
Sep 14, 2009 | Lenovo ThinkPad X60 Tablet PC
Format hard drive without access to bios
is there an option when you boot up to go to a boot menu other than the bios, with dell's if you press F12 it will take you to a boot menu and you can select to boot from cd
Feb 17, 2009 | Lenovo 3000 N100 0768 - Pentium Dual Core...
New hard drive
you got a problem there.
may be you can return it and get a 80GB harddrive. e-mail me fo rinstruction how to install update BIOS.
Sep 30, 2008 | Fujitsu LifeBook B2131 Notebook
Harddrive
Get into boot setup and change the 1st boot device as hard disk
Dec 30, 2007 | Computers & Internet
Computers & Internet Logo
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
rey francis basa
rey francis basa
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
