Question about Nikon D5200 DSLR 18-55mm Lens Kit with Camera Accessory Kit - -
Menu button is not working - Nikon D5200 DSLR 18-55mm Lens Kit with Camera Accessory Kit - -
Menu button ont he remote will not work. The rest of the buttons work. I can't change the recording times
just clean the contact in the menu button of your remote controller then it will work now. now if you want to know if the menu button is working you can do the trick. using the digital camera turn it on to capture mode and then your remote controller point toward to the digital camera and press the menu button and look at the screen display of the digicam, if their is a light that was mean the menu button now is working.
Jun 25, 2012 | Televison & Video
Black screen for HDTV channels -- but TV menu and DVDs display normally
Try hard reset, Please unplug the tv cables and power cables for 30 min and redo the cable and check its working ....
Good luck...
Aug 01, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Tip
Service menu codes mitsubishi
I provide this information for those that are qualified and trained to do TV repair work. Entering or making changes in service mode by untrained persons can cause significant and permanent damage to your television. If you are not qualified to service your television, please DO NOT ENTER these service menu codes.
# Using the remote control press:
{MENU} {0} {3} {5} {3} buttons.
{MENU} {0} {3} {5} {7} buttons.
# Then use {VIDEO} or {AUDIO} buttons to enter two different groups of adjustments.
# {VIDEO} and {AUDIO} steps along through the adjustments, and {+} {-} does the adjusting.
# Press the {ENTER} button to save the change.
# Press the {MENU} button twice to exit service menu.
{MENU} {1} {2} {5} {7} buttons.
{MENU} {1} {2} {5} {9} buttons.
{MENU} {1} {3} {7} {0} buttons.
{MENU} {2} {3} {5} {6} buttons.
{MENU} {2} {3} {5} {7} buttons.
{MENU} {2} {3} {5} {8} buttons.
{MENU} {2} {3} {5} {9} buttons.
* Then use {VIDEO} or {AUDIO} buttons to enter two different groups of adjustments.
* {VIDEO} and {AUDIO} steps along through the adjustments, and {+} {-} does the adjusting.
* Press the {ENTER} button to save the change.
* Press the {MENU} button twice to exit service menu.
{MENU} {8} {2} {5} {7} buttons.
Mits VZ8 chassis Menus
Option menu, Menu 1270
Service Menu, Menu 1257
Convergence Menu, Menu 1259, 4 Fine,
5 Coarse, 6 Misc.
on Apr 29, 2015 | Mitsubishi Televison & Video
Tip
Saving contacts to SIM with Broken Screen Nokia 3109 3109c 2323 2323/c and...
This works for the Nokia 3109/c and also the 2323/c which have a Nokia menu like in the picture. If you have the same menu then it should work. The handsets have a central navigation button which allows you to move up, down, left and right through the menus.
Save Contacts to SIM blind. Nokia Broken Screen
Press Central Navigation Button to get Menu
Press Up once - Contact Menu
Press Central Nav Button
Press Up once - Copy Contacts Menu
Press Central Nav Button - From phone to SIM card
Press Central Nav Button - Confirm copy
Leave for a few minutes depending on how many contacts you have to copy
Press Button above call end several times to exit from the menu
on Aug 06, 2010 | Cell Phones
Problem for Sony SDM-HS75/B (Black) 17" LCD Monitor Menu buttons don't work but menu randomly appears
Try this:
Under the menu options, there's Menu Lock. Switch it to "On". It worked for me.
My menu button wasn't working, so to access the menu, I had to hold down the arrow up button and push the arrow down button till I got to the Menu Lock Option.
Dec 30, 2009 | Sony SDM-HS75/B 17" LCD Monitor
Why does the model and serial number keep popping up on my sony monitor?
Try this:
Oct 18, 2009 | Sony SDM-HS75 17" LCD Monitor
Tip
Acessing Menu with universal remote
We used a One4All model URC3021BOO remote. We programmed BOTH the TV function and the DVD/vcr button with code 0807.  To access the menu PRESS TV then MENU button then DVD/VCR button will allow you to change menu functions using left and right and select buttons. *TV button will access Menu screen BUT NO menu functions. * DVD/VCR button will NOT access menu screen but WILL control menu functions if menu is already displayed. May work with other sharp products, or other universal remotes? These original (RRMCG1330PESA) remotes run 38.00+ to buy new so try this FIRST!
on Oct 29, 2008 | Sharp 13VT-J100 13 in. Combo
Nokia 6103 LCD screen broken, need to transfer contacts to SIM
Menu
down once
menu
menu
upper left
down 4 times
menu
menu
down once
menu
(now you have to decide - for keep original press menu, for move original down once and menu)
upper left
menu
Dec 11, 2008 | Nokia 6103 Cellular Phone
Sony sdm-hs75
Try this:
Jun 29, 2008 | NEC MultiSync LCD15T Monitor
No remote specific to Sharp combo unit..how to turn off closed captionning
on some models the menu button is on the front disguised as the volume up/down or channel up/down buttons. you have to push both up/down buttons on either one of these to bring up the menu.
Apr 24, 2008 | Sharp 13VT-K100 13 in. Combo
Nikon D5200 DSLR 18-55mm Lens Kit with Camera Accessory Kit - - Logo
615 people viewed this question
Top Nikon Video Cameras Experts
David Payne
David Payne
ray gallant
Tony Parsons
Tony Parsons
Are you a Nikon Video Camera Expert? Answer questions, earn points and help others
