Wan lan wlan settings huawei hg533 router home network
    Top Expert:
  • 10,875 Answers
Is the HG533 router an 802.11ac
www.chatteris.biz/.../HUAWEI_HG533_User_Manual(02,English,General_... specifications go to the above address to download the manual including tech specs
Nov 22, 2014 | Computers & Internet
How can I extend my home internet network?
Yes you can connect the LAN ports with a network cable from your 3G router to one of your old router LAN ports
Before connecting the 2nd router:
Check it does not have a conflicting IP.
Check it is in the same subnet
ie if 3G router is 192.168.0.1
Set old router to 192.168.0.10
subnet mask 255.255.255.0
gateway is 192.168.0.1
DNS 192.168.0.1
Set DHCP off on 2nd router.
Set WIFI to Same SSID, same password and authentication
ensure it is on a different channel though.(not automatic on either)
Finally just to make sure remove any WAN settings from your router, any old ADSL config etc so that it doesnt think it is a gateway.
Apr 30, 2014 | Computers & Internet
Huawei HG533 router
OK, do you have a question?
Mar 05, 2013 | Computers & Internet
How do i hook up my router?
There are several ways to do this, depending on how your network is configured.
Generally, if you have only one router - you connect the network jack of your cable modem or DSL modem to the WAN ("wide area network" or "internet") jack of the router with a CAT 5 network cable or jumper. Each computer's network jack would be connected to one of the router's (4) LAN ("local area network" or "home network") jacks labeled 1, 2, 3, & 4.
In the picture above, the left most jack (WAN) of the router connects to the cable or DSL modem. The "LAN" jacks labeled "1, 2, 3 & 4" connect to each computer's network jack in your home.
The above would change if you are simply adding this router to extend an existing network. You'd likely be using this router as a switch, and leaving the routing duties to the main router. Over simplified, all the CAT 5 network cables would be connected to the 4 LAN jacks. There would be no connection to the router's WAN jack because the output of the first router provides only private IP addresses used in YOUR location. The internet IP address from your ISP is used only at the first router so that your entire home has the single IP address. The WAN jack is for internet addresses only - and the LAN jacks are for local / private addresses in your home only.
Have a look at the LinkSys web site for help configuring your particular model router, or reply with the model and version here.
I hope this helps & good luck. Please rate my reply - thanks!
Jan 28, 2011 | Linksys Wireless-G Broadband Router
Wan and All LAN led bulbs are continuously on- Router not working
Straighten a Norwegian paper-clip, and insert one end into the small hole in the back of the router, to "reset" the router to its "factory" settings.
Or, spend $50, and replace the router.
Mar 26, 2010 | Trendware TEW-452BRP Wireless Router...
Can I use 2WIRE 2701HG-B router in COX internet connection
No. A router has 2 main interface types WAN (for the internet connection side, and LAN (for the home network side) the 'LAN' side often has up to 4 ports and wireless connectivity for the home network.
The most common routers available at electronics retail use a CAT-5 connection for the WAN ports and the LAN ports. Your DSL modem/router uses a phone line input for it's WAN port, which uses a signal type that is incompatible with the cable modem output.
If COX doesn't offer a router with the cable modem package, you can go and purchase and common brand of home networking router, and attach it to the output of the cable modem.
Feb 28, 2009 | 2wire 2700HG-B Router (2700HGB)
Hg520s Huawei wireless router
Make sure you LAN settings is looking at your Wireless Adapter for WAN source, your computer might be looking up to the Wired Adapter for source, with not much info that's all i can suggest.
Create a new connections and make sure Wireless Adapter is selected.
Hope this helps
Enjoy
Apr 27, 2008 | Computers & Internet
Computers & Internet Logo
78 people viewed this question
David Payne
David Payne
