Question about Head Health & Beauty
Main cutters fell out how do you put it back together?
Blue holder and thre cutting blades fell out of head when cleaning
  • shaveroutlet.com
    shaveroutlet.com Apr 07, 2015
    Hi Ken Sandy Freligh, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    Please provide make and model of shaver
  • 509 Answers
T
They should have 2 flat sides on the otherwise round heads look for the flat sides on the insert areas then put the plate back over them if this one has one and turn the lock the machine will line them up automatically when it starts running.
Posted on Apr 04, 2015
How to reassemble blades on wahl stable pro 8800
Do you have more parts in your hand than 2x screws and 2x blade parts? If no then pop the small cutter blade onto the plastic blade drive with the drive engaged into the diamond shaped hole in the cutter blade. Make sure you put the cutter blade on with the teeth facing forwards and the correct way up. The top side (goes towards clipper) is pretty much flat except where teeth taper. Next lubricate the small cutter where it is going to touch the large comb blade when you fit it. Now put the comb blade on and fit the 2 screws. Line up the blades & tighten the screws.
Apr 20, 2015 | Wahl Whal Stable Pro Pet Animal Clippers...
How to put a oater a5 blade back together
There needs to be a video for this one but if you look at your other blades they can give you a guide. I wouldn't take the others apart though.get your pieces together the best you can. Don't forget the little plastic sliding piece. When you tighten the screws tighten the two equally and try your best to align everything as much as possible. Now look at your cutter blade and make sure the teeth don't stick out higher than gaps of the teeth on the main part of the blade. This will cut a dog.
Sep 01, 2014 | Oster Clipper Golden 2 Speed A 5
Paper cutter
You should try replacing the cutter assembly with a new one. They are rather inexpensive ($50) to purchase and easy to install.
The only other thing I can think would cause your problem is if something is stuck in the groove by the cutter guide that would cause it to disengage while cutting.
Jun 07, 2013 | HP DesignJet 500 InkJet Printer
What is the difference between the angle cut blades and the shear cut blades on my bolt cutter?
angle cut blades have the cutter head angled at 25-35 degrees for easier insertion into tight spots. Shear cut blades are light normal scissor blades
Jan 16, 2013 | Cutter Tools
Why my andis outliner not cutting
Try cleaning the head cutter below the main stem. Remove screws and clean old hairs in there, also lubricate.
Thanks
Jun 13, 2011 | Andis 04603 Hair Trimmer
We own a Dewalt DW735 13" planer. Have lost or misplaced the owner's manual. We need to reverse the knives for the first time, and do not know how to do it.
Unplug the machine then crank open the head up as far as it will go. Underneath, in the middle of the head you'll find two feed rollers and a cutter head with the blades on it. Even dull the blades are very sharp so work carefully. Each blade is held in place by a blade holder and eight allen screws. Remove all eight allen screws and the holder and blade will fall out. If they have excessive sawdust or tree goo on them they may need a bump from the plastic end of a screw driver to knock them loose. Keep track of how they come off so you can put them back on the same way only with the blade turned around. The top of the blade holder will fit into a channel in the blade so they'll all go back in lined up correctly. Turn the cutter head carefully to get at the other blade(s) to change them.
Nov 15, 2010 | Garden
My clippers are no longer cutting. I took it apart today and cleaned out all the hair but I still can't get it to cut. I felt it and it's very sharp it's just not cutting any hair. I have been told it...
there is probably hair stuck between the cutters
remove the cutters from the clipper and you can push the top blade out from under the spring retainer making sure you keep the small plastic runner strip
clean the surfaces and using a flat bladed screw drive insert the blade under the spring and twist slightly to allow the top blade to slide back in
while it feels sharp , it is the sides of the cutter fingers that cut the hair ( like miniature guillotines) and those edges are easily worn off
May 04, 2017 | Remington Precision HC-8017 Hair Trimmer
Diagram showing assembly of 4 parts of cutting head
I solved the problem finally. I discovered that the plate which has the 2 large threaded holes which carry the fixed cutter, had to be locked in behind 2 spring fixing points (on the body of the clippers) before inserting the tongue into the body of the shaver. When I first removed the plate I used a screwdriver blade to spring the tongue away from the body and the whole caboodle (4 pieces) fell out on the bench, so I didn't see how it was assembled. Thanks for your interest anyway.
Jan 08, 2010 | Kitchen Appliances - Others
Cannot put blade assembly back together
Sounds strange, since I don't think that the HQ5 heads in the shaver have the pointy parts that other shaver heads have. If your comb has 2 pointy edges, make sure they are located correctly in the head housing - they will need to be located inwards, with the the spindle that the retaining bracket attaches to in the center of the the two pointy parts.
But apart from placing the combs in first, locating the cutters in then putting the retaining bracket in (which may be broken if it won't fasten properly) I'm not sure what you can do, other than calling your local Philips Service Centre,
Apr 07, 2009 | Norelco Reflex Shaver 5885XL Electric...
No running manual 4 summasign pro D610 vynal cutter
You can get assistance and possibly a manual for your Vinyl Cutter from a Summagraphics Repair facility such as
ADVANCED GRAPHICS
1027 N. MAIN STREET
TEL: 210-227-9393
SAN ANTONIO, TX 78212
I hope this helps. Toni Gallucci, Glass Act
Mar 17, 2009 | Computers & Internet
Health & Beauty Logo
97 people viewed this question
Top Head Health & Beauty Experts
rugby prop
john h
Are you a Head Health and Beauty Expert? Answer questions, earn points and help others
