Question about Husqvarna YTH21K46 (46") 21HP Lawn Tractor 960 43 0085
The wheels are off center, can the steering be adjusted?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 66 Answers
If this is on a tractor, no the steering does not come with adjustments. However, there are adjustable links available. Check with your Husqvarna dealer to determine if they are available for your model.
Posted on Feb 22, 2017
How to fix play on tata xenon 3l dicor power steering unit
Most power steering units have two adjusters--one one the lower end for main bearing adjustment, but the one on top (just like manual steering boxes) is all you usually need to adjust. With front end jacked up and engine running adjust screw inward until drag is felt in steering wheel with wheels pointing straight ahead, then loosen just a touch until no bind is felt as steering is turned back and forth through center of steering.
Oct 28, 2016 | Tata Cars & Trucks
How do I adjust the steering on a 1998 z71 4 wheel drive
If the steering wheel is off center generally its not the wheel. Something is out of alignment underneath. Tire rods, pitman arm, you name it, that is where the real problem is. Could be out of adjustment or bent some way. Can tell where to look because we cant see it, but 90% of time problem not in steering wheel
Jan 28, 2015 | Cars & Trucks
How do I balance or adjust the power steering control valve on a 1975 Corvette?
If your steering is operating normal and you replaced the valve, a front end aling will staighten your wheels and center your steering wheel
Dec 02, 2014 | Chevrolet Corvette Cars & Trucks
REPLACED STEERING GEAR BOX IN 2003 CADILLAC ESCALADE NOW WHEEL IS OFF CENTERED
IF you have a rack and pinion steering pull the steering shaft of the pinion splines and centre the wheels . Centre the wheel and put the steering shaft back on the splines. If it is master splined then centre the steering wheel and adjust each side tie rod until the wheels are centred . (one in -other out ). Remember that when the wheels are straight ahead then the steering wheel will be slightly to the left (USA) to compensate for the camber of the road.. IF a steering box pull the pitman arm off --centre the wheels and the steering wheel and refit the pitman arm
Mar 02, 2014 | Cadillac Cars & Trucks
What's your problem?WHY IS MY STEERING WHEEL NOT CENTERED AFTER AN ALIGNMENT ON A 1996 CHEVY C1500
No the **** has to fix that with toe adjustments to each side to bring the wheel to center. or the wheel has been removed on another realignment and centered at the wheel which is NOT the way to do it.
Sep 16, 2012 | Cars & Trucks
Drag link adjustmnet
Your desctiption sounds like your settings are incorrect. I reccomend that an alignment shop adjust for you.
A common mistake on this type of project is steering box centerning. to test, from straight ahead, stop.., turn wheel from dead center to the stop, and measure exactly how many turns. From dead center, it must be the same both ways.
Steering boxes have an exact center setting, and get looser (so to speak) as turned right or left off of that spot. SOOO, if set to one side or the other, steering gets tighter when turning in one direction as compared to the other.
Get an alignment shop to set this up, it is common problem.
Sep 07, 2009 | 2000 Jeep Wrangler
Esp/bas light on, steering wheel off center after off roading
If your steering wheel is off center, this can cause the problem. Luckily this is very easy to fix -- you can do so even if you have little to no experience working on your vehicle.
1. Park the vehicle with the wheels facing straight ahead (drift forward until you are moving in a straight line). Don't worry about the steering wheel position. 2. Locate the steering drag link -- the diagonal rod coming from the bottom of the steering arm to the top of the passenger side steering knuckle (on the axle near the tire) 3. Loosen the two bolts on the rotating adjustment collar on this link. I believe these are 13mm. 4. Rotate the collar one way about two or three turns, check the steering wheel to ensure that the "Jeep" logo is perfectly horizontal. If it's not, continue rotating the collar (or move it in the opposite direction) until the wheel is centered. 5. Tighten down the nuts on the drag link adjuster. 6. Take her for a test drive and let me know how it worked!
Apr 06, 2009 | 2008 Jeep Wrangler
Wheel alignment
The main cause of steering wheel off-center is toe misalignment or rear axle misalignment. Toe can fall out of adjustment fairly easily as a result of daily driving, so you can imagine the effects of pounding it through 4WD trails on a regular basis.
Toe is designed to preload the steering linkage to remove play in the system. You can visualize toe angle from above; toe-in, or positive toe, is displayed when the leading edges of the tires are closer together than in the rear. Toe-out, or negative toe, is when the leading edges are farther apart. Zero toe is when wheels are pointed straight ahead and are parallel to each other. A slight amount of positive toe is preferred for most vehicles.
Improper toe angle isn't the only reason a steering wheel won't center. This phenomenon can also be caused by the steering linkage not being centered when toe was adjusted in the first place. This can be corrected by recentering the steering wheel and readjusting toe to proper specs. A bent steering arm or linkage component can also cause the steering wheel to be off-center. I've also seen this occur due to loose steering arm bolts. An off-center steering wheel contributes to tire wear because as the wheels are turned off dead center they turn toe out and increase tire scrubbing.
Sometimes an off-center steering wheel is accompanied by a wheel pull to one direction or the other and could be the result of a damaged component somewhere in the vehicle - a bent axlehousing could be throwing off the rear toe setting (rear toe setting is often overlooked). A bent frame or overly worn suspension bushings can also be the cause. If your wheel is off-center and also pulling, it can be as simple as incorrect tire pressure from side to side. Memory steer is another effect that is usually associated with an off-center steering wheel. This is when the steering wheel returns to an off-center position and can result in steering pull or drift after completing a turn. This can be caused by binding in the steering linkage as well as power steering system issues such as leaks or improper hydraulic pressure. Steering linkage bind occurs when proper geometry is not maintained in lifted vehicles.
Many 4x4s don't have factory provisions for adjusting caster and camber and rear toe and camber, but the front toe setting is easily adjusted. Toe is controlled by the steering linkage. By loosening the adjusters on the tie rod and shortening or lengthening the tie rod by turning the ends, toe angle can be adjusted. This should not be a substitute for regular professional wheel alignment jobs and is simply a tip that can be used to put off frequent trips to the alignment shop due to regular trips to the trail.
Before determining toe angle and/or performing adjustments, it's a good idea to start the engine and turn the steering wheel side to side to relieve pressure in the system. Then, turn the wheels straight and shut off the engine. You should also roll the vehicle back and forth a few times between measurements.
Get someone to hold the other end of the measuring tape and measure the leading toe distance. This is the distance between the leading edges of the front tires. You'll compare the results to the distance between the trailing edges of the tires directly opposite from where you took the first measurement.
The higher number will indicate toe direction: higher number in leading edge indicates toe out; higher number at trailing edge displays toe in. Larger-than-stock tires require more positive toe for best results.
Once the necessary measurements are performed to determine what the current toe setting is, you can loosen the bolts on the tie-rod adjuster sleeve so that the tie-rod ends can be rotated. Don't forgot to tighten the adjusters when you're done as damage or injury could result.
The tie-rod ends thread into the tie rod. The ends can be threaded in or out of the tie rod to make the assembly longer or shorter. Longer creates more toe out; shorter toe in. Don't make huge adjustments all at once. It's best to adjust and measure a few times to achieve appropriate setting.
I hope this helps you if you were looking to do a toe alignment yourself if you have decent knowledge of component location on a jeep.
Jan 30, 2009 | 1995 Jeep Grand Cherokee
Uneven steering wheel
Off center steering wheel is very common, a good front end man will drive the car/truck and verify that the wheel is centered, it is not a mechanical problem just an adjustment issue, go to an outside shop or another dealer and tell them u just want the wheel straight, remember the road has a slight angle to drain water off, it's called road crown, tell them you want the wheel centered and to take road crown into account when they do it, make sure the front end man double checks the center by means of a good road test on varied road surface, tell them where it is that the off center is most noticeable, all this is from personnel experience, I am a fanatic about the wheel being centered. If u have more questions fell free to ask, sorry for your justified frustration on this issue.
Jan 06, 2009 | 2005 GMC Envoy Xl
Husqvarna YTH21K46 (46") 21HP Lawn Tractor  960 43 0085 Logo
231 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
