Question about Moultrie Mfh-dgs-d55ir
Camera clicks but does not actually load a picture. There is nothing on the sd card.
3 Suggested Answers
  • 3 Answers
SOURCE: camera screen said SD card is locked when I installed an SD card
#1) On my camera if there was a picture that got stored in the internal memory it would not reconize the sd card nor store the pictures on the sd card. I would have to take the sd card out and delete the pictures in the internal memory and then reinsert the sd card.
#2) Some how or other the files that were on the sd card would get scrambled on the sd card when I would try to erase them. I would have to reformat the sd card back to a "fat" format before it would work again.
Posted on Jul 28, 2009
  • 3287 Answers
SOURCE: Camera doesn't recognize the sd card, bypasses it
1) This camera accepts SD cards up to 4 GB in capacity. Most 4 GB SD cards however, are "SDHC" types (check the label to determine which type you are using). If you are using a 4 GB "SDHC" card, it may be causing the problem, as it is not an "SD" card. Furthermore, any card greater than 4 GB is not compatible with the camera. Any SD card with a capacity less than 4 GB should work without issue.
2) Check the position of the lock or "protect" tab on the side of a compatible SD card to be sure it is in the unlock position. The camera will be unable to write to a locked or protected card.
http://www.moultriefeeders.com/Game-Spy-D40
I hope this helps!
Posted on Oct 20, 2009
"memory full" but SD cards are empty
Not sure if it will be this, but has the SD card got locked by accident? There is a little sliding button on the side of the card, which can be locked to protect the content. My camera shows the card as full if I accidentally lock the card. You can just slide it back again to unlock it. I never noticed the button was there until I accidentally knocked it while loading the card in and out of my PC to transfer the photos.
Dec 04, 2012 | Fuji FinePix S1000FD Digital Camera
Hi, got new kodak camera and 4gb memory sd inside. i only took 8 pictures so far and said internal memory full. i dont understand why? i want to keep 8 pictures and it should be plenty as using 4gb and...
4GB "SD" cards are almost always actually SDHC (high capacity) cards. SD and SDHC cards fit the same slots, but they are slightly different electrically. Many cameras won't work with SDHC cards. SDHC is not backwards compatible.
So your camera is not able to use the 4GB card, and is ignoring it and using internal memory only. That memory is tiny and won't hold many pictures, and when it is full, the camera cannot work at all. You need to delete the pics in the internal memory and get a memory card your camera can understand (2GB or less).
Jan 27, 2011 | Kodak Cameras
When I try to take a picture, it says memory full. But, when I try to look at the memory it says no file. I tried using the disk, installing software, formatting it.. Nothing works. The SD memory card is...
Format the SD card make sure the camera is set to place the new files on the SD card and not go to the internal memory. What I fully expect is the camera has defaulted to using the internal memory which is now full of files/pictures and needs to be set back to SD card. To get the pictures from the internal memory to your computer you need to load the pictures one by one from the internal memory to the SD card. Then take them from the SD card ether to a card reader to the computer or download them from the camera to the computer.
Dec 25, 2010 | Vivitar ViviCam 8025 Digital Camera
My son cleared the sd card for my dimage e323 using my laptop after down loading the pics. When I re-inserted the card in the camera it now says it needs to be formated. I have clicked "yes" and...
Formatting it in the camera is the only way to get it to work. Try it again and be sure the slide switch on the side of the card is in the unlocked position.
Nov 26, 2010 | Konica Minolta DiMAGE E323 Digital Camera
I just inserted a 8 MB card in and the camera says "Memory card needs formatting" I click continue, then it says "Formatting will delete everything on the memory card", no problem, it's a new card so I...
8MB or 8GB? If it's actually an 8MB card, you'll be able to put maybe two or three pictures on it, so I'll assume it's an 8GB card.
The DX4530 is designed to work with SD cards. Your 8GB card is actually an SDHC card. While SDHC cards will fit into SD devices, there are electronic difference that prevent them from working there. SD cards will work in SDHC devices but not the other way around.
You need to use SD cards, 2GB and smaller.
Sep 30, 2010 | Kodak EasyShare DX4530 Digital Camera
How do i transfer my pictures from my computer back to my easy share camera
Take SD card and stick it in computer card reader.
Load card from computer with mouse select transfer click.
Now take loaded SD card and put it in the camera.
Vitally
Apr 19, 2009 | Kodak EASYSHARE M1063 Digital Camera
Transferring pictures from old computer to blank SD card
I plugged my camera into the USB port in the CPU and reinstalled my Picture Project, into which the 240 pictures automatically imported from My Pictures. Then I turned my camera on and clicked Export JPEG and voila... they started exporting. I didn't know for sure if it had worked, since I could not actually view the pictures on my camera after that, but when I put the SD card in my other computer, they were on the card and I loaded them into My Pictures with no problem at all!!!
Jan 13, 2009 | Kodak EasyShare One Digital Camera
Retrieving pictures from SD card
You may take a look at this SD card photo recovery guide which helped me get back deleted photos after reformat the SD card
recover photos after reformat SD card
good luck!
Dec 03, 2008 | Kodak EasyShare C613 Digital Camera
New memory card will not work
this camera is actually really compatible with the 2gb sd card, anything higher will give you that message. since you have the right kind but still won't work - 2 possibilities:
camera memory ready issue > repair necessary
defective card> try another one
Dec 04, 2007 | Kodak EasyShare C340 Digital Camera
Moultrie Mfh-dgs-d55ir Logo
151 people viewed this question
Top Moultrie Computers & Internet Experts
David Payne
David Payne
Are you a Moultrie Computer and Internet Expert? Answer questions, earn points and help others
