Question about Dryers
What causes Electric dryer to not start & run
Turning the momentary start switch just gives a strong hum. Like a motor with a bad starting capacitor but there is none. Motor turns free and so does drum. slide bearings good
    Champion:
  • 220 Answers
Open the door and depress door switch have someone activate start button when humming rotate drum if it starts and continues to run replace motor
Posted on Apr 05, 2015
  • Gale H
    Gale H Apr 05, 2015
    Thanks Dryon, After finding a solid ball of fluff in the blower, I did as you said and it runs repeatably now. Still not sure if it is motor or too much start resistance. If I were fixing for someone else, I would just change motor but will change slider plates and see what happens over time. Thanks again for a very practical diagnosis step!
  • Gale H
    Gale H Apr 05, 2015
    Please excuse my screwing up your name, Dyron!
Do Samsung dryers (Model DV330AEW/XAA)have an independent capacitor or does the whole motor need to be replaced when bad?
Check to see if unit has start capacitor. Go to attached web site for diagram . If no start cap is involved then make sure that the motor bearings are as friction free as possible and it spins freely.
Some motors in lieu of a start cap have an internal centrifugal switch that diverts the power from a start winding to a run winding. If that internal switch is fubar unit will not start unless you nudge it as you have been doing. If that is causing the hassle see if that motor part is available separately to save you some dinero.
Search Over 2 1 Million Appliance Parts
Feb 12, 2016 | Samsung Dryers
My Kenmore 90 Series electric dryer makes a humming noise when I push the start button. It heats up, run for a short while, then stops. Before it stops there is a clicking noise like a circuit or safety...
There's possibilty that the bearing is going bad. It would cause the belt to slide alittle when the drums starts to turn. The strain on the motor because of the bad bearing can cause the motor overload and shut down until it cools, then it can be restarted.
Apr 08, 2011 | Dryers
Dryer won't tumble, i only hear on/off switch humming.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
heatman101
Jan 25, 2011 | Whirlpool LER4634J Electric Dryer
Maytag Electric Dryer will not run. Start button sometimes gives a momentary low pitched hum then dies. Motor wont start. Door is closed power is on to unit.
Try this, tape the button down press start and give the drum a push to see if it will spin. If you can jump start it that way, you will need to replace the motor.
Jan 02, 2011 | Dryers
Dryer does not come on. when I push the start switch it hums as if wants to start but won;t.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 06, 2010 | Estate TEDX640JQ Electric Dryer
Drum wont turn but dryer heats.door switch and push to start switch ok. No hum or buzz from motor.
Dryer Repair - The
Dryer Repair - The
heatman101
Jun 24, 2010 | KitchenAid KEYS750LQ Electric Dryer
Gas dryer hums when I press the start button but won't start
hi thats a sign of a faulty motor . replace the motor thanks the appliance doc.
Oct 12, 2008 | Roper RGX4634KQ Gas Dryer
GE Dryer DWSR473GV0WW periodically just hums when turning on switch
if it hums when you start it means switch is ok. problem may be the motor capacitor. to check, take off the top and give the drum a push in the normal direction of rotation. if it goes then motor capacitor is faulty - cheap part
Mar 28, 2007 | GE Profile DPSB619ED Electric Dryer
My Matag dryer does not run, but for a while it hummed before starting.
Motors of this sort have a "start" winding, to give them an extra boost to get them turning. Once they're turning, the start winding shuts off. Critical to this is the start capacitor which, when shorted, causes the exact symptom you've described. The motor's "regular" winding gets power (and then hums), but it needs that extra boost to actually start turning. Have someone check the capacitor (with an ohmeter) or check to see if the motor's start winding is open (broken).
Apr 10, 2006 | Maytag HYG2460AWW Gas Dryer
Dryers Logo
69 people viewed this question
Top Dryers Experts
