Question about Kenmore Dishwashers
Top tray of a Kenmore dish washer stuck at mid point. Will not open fully or close.
Model 665.1373, this model has an adjustable top tray which is locked at a mid point. How do I get it out or all the way in?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 183 Answers
Something is broken inside... You may be forced to force it.
Posted on Apr 05, 2015
Dishwasher door does not close
Does not close or does not lock? If not locking the latching mechanism probably got loose and needs the screws re-tightened. If its not closing fully something is blocking it, loose door gasket, tray out too far, item stuck in behind tray.shelf etc.
Jul 29, 2014 | Dishwashers
Kenmore washer stopped dead in mid load.
Check the lid switch. You should hear it click when you open and close the lid. If you don't hear a click, replace the switch.
Oct 18, 2011 | Kenmore 24032\24036 Top Load Washer
My dispenser door sticks. It only comes out about 1/2 inch and then you have to keep opening and closing it that little bit until it comes open all the way. Where is it sticking and how do I fix it?
with the dispenser fully opened, reach in the tray to the retaining clip at the top above the tray. depress clip and fully remove tray. rinse tray to remove dirt and detergent, and with a toothbrush scrub away at interior guide path. use a silicone based lubricant on side rails of the dispenser tray and reinsert, open and close till problem is solved, if problem persists repeat proceedure.
Mar 20, 2011 | LG WM-2277HW Front Load Washer
ADJUST TENSION DOOR
Just below dish loading door there is a panel. Remove screws (if applicable) to find tension adjustment. Turn screw to the left to loosen or opposite lifting door open or closed untill happy with tension. Some washers have no adjustment, I suggest opening door fully and pulling out bottom load tray, loading and then top tray or rack, pushing top in first then bottom rack. Use a glass fry pan cover or fry pan for weight on door while filling soap. Good luck, best regards
Jan 31, 2011 | LG 24 in. LDF 7811 Built-in Dishwasher
When hot water goes in tub waster makes norris kenmore waster top lead model 110 serial # c 80207234
Try adjusting the water tap for the hot water. Open or close a little while it is filling up.
Jan 23, 2011 | Kenmore 23822 Top Load Washer
I have a Kenmore model 1374 (ultrawash quiet guard). Recently I've noticed a lot of dirty residue left on the top rack dishes. I looked in the back of the dishwasher and noticed something with the little...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Dec 26, 2010 | Kenmore 13742 / 13744 / 13749 Built-in...
The dvd is stuck mid way not opening or closing
Try unpluging unit, then plug back in and press open/eject.Also look for a tiny hole on front door used to insert paperclip end, push in this will open tray.
Sep 04, 2009 | Yamaha DV-C6280 DVD Player
Which dishwashere auto resume wash cycle when door is closed?
All the tall tub dishwashers made by Whirlpool (inc. Kenmore and Kithcenaid) must have the start button pressed after adding a dish. If the start button control light is blinking, you must press start. On those models with buttons on the top of the door you must, in addition, close the door within aprox 5 seconds after pushing start. Hope this helps. Ken
May 01, 2009 | KitchenAid Dishwashers
Kenmore 25862 replacing lid switch
What is the model number? Normally, Sears brand washers begin with three digits then a period. As an example (110.25863).
Nov 12, 2008 | Kenmore 25862 Top Load Washer
Water acculation in refridgerator.
I had a similar problem with my old hotpoint frig (top freezer, bottom frig). the defrost cycle would come on and melt the ice, but since the drain plug in the back of the freezer below the coils would eventually freeze up closed due to ice accumulation. It got to the point I had to shut down the whole unit and leave it open for around 8 hours to let it naturally melt the ice in the drain tube. I hear a gurgle sound and then a sound of water flowing, so I knew it was now draining again.
Jun 08, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Dishwashers Logo
49 people viewed this question
Top Kenmore Dishwashers Experts
D. E. Hev
Adam Dower
Adam Dower
Level 1 Expert
Fred Sops
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
