Question about Toshiba Estudio 4511 Color Printer, Copier, Scanner & Fax. 45 Ppm B/w & 11 Color
Won't load black toner - Toshiba Estudio 4511 Color Printer, Copier, Scanner & Fax. 45 Ppm B/w & 11 Color
I have 5 machines Ricoh aficio 3235c showing a massage loading toner and then black toner is empty Althought the toner is full????
This is one possibility, but there are other solutions if this don't work.
The black toner is not set message is displayed. The black toner is not set message is displayed even though the black toner is set.
[Cause]
There is a problem with the BCU lift. The communication with the ID chip is faulty.
[Action]
Update the BCU software version to the latest version.
Apr 01, 2017 | Ricoh Aficio Office Equipment & Supplies
Toner will not loan
Either toner transport pipe cloged or toner pump gone. Only new pump will solve it, but first I would check the rubber pipe that transports the toner. That is most likely
Apr 18, 2014 | Ricoh AFICIO MPC3500 1-SD YLD BLACK TONER...
Kyocera EP470DN - Has Toner - Won't Print
MHHH, it seems as if its empty but it might be that it has humidified. Take out the toner and shake it side ways without compassion, then you slow down and shake it gently a couple of times then install it at the drum. You can also verify if this is true if you take out the toner and watch the roller and see if its loaded with toner. If it looks shinny with almost no toner it what I just exposed. Luck
May 10, 2013 | Kyocera Mita EP-470DN Toner Black EPT-470
PC 921 toner light on. Replaced toner cartridge, light still on: won't function.
You see these machines needs to be kept very well.
1. the machine is not sensoring your toner.
a) need for the machine to be serviced it probably has a lot of spill toner inside.
b) toner empty sensor is not positioned properly.
b) the toner empty sensor is not functioning properly and needs to be changed.
Jul 14, 2011 | Canon PC-921 Black and White Copier
New toner loaded but still shows load toner mssage...
check the toner supply unit, maybe the toner is blocked inside the hopper.
Nov 04, 2010 | Ricoh Aficio MP 1600L Black and White...
I have color laser printer hp it print black paper
Do kinda a half way test by running a test print and purposely stopping it befor the entire paper passes completely over the black toner, open the front panel to expose the toners and pull the black toner, there is kind of a spring loaded flap cover that you need to open manually. Check to see if the drum under the flap is covered with black toner and if so, replace the black toner for it is defective... hope this helps and if so please mark fixya...
Jul 04, 2010 | HP Office Equipment & Supplies
Does not load toner
make sure the cap is not stuck in ther machine from the old toner. very common problem. not the hard black plastic on you unscrew but the clear plastic one the hanlde removes as you close the hopper or handle. also the toner motors do burn up and willnot load toner. you will need a tech. also the dv fears go bad and make it look like a toner problem but you may need a pcu as the toner sensor is in the pcu. good luck
Oct 27, 2009 | Ricoh Office Equipment & Supplies
Blotches of black on both sides of paper
The black slodges are most likely to be caused by the dev unit dropping black toner. Swap the black devs around and vaccum any loose toner out of the machine. The problem with the other one it that the magenta toner pump could have a fault. I would try this before cleaning the toner tubes.
Thanks Jason
Aug 08, 2008 | Ricoh Aficio AP3800C Laser Printer
Toshiba Estudio 4511 Color Printer, Copier, Scanner & Fax. 45 Ppm B/w & 11 Color Logo
42 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
