Question about Bosch 491939 - Drier
What length of screws for Stacking kit WTZ11400
This is the proper kit supplied by dealer
2 Suggested Answers
SOURCE: remove stacking kit from Bosch tumble dryer
I have got the same problem - did you manage to fix it?
Posted on May 14, 2010
How do I detach my Bosch drier from yhe stacking kit as I need to replace the drier
most model have some bolts or screws to keep dryer safe on top of washer
just remove bolts and screws and pull back the dryer
Feb 11, 2015 | Bosch Washer And Dryer Stacking Kit...
How do you unstack a Bosch Axxis WTA dryer from a Bosch Axxis WFL 2050 washer?
You do not state the type of stacking kit installed on your Bosch washer. The installation instructions of one of the stacking kits is found at the site Assemby Instructions Bosch Axxis Stacking Kit /WTZ11310.pdf . First remove the front concealment strip to expose the front of the mounting kit. Gently pry with a wooden tool to prevent damage. Once the it is exposed, there are two clip inserts in front of the dryer feet that must be removed. Once these are removed, you pull or slide the dryer forward to release them from the stacking kit and simply lift the dryer off of the stacking kit and the washer. The stacking kit itself is attached to the washing machine with four screws that must be removed to separate the kit from the washer top. And with that, your dryer and washer are separated!
But after separation there are two additional problems that may be bothersome to you. The first is that you now have mounting holes in the top of the washer that are exposed and the second is that the feet on your dryer may need to be replaced as parts of the feet may have been tossed during installation of the stacking kit and may need to be replaced.
The assembly instructions above show only the basic stacking kit. Some kits included a slide that pulls out to allow for a handy tray but the installation or disassembly is nearly the same.
Sep 13, 2014 | Bosch Axxis WTA 3510 Electric Dryer
I am concerned about srewing the stacking kit to
Maybe, depends on the age of the washer; you should be able to use the screws that come with the stacking kit.... which screw into existing holes in the washer.
Nov 08, 2009 | Samsung Washing Machines
Can the Whirlpool Duets stack?
The simple, short answer is yes, the Whirlpool Duet washer and dryers can be stacked. You'll need to check with the Whirlpool folks to see if you'll need a stacking kit, or if they are ready to go with what you already have.
The key to stacking these Duet laundry pairs, is to have both the washer and dryer model numbers when you contact Whirlpool, so they can provide you with the stacking kit needed to mount the dryer on top of the washer. You can also check the Whirlpool web site to get a good idea of how much space is needed for a stacked set. Here's the link for the space checker, just look under the Guides and Tools on the left side and click on the Laundry Space Sizer to see what's needed.
http://www.whirlpool.com/catalog/category.jsp?cat=115
You can also call Whirlpool at (866) 698-2538 and speak to them about your particular washer and dryer.
Hope you find this Very Helpful and best regards!
Sep 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Remove stacking kit from Bosch tumble dryer
Mar 24, 2009 | Bosch WTA4410US Dryer
Hotpoint Aqualtis Stacking Kit
I Have the same machines and the only option is the Hotpoint stacking kit. Available from Hotpoint - 08448225225. They are selling it half price at the moment for around £70 delivered. I have been assured by Hotpoint this is the only option.
Mar 01, 2009 | Silver King Stacking Kit For SKR27 and...
Stacking the washer and dryer
Been a while since I did one, but as I recall: Two side pieces secure to top of washer with peel off tape and a screw into the top at the very back of the washer's top. Dryer sets on top of washer with back legs sliding into the stack kit side parts. Front rail holds front dryer legs, secured by one screw on each side into stack kit side pieces after dryer is set on top of washer.
Nov 09, 2008 | LG WM-2277HW Front Load Washer
Stacking kenmores
Yes. When I bought my washer and dryer, it came with the stacking kit.
Jul 21, 2008 | Kenmore 44072 Front Load Washer
Stacking Frigidaire dryer on washer using stacking kit 5303937141
i have the two brackets but have no idea how they attach. does the top come off the washer?
Mar 23, 2008 | Bosch Axxis WFL 2060 Front Load Washer
You have to take the top off the washer a put it aside. You no longer need the top. Then you put the two angle brackets on the front top of the washer. this is where the front of the dryer will attach. The back of the washer either has or needs the brackets put on the top (been a long time since I did this). Remove the leveling legs from the dryer. Then lift the dryer and slide it on top of the washer with the back touching the top of the washer and the front about 2 inches higher than the washer top. The back of the dryer slides into the back brackets which are on the top back of the washer. Then lower the front of the dryer and the two "L" brackets on the front top of the washer slide through cracks into the dryer. Pop off the two plastic plugs on the dryer bottom front and place a screw in each one to hold the unit in place. Replace the plastic caps and you are done.
Dec 29, 2007 | Frigidaire FEQ332E Electric Dryer
Bosch 491939 - Drier Logo
87 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
