Question about Amana Refrigerators
I have no water to my ice maker or water dispenser . Replaced the solenoid valve. You can here the valve operating. Where could the line be frozen?
  • Amana Master
  • 5,323 Answers
YOU MAY NOT BE GETTING POWER TO THE VALVE VIA THE ICE MAKER ITSELF NEED TO TEST ICE MAKER FOR VOLTAGE WITH A METER
How to Test the Ice Mold Heater There are two types of ice makers, those in which all of the parts can be individually replaced and those in which some of the parts are clustered together into a control module. To determine which model you have remove the outer face plate. If there is knob, pull it off first, then pry off the face plate with a small screwdriver. Modular units have holes in the module's face plate for test probes. If you see several holes, each marked with a letter, it is a modular unit. It is easier to work on this type of unit by first removing the entireicemakerfrom the freezer compartment. The unit is usually mounted to the freezer case by two or more screws. Remove the bottom screws first. While supporting the ice maker, remove the remaining top screws. Unplug the ice maker from the freezer cabinet if you have not already done so. Along the edge nearest the shutoff arm, a pin protrudes through the mounting plate . The arm pin has a spring under the mounting plate. Reduce the tension on the spring by moving the shutoff arm into the "on" position, down, against the ice maker.
Test the heater for resistance using amultitester. Set the multitester to the ohms setting X1. Touch one probe to each of the two terminals (or wires). The reading should be in the range of 60 to 90 ohms. If you get a significantly different reading, such as zero or infinity, then the mold heater is bad and needs to be replaced. Conduct this test with the refrigerator unplugged. Test the moldheaterfor resistance using amultitester. Set the multitester to the ohms setting X1. Place one probe into the hole labeled "H" and the other probe into the hole labeled "L". The multitester should read in the range of 60 to 90 ohms.
Also be sure to check and test water valve with a meter for continuity and voltage..( a full 120 and nothing less) And a visual inspection for any ice build up or blockage in tubing and flow line. Remember u may get a close circuit reading of continuity however it may still be bad in that it may remain constantly closed and water keeps flowing more than suppose to. Hence chunks of ice build up.
Posted on Apr 10, 2015
My whirlpool side by side ff water dispenser water not recieving water to ice or water dispenser .i think it's frozen
Check to see if there is a filter in the water supply line, if there is it may need service, if no filter then the solenoid valve may be clogged with sand or other material, unless you are handy about this kind of stuff, i suggest you have a professional look at it. have him/her check the supply lines they have been known to break and cause all sorts of trouble.
Dec 21, 2014 | Whirlpool Refrigerators
Tip
The ice maker is not working, but ice water dispenser operates
Try defrosting the fridge completely, this will tell you ifd the icemaker lines are frozen.
The ice maker is actuated by a solenoid.
To check if the lines are frozen , defrost the unit.
Check the water valve connected to the hose at the back of the unit.
The ice maker solenoid is tested by reading the ohms on solenoid with a multimeter.
Other faults can concern the impeller pump that is sending water to ice maker, that is tested by energizing the pump.
to disassemble the icemaker click the diagram below:
Click on picture above to open diagram.
Here more diagrams:
CABINET PARTS
CONTROL
More diagrams for your model.
on Dec 03, 2009 | KitchenAid KSRG25FKSS Side by Side...
Amana refrigerator ice maker
You are on the right track since the solenoids control the amount of water reaching the ice maker and the water tap. Sometimes over a period of time the plunger or moving part of the solenoid just gets stuck and a good cleaning will restore it to proper operation.
Mar 16, 2017 | Refrigerators
CAN13 ice maker does not call for water.
Ice maker is bad if not sending power to valve.
Oct 14, 2017 | GE Refrigerators
I have a Jenn Air JRSD209W refrigerator. The ice maker stopped making ice. So far I have replaced the water supply solenoid and the ice maker unit. The unit is cycling mechanically, but no water is...
Check the water line that goes from the water fill valve to the ice maker to see if it's frozen shut.
You can remove the ice maker water line from the water fill valve and see if you can blow air through it. If you can't blow through it then its frozen shut.
Sometimes they freeze shut if the water inlet valve was seeping a little water past it when it was off.
If that is the case you have already replaced it so after thawing the water line out you should be good to go.
Aug 03, 2011 | Jenn-Air Refrigerators
Ice maker not making ice water dispenser works well
There are 2 solenoids, one controls the water dispenser the other controls the ice maker water supply. Follow the tubing down the back of the refrigerator to find the ice maker solenoid. If the line is frozen between the back of the refrigerator and the ice maker it won't make ice either. If the line is frozen you need to check to see if the solenoid is leaking, this allows a trickle of water to continously flow through the lina and freeze.
Jan 08, 2011 | Refrigerators
I have a GE Refriderator about 3 years old. Recently the water dispenser stopped working, and the ice maker stopped as well. The ice maker seems to freeze up as it dispenses water in the tray to make ice....
Are you having any cooling problems whatsoever, anywhere? Is there any area in the unit that you dont put food for cooling reasons? if cooling is fine, check the water pressure as it comes into the refrigerator, you wil have to disconnect the water line at the solenoid valve behind the fridge. If pressure is good, pour 4-8 oz of water into ice maker, does it eject those cubes within 24 hours? then replace your water valve(s) One assembly houses a solenoid for both the ice maker and the water dispenser, both solenoids are bad.
If you have further questions, visit my website and send me a question. www.FixMyFridge.net
Mar 16, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Whirlpool gold side by side ice maker not making ice... have replaced the ice maker... still not working, no water to unit... not frozen up... water dispenser is working fine
You have a dual solenoid water valve. Blue for the water and red for the ice-maker. It located in the rear lower part of the frig. The water solenoid needs replacing that will solve your problem. BB
Jan 21, 2010 | Refrigerators
Water dispenser and ice maker don't work
You have a bad water filter housing. Be sure to turn of the water to the refrigerator before replacing this part. Replace the filter at the same time.
Apr 30, 2017 | Whirlpool GS6NBEXR Side by Side...
Water dispenser fine but ice maker not working
Hi. A good way to check the ice maker water solenoid valve is to swith the wire lead from the dispenser water solenoid valve to the ice maker water solenoid valve. Now push the water dispenser lever and water should come out your ice maker fill tube. If not, either the fill tube is frozen or the ice maker water solenoid valve is bad. Take the 1/4 inch tube that runs up the back of your freezer off at the ice maker water solenoid valve and blow thru it. If you can't, the tube is frozen. If you can, the valve is bad. Good luck, Mack
Jan 31, 2008 | Refrigerators
Refrigerators Logo
52 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
