Question about Ariens 42" 19HP Lawn Tractor
Engine will turn over but won't start checked carburator and fuel filter and they are ok are there any saftey switches that would prevent engine from starting?
    Habit-Forming:
  • 31 Answers
Since engine is turning over by using the ignition switch it should not be a safety switch problem,
Sounds to me you might have a spark / coil problem
If you have spark then fuel shutoff selonoid on bottom of carb bowl might be bad and not opening.
which in that case I unplug from harness and unscrew from carb bowl , pull out center pin if connected cut off if not throw it in the trash when I do this I always put a shut off valve in the gas line.
You will need a very thin open end wrench to unscrew selonoid from bittom of carb.
Posted on Apr 04, 2015
  • Ariens Master
  • 1,169 Answers
As for safety switches there is one switch could prevent the ignition system from firing and that is the operator present seat switch. This all depends on electrical setup for your equipment.
1991 Grand Marquis LS turned off on me I replaced
You need to determine what shuts off. With a volt meter check for power at the fuel pump. Try starting and see if power is present.. If power is ok. You will need to test the ignition module for power, ground and output signal.
Oct 09, 2014 | Cars & Trucks
Fuel is not getting from carburator to the spark plug
You don't say what engine it is. First does the spark plug smell of petrol? Does it spark? Take it out and hold it by the plastic cap against the engine casing and turn the engine over (with ignition on) - you should see it spark. If not, check your ignition system.
If it sparks: check compression, a thumb over the plug hole and you should feel the pressure as you turn the engine over.
If that's OK and its a four stroke engine, you need to check that the valves are opening OK. Take off the rocker covers and turn the engine over. If that's OK I'm afraid I'm out of ideas!
Jan 07, 2014 | Garden
Car turns over but won't start
Which engine?
I would first check the following:
Are you getting spark at the spark plugs? If not, check the ignition coil or coil pack.
Are you getting fuel to the engine? Make sure there is fuel in the tank, and that the fuel pump is working.
Check all your fuses to make sure they are OK. A blown fuse to any critical engine component (ECM, ignition, fuel supply) will prevent a vehicle from starting or running.
Feb 13, 2012 | 1997 Ford Escort
My 2004 ford expedition was runing perfect when I got home and parked it in the driveway few minutes later I tred to start it and it looked like it was running out of gas started to shake and the engine...
Hello You will have to reset your fuel pump switch located passenger side right foot kick panel when you press it it should stay down if this does not work your probably looking at a fuel pump not working.
Jan 06, 2011 | 2004 Ford Expedition
Gas not getting to the carburator. Starter turns
Check all of the fuel lines very carefully for breaks or cracks in the fuel lines, especially between the fuel tank and the fuel pump.
If the fuel lines are all in good condition then you can safely assume that the problem is in the fuel pump and you will need to replace it. (If the fuel pump is in really bad shape the engine oil on the end of the engine oil dip-stick will smell like fuel)
May 13, 2010 | 1986 Dodge D150
Engine goes off when changing gears from P to D or
check engine light is on? if yes, You need an OBD scanner to dianose the problem. if no, its a mechanical problem. 1st, check if their is a vacuum leaks using the carburator cleaner to spray all over the emission, carburator, the vacuum lines if the idle going up you found the leak, now if still don't work, check if the fuel injector if not failing, check also the fuel filter and cracks on the exchaust manifold.
May 04, 2010 | 1999 Volkswagen Golf
I have a 1997 GMC Sierra. The engine is a 5.7 vortex. Is there a fuel filter in the carburator?
This year does not have a carburator,it is fuel injected.The filter is on the inner frame rail on the left side.Make sure and relieve the fuel pressure before removing the filter or it will spray fuel all over.You can do this by removing the fuel pump fuse or relay and start the vehicle and let it run tilit dies.Then turn off the key and replace the filter.You will still get some fuel coming out but it won`t be pressurized.Hope this helps.Good luck.
Apr 05, 2010 | 1997 GMC Sierra
My 2000 Jimmy won't start, I can hear the fuel pump running and then shutting off before I attempt to start the engine. I also hear it running while I attemp to start the engine. The engine won't start...
The pump is working normally the reason it stops before you start the engine is it has built up enough preasure and cuts out. When you turn over the engine it starts up again as the preasure goes down when the carburator open's. The pump only helps the fuel from the tank. It seem's like dirt in your carburator. The reason it wont start after 3 minutes is the excess petrol in the carburator has evaporated hence need to pour more in. Check all pipes filters and carburator for dirt.
Aug 06, 2009 | 2000 GMC Jimmy
RAN OUT OF GAS AND I CAN'T GET IT TO START AGAIN for a 2006 Lexus 250 is keyless start
have you primed the gas convertor?
there is a button on the side of it
Mar 14, 2009 | 2006 Lexus Is 300
Ariens 42" 19HP Lawn Tractor Logo
199 people viewed this question
Top Ariens Garden Experts
Phil Walker
Phil Walker
Matt Olenzek
Matt Olenzek
enb54
Level 1 Expert
Are you an Ariens Garden Expert? Answer questions, earn points and help others
