Question about Olivetti Office Equipment & Supplies
How do I fix a jammed ribbon guide on a Olivetti Letter 32? It won't move up when I hit a key.
  • Olivetti Master
  • 3,594 Answers
Before you do anything rash check the ribbon color lever if it is in the white position the ribbon won't lift.
DickyO
Posted on Apr 10, 2015
SOURCE: typing
Something else you might check, I was having same problem. Make sure the Daisy Wheel Lock Lever (check the description that comes in the guide) is locked in place, i.e., push it forward to lock. It is the black thing that sticks up on the right inside the correction tape. I did this and words started appearing. Hope it helps.
Posted on Feb 17, 2009
SOURCE: olivetti lettera 22 replacement black/red ribbon ?
i just picked up an olivetti lettera 22 at the local goodwill for $5. it has a ribbon but def. needs replacement. i was on a site that sells them in a 3-pack for $24.00. they fit all standard and portables by olivetti apparently. here it is:
http://mytypewriter.com/b53-olivettistandardandportabletypewriter3pack.aspx
Posted on Sep 08, 2009
JayBlair
  • 328 Answers
SOURCE: The Caps Lock/Shift key jammed on my Olivetti Lettera 32
Sounds like the shift key lock spring is broken or missing. Look ont he key and hook it up or find a tiny spring to install.
Posted on Dec 30, 2009
  • 3594 Answers
SOURCE: my typewriter carriage doesn't move
Many of these older portables have a carriage lock, usually just below the carriage on the L. or R.
DickyO
Posted on Jun 10, 2010
chuckt528
  • 73 Answers
SOURCE: HI! MY OLIVETTI LETTERA 32
Is it possible the margins are set closely together? There may be a carriage lock on the bottom l or r side of the carriage.
Posted on Dec 25, 2010
How to unlock the shift lock?
Try without ribbon and L/O tape, check for bent or broken spokes on print wheel.
DickyO
Sep 09, 2012 | Olivetti refurbished etv2700 typewriter...
It's stuck in place and won't move either left or right. When I hit a key it types that letter, but the paper doesn't move to the next space
If it is stuck in the middle of the page it probably has a carriage lock usually just below the carriage on the R. or L. side.
DickyO
Oct 12, 2011 | Olivetti Lettera 35 L Typewriter
I have an Olivetti Lettera 32. I put a brand new ribbon in it and when I type, the letters are coming up too light on the paper. How do I fix this? What needs to be done?
First thing is to be sure the ribbon is feeding, watch while you type. if not you may have a universal spool ribbon that isn't quite that universal. Wind the ribbon onto your old spools.
DickyO
Jun 06, 2011 | Olivetti Lettera 35 L Typewriter
WHEN TYPING LETTER BAR HITS ABOVE RIBBON
There will be a lever on one side of the keyboard that moves thru Black, Red, White. Select black.
Dec 04, 2010 | Olivetti MS25 Typewriter
Dec 13, 2009 | Office Equipment & Supplies
Olivetti Lettera 32 typwritter carriage will not move?
There is a lever in front of the right knob that is used to lock the carriage.
Aug 31, 2009 | Olivetti Lettera 35 L Typewriter
Letters aren't striking ribbon
Get some WD40 and spray it on thw segment (the place where the type bars are swung) then everywhere the key mechinism pivots.
DickyO
Apr 04, 2009 | Olivetti Linea 198 Typewriter
Wheelwriter 6
You may need a ribbon motor or motor board, however on the older wheelwriters sometimes the gear mesh gets sloppy and gears jam tooth for tooth. Try moving the ribbon lift gear/cam on rt. side of the carrier by hand with the machine off if it won't move that's the trouble. Wiggle it back and forth and it may free up.
Dec 20, 2007 | Lexmark Wheelwriter 6 Series II Typewriter
172 people viewed this question
Top Olivetti Office Equipment & Supplies Experts
James Cagle
James Cagle
Alun Cox
Are you an Olivetti Office Equipment and Supply Expert? Answer questions, earn points and help others
