Question about Husqvarna Lawn Tractor - 54in. Deck, 26 HP, Model# LGT2654
Husqvarna will not start,starter engages,but will not crank motor,
    New Friend:
  • 38 Answers
First thing u need to check is Spark. Its best to disconnect the ground wire going to coil then check for Spark. Then if u have Spark
try starter fluid in the carb. If it start after the shot of fluid and dies then ur solenoid on the carb bowl is bad ( stuck not letting gas get in to motor. Then after all that is good and still no start do the Valve check set them to spec
Posted on Apr 05, 2015
  • Husqvarna Master
  • 1,169 Answers
If it is an OHV reset your valve clearances to spec.
My 2004 Accent wont start. It started fine Tuesday, Wednesday morning it would not start for nothing. I tried it Thursday afternoon and it started fine. This is the second time it has done this.
Does the motor crank (starter engaged and turning the motor)? If it does not crank, do you hear the solenoid clicking (engaging the starter gear into the flywheel teeth)?
Nov 25, 2016 | Hyundai Motor 2004 Accent
My 2000 S10 will not crank,it has new battery & alternator,when the ignition is turned on I get all dash lights but won't turn over. The light around the odometer dims when I engage the key.
You need to test the start wire at the starter when the key is turned to crank position to make sure it has power during cranking. Sometimes tapping on the starter motor with a hammer while cranking will engage a bad starter motor
Apr 11, 2015 | Cars & Trucks
I have a 2000 toyota celica gts and it wont start or turn over the starter will make like a whinning sound but its not trying to crank the engine maybe its the starter but just in case its not anybody have...
Likely either the starter or solenoid. Solenoid is a combination of relay and actuator, pushing the starter's gear into engagement with your flywheel.
Oct 28, 2014 | Cars & Trucks
Starter wont engage after replacing dead battery
Check power to starter motor solenoid, solenoid operation and starter motor voltage during cranking. If the starter motor is receiving power from the solenoid, but isn't cranking, then replace the starter motor.
Also check the condition of battery terminals, wiring and connections. Also check the earth wire from the body to the engine.
Nov 12, 2012 | Cars & Trucks
My van will not turn over,i thought it was the starter cause it wasnt starting it will turn over but not start.so i put a new battery in it cause i was told the old one wasnt kicking out enough amps.and it...
If the starter motor spins and does not engage, thump the case of the starter motor with a piece of 4 x 2 or a lump hammer handle. If that fixes it, the fix will be temporary. Take the motor off and lubricate the bearings, paying attention to the dog wheel slider.
Oct 01, 2017 | 1992 GMC Safari
Husqvarna Z6127 won't start after running 30 minutes.
If the starter motor is spinning, the problem is probably the starter motor solenoid. It is basicly an electric piston mounted on the starter that engages the starter motor pinion gear to the flywheel.
Jul 31, 2009 | Husqvarna Zero Turn Mower Z5426
92 Cavalier. Starter Problems
could be a loose wire on the starter , check your connections
Jun 27, 2009 | 1992 Chevrolet Cavalier
Husqvarna Lawn Tractor - 54in. Deck, 26 HP, Model# LGT2654 Logo
107 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
