Question about Cell Phones
How can i get a cellphone manual?
Trying to get best procedure to apply fastboot&recovery mode
  • 1,205 Answers
Dan
try talking to the people who sold the phone to you or even better go to this page Free User Manuals and Owners Guides ManualsOnline com
best of luck
kolbrun
Posted on Apr 04, 2015
DNX FASTBOOT MODE
Fastboot Mode on Android from Kingo, which offers the best one-click Android root software for free.
Here's the link: https://www.kingoapp.com/help/fastboot-mode.htm
Aug 07, 2017 | Cell Phones
Asus zenpad10 tablet stuck in fastboot mode
KEEP HOLDING THE POWER BUTTON UNTIL YOUR PHONES SWITCHES OFF OR PULL OUT THE BATTERY DIRECTLY(If Required) to exit the FAST BOOT MODE and then start your phone normally by pressing only the power button.
Also in case you were trying to enter the recovery mode to wipe cache or hard reset then keep holding the power button and volume DOWN button until you get vibration and release the power button and keep holding the volume DOWN button to enter RECOVERY.
Jun 16, 2017 | ASUS Tablets & eReaders
My Hisense U989 froze on the screen then I took out the battery now it doesn't want to power on. What should I do?
My hisense u989 wont turn on I tried to reset it but instead of showing reset setting it shows recovery mode fastboot mode and normal mode. please help
Apr 09, 2017 | Cell Phones
Rca tablet how do i get out of fastboot mode
You will be stuck in fastboot if you have failed to flash an img file. You will have to boot a boot.img file using fastboot then download the last update to get your tablet back to normal.
Download the following file onto your computer...
K1_A301_03_03_110829_US.zip
Then unzip on the computer. You will see a file named "boot.img". Make sure your tablet is connected to the computer and you have the fastboot binary. Then run the following command in the directory you just unzipped the file
fastboot boot boot.img
This will allow you to boot up your tablet but the bootloader will STILL be stuck in fastboot. Therefore you will have to update your system. Download the same file above into the Download directory of your tablet. Rename it to update.zip. Dowload the following XML file...
K1_A301_03_03_110829_US.xml
and rename it to update.xml (NOTE: the system file manager won't let you change the extension so just rename to "update". Power off the tablet. Then hold down the Volume + key and hold down power button until it comes on. That will boot the system into recovery and install the update. In a few minutes you will be restored and your tablet will work normally. NOTE: YOU MAY LOSE YOUR DATA and may have to reinstall your apps.
If your boot partition isn't a mess like mine was, you may be able to just flash the system partition from the above zip file by using...
fastboot flash system system.img
fastboot reboot
The key is that a fastboot flash must be successful in order for your device to boot normally.
Source: Lenovo
Nov 13, 2016 | Tablets & eReaders
Tablet says, Entering DNX Mode: waiting for Fastboot command...
I would book mark these links. Below.
Copied from :
What is Fastboot for?
While in fastboot, you can modify the file system images from a computer over a USB connection. Fastboot mode can start on your device even before Android loads, even under the circumstance when Android isn't installed at all. And because of that, fastboot mode is useful for quick-updating the firmware, without having to use a recovery mode. In fact, it's the preferred way to initially install the recovery image. Once you set up, you boot to your phone to fastboot and you can flash image files to the internal memory. Flashing a custom recovery like ClockworkMod is a popular use case. The images you flash don't need to be signed with a particular key, and thus you should use care when flashing. It can also be used for developer operations. Things like erasing partitions and overriding kernel command line options can be done. And all this features make the tool very useful for developing hardware and software solutions, like unlocking the Bootloader of Google' Nexus.
https://www.kingoapp.com/help/fastboot-mode.htm http://forums.androidcentral.com/verizon-droid-dna/252896-how-do-i-turn-off-fast-boot-mode.html
May 11, 2016 | Tablets & eReaders
WHAT DOES FASTBOOT MODE MEAN?
Fastboot is associated when you root Android. Here's a site that helps explain it better in detail: The Easiest Way to Install Android ADB and Fastboot Tools on Any OS
Hope this helps you get a better understanding of what it is.
Jan 17, 2016 | Tablets & eReaders
I got a Motorola Moto E (2nd Gen) from a friend her grandfather that passed away gave it to her. and it got factor reset so now when I power on the phone it ask for the previous email account that was
Found this info to do a hard reset on Android Geek.
Apply the Hard Reset using Hardware buttons
  1. First of all, turn off your phone (press power button and select "power off" or keep pressing the power key for 15 seconds).
  2. Enter fastboot mode on your Moto E.
  3. From fastboot mode use volume down / up buttons in order to scroll up and down.
  4. Highlight recovery option and select by pressing the power button once.
  5. Good; now from recovery select "wipe data factory reset".
  6. In addition you can also choose "Wipe cache partition"; from main menu of recovery pick "advanced" and then select "wipe dalvick cache".
  7. Done.
Nov 05, 2015 | Motorola Cell Phones
Vtouch v705 is locked how I can reset the password
I read an article on how to reset the Vtouch V705 and although I have not performed this operation my self, you may want to investigate the following and see if it something you can work with that may help solve your issue. If this does not work or apply please reply and I will continue to look for possible solutions to solve your problem. Here is the quote on what you might try (if this applies) to possibly solve your issue.
"works well on chines android tablets! 1.Download the android tool. https://www.mediafire.com/?7se8s62sj1y5fpo2.extract and save to any location on computer2.open extracted folder and open software use the appropriate number for whatever job you would like to do.number 4 to reset Gmail lock, pattern lock, or password.when device reboots you may need to restart it a second time that's it all done. subscribe, like, share, comment.User Manual for Android Multi Tools v1.02bfirst device must install correct driver This program works with any Android device .Requires root and enable Debug mode or fast boot mode.choice 1-6,S,H can work with Debug Mode only.choice 7-9 can work with Fastboot Mode only.choice detail1.Check Device for check connection of device to PC.2.Reset Face/PIN Lock for reset face lock on android 4.1.x and PIN lock without lost data.3.Reset Face/Gesture Lock for reset face lock on android 4.1.x and Gesture lock without lost data. After device reboot Then you can draw anything for unlock.don't forget close lock in security menu4.Reset GMail for reset gmail login after try many time wrong unlock 5.Wipe Data for reset all data to factory setting.6.Reboot for reboot device to normal mode or exit from adb shell.7.Check Device On Fastboot Mode for check connection of device to on FastBoot mode.8.Wipe Data / Cache On Fastboot Mode for erase user datat and cache on Fastboot Mode to resolve freeze,stuk on boot logo or slow down device. That is often found in the CPU Spreadtrum SC6280/SC8810.9.Exit Fastboot Mode for reboot your PC or exit FastBoot.0.Go To Command Promt for entering DOS promt.you can use command in this soft folder And can return to the main program by type exitS.Software Info for info CPU inside,firmware version and etc.H.Hardware Info for determine the IC number of Gsensor,touch screen,Camera,WIFI and moreR.Report / Contact Me links to the specific problems of the Phase I program and a bookmark.D.Driver Download for loading the drivers in case you do not have the driver installed in your PC - See more at: http://celularmovil.info/video/view?videocode=okEyk5LrNDc&startpage=6#sthash.j9wiRuoL.dpuf
Please let me know if this works out or if you have any additional comments or questions. Like I said before I have not actually used this method myself so PLEASE be cautious when downloading and installing any type of software. Thank You!!
Nov 20, 2014 | Computers & Internet
How do i factory reset my zte concord v768?
Just try with the below steps to hardreset your phone:-
1.Switch off the handset, and press the power-key and volume-down key at the same time until get recovery mode;
2.Press home key get into next interface;
3.There will be four choices:reboot system now;apply update from sdcard;wipe data/factory reset;wipe cache partition;
4.Use "Vol+" and "Vol-" to move the cursor up and down;
5.Move cursor to "wipe data/factory reset," press "menu" key to select it.
6.Then use vol- key to move the cursor to " yes-delete all user data" , press menu key to select it.
7.Then choose reboot system now ,you phone will reboot itself.
Mar 24, 2013 | ZTE Cell Phones
Cell Phones Logo
37 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
