Connecting leads to the back of a su 2800 properly
    New Friend:
  • 151 Answers
You should Google and download the manual. All info is there.
Posted on Aug 04, 2015
Why am i not getting any sound to the speaers of my boss chaos 2800 watts amp?
Most common problem is cable connection. Wiggle each lead, positive, negative in turn at amp. while playing. I assume you have checked that you haven't inadvertently muted the system.
Mar 18, 2017 | Boss Car Audio & Video
How do I change the power switch on my Technics SU 2800 Amp the power switch does not hold on works if held manually but relkeasing the button makes the power stop
First of all, you need to find the switch. The Technics of the past, is long out of business. Actually, Technics was a priority brand of Panasonic.
Aug 05, 2015 | Technics Audio Players & Recorders
Why does samsung sf 2800 page come out black when copying a document?
if it receives faxes fine then its
likely the ccd reader input is disconnected . broken lead.
the sensor is above the slot where you insert the to be scanned sheet.
you'll have to open the case cover to find out.
Aug 03, 2014 | Samsung Office Equipment & Supplies
Pink vertical line in center of screen th-42pz80u
it could be either the SD or SU boards going. check the cable connections and make sure the ribbon cables are seated properly.
Feb 24, 2013 | Panasonic Viera TH-50PZ80U Plasma TV
Hi I just got a Technics SU V2 amp and can't get sound from the speakers. What size speakers would suit this amp? What is the correct method to connect the speaker leads to the back of this amp,...
Being a 500W amplifier, you need to connect speakers with 300W each. The correct method to connect speakers is red terminal of speaker should be connected to red terminal of amplifier & black to black. The left side to left side speaker & right to right speaker. There may be main & remote terminals. Main speakers are the speakers at local place of the amplifier & remote for remotely placed speakers. I do have Technics SU-V85A which is somewhat similar. Enjoy! A nice piece to listen.
Oct 22, 2011 | Technics SUV500 2-Channel Amplifier
FRS 2800 Mackie Amplifier Connection Problems
that sounds like an internal connection problem, try getting inside the unit to where the internal wiring is connected, if you have signal coming through well thats a big plus, see if there are any loose wires or if the internal connection is damaged, would probably pay to replace the complete terminal, should be able to pick up XLR connections fairly easily from any electronic spare part dealer, trouble with this type of gear is that the connector is continually being used, so over time they do wear out or suffer damage
May 30, 2010 | Mackie FRS 2800 Amplifier
I had the 7 blinking lights problem after tv shut
7 blinking Defective Board (possibility)
SC, SU, SD, P board (SC,SU,SD>D,P).
Connect
the connectors SC2(*2),
and SC20 to the SC board. Remove the SU board. Turn the TV on. Does the TV power up
and stay on IF YES REPLACED SU BOARD IF ON
Install
the SU board and
Remove the SD board. Turn the TV on. Does
it power up
and stay on? IF YES REPLACED SD BOARD
Feb 03, 2010 | Panasonic TH-42PX75U 42 in. Plasma...
Technics su-a808 amp & sh-ge70 graphic equaliser.
connect your media source(dvd-cd player)to equalizer in-connect equalizer out to amplifier line in-or aux in-connect amplifier out to your loudspeaker.
Jun 24, 2008 | Audio Players & Recorders
The brother Intellifax 2800 intercepts other faxes
Make sure that the proper phone number is installed in the fax.Also that they are not sharing the same common line.
Oct 17, 2007 | Brother IntelliFAX 2800 Laser Fax
106 people viewed this question
 Grubhead
Grubhead
