How to connect cables in back - Audio Players & Recorders
    Problem Solver:
  • 29 Answers
The simplest way is often to turn the rack or stand around.
If that is not possible, I sometimes use a mirror and a flashlight. You could also use a trouble-light in the sitting in the right spot so that you have one hand for the mirror, and the other for the cable.
Another useful item is the little led light with the band that holds the light on your forehead. This is useful in a surprising number of situations.
Posted on May 04, 2015
How do i connect my cable box to my tv
Connect the coaxial "Cable In" cable to the "Cable In" port on the back of your TV cable receiver box. Make sure your receiver box is not plugged in yet. 2 Take the TV audio/visual cable, and connect the red, blue and green ends to the corresponding color "Cable Out" ports on the back of your cable receiver.3 Take the other ends and plug them in to the red, blue and green ports under "V1" on the back of your TV.4 Take the audio cord with the red and white ends, and connect them to the corresponding color ports of "Audio Out" on the back of your cable receiver; then, connect the other ends to the corresponding color "Audio In" ports on the back of your TV.5 Turn on the power of your TV cable receiver box first. Allow it to run through the boot sequence. When you see the time appear on the front of the cable box, you may turn on the television and check your signal.
  • Oct 13, 2011 | Televison & Video
    Tip
    How to connect and record on a VCR when you have a Digital Cable Box.
    Do you want to still be able to use that trusty ol' VCR to be able to record your TV shows but can't seem to do so now that you have gotten a Cable Box?
    Well here are some simple tips on how to connect all the components and not compromise the quality of the incoming signal of the cable signal feed.
    First here are the cables you will need.
    3 sections of Coax cable (preferably RG-6 quality)
    or
    2 sections of Coax cable (preferably RG-6 quality)
    1 RCA cable (Yellow/Red/White)
    Now here is how you will need to hook up the cables properly.
    1) Connect one Coax cable to the incoming cable signal feed. Usually a screw on connector on the wall or line coming up through the floor.
    Now connect the other end of this cable to the "Cable in" or "Input" located on the Cable box.
    2) Now, connect one end of another Coax Cable to the "TO TV" or "OUTPUT" on the back of the Cable Box. Now connect the other end of this cable to the "CABLE/ANT IN" or "INPUT" connection on the back of the VCR.
    3) Now, connect the last coax line from the "TO TV" or "OUTPUT" on the back of the VCR. Now connect the other end of this cable to the "Cable IN" on the back of the TV.
    ***** ALTERNATIVE OPTION FOR THIS FINAL CONNECTION******
    Using the RCA cable connect to the "VIDEO OUT" RCA connections on the back of the VCR and connect the other end of this cable to the "VIDEO IN" on the back of the TV.
    Now this is how you will need to set your VCR and Cable box to make your recording.
    1) Tune your VCR to Channel 3 or set your timer to record Channel 3. (The actual channel you are going to be recording is controlled by the Cable Box)
    2) Tune your cable box to the channel you wish to record.
    *** Note: Some cable boxes have an auto tune feature that will tune your cable box to a channel while you gone. Contact your cable provider to see if this is available on the model that you have***
    on Jan 09, 2010 | Televison & Video
    Where is my cable output on my Philips TV 32PF7321D/37. How do I get cable on my TV I cannot find a cable output! please help
    your output cable is in the back of your t.v. there is a color designated on its hole then you have to buy a a cable in any electronic shop like components cable or hdmi cable try to read the back panel of your tv
    Mar 10, 2011 | Philips 32PF7421D 32 in. LCD HDTV
    I'm having trouble connecting my emachine to a cable modem.
    Turn off the computer before you begin making connections. Make sure the cable modem is up and running with your service before you attempt to make the computer connection.
  • 2 Connect the coaxial cable from the wall outlet into the back of the cable modem where it is marked "Cable" and has the male coaxial connection. Use an extension coaxial cable if necessary to reach the modem.
  • 3 Connect the CAT 5 networking cable from the cable modem where it is marked "PC" (or something similar) and connect the other end into the back of your computer where the networking card is. These connections are RJ-45 connections that look like oversized telephone jacks. If you also have telephone service through your cable provider, you will want to connect the telephone line into the port on the back of the cable modem marked "Telephone."
  • 4 Connect the power cord into the back of the cable modem and plug it into a power strip with power surge protection. The modem should power on by itself once it is plugged in. It will cycle through a power on self test and then make the connection to your cable Internet provider. Once the lights indicating power and cable are green, you are ready for Step 5. It could take several minutes for the modem to connect to your service provider.
  • 5 Turn on the computer and test out your Internet connection. Should your computer still have a problem connecting to the web you may need to reset your cable modem. You will find a small recessed button the size of the head of a ballpoint pen either on the back or front of the modem. This button will be marked "Reset." Pushing it once will allow the modem to reboot and reset all its connections. Turn off the computer before resetting the modem to allow the computer to flush all the networking connections out of its memory as well.
  • If the power goes out and your connection is not restored when it comes back on, always reboot the devices in this order: cable modem first, computer second. Keep the cable modem where it can get proper ventilation. Call your cable Internet provider if you get frequent interruptions to your cable Internet service and rebooting the modem does not solve the problem.
    Jan 21, 2011 | E-Machines eMachines Desktop PC
    Setup belkin wireless network
    1.Connect a Cat5 cable into the Ethernet port on the back of your cable or DSL modem. Plug the other end of the cable into the "Connect to Modem Internet/WAN" port on the back of the Belkin Router.
    2.Connect a Cat5 cable into the "Ethernet" port on the back of any desktop or stationary computers and then plug the other end of the cable into one of the LAN ports on the back of the Belkin Router. Start with port one and work your way up with subsequent computer connections.
    3.Turn the Belkin Router on by plugging the router into a power outlet. Allow 30 seconds for the router to fully boot up. All computers tethered to the modem via a Cat5 cable have access to the Internet.
    4.Open the Wi-Fi Wizard on your laptop and turn on the Wi-Fi antenna. Once turned on, the Wizard finds all network connections in your area. Connect to your network to establish an Internet connection. Complete this step for each computer not tethered to the Belkin Router with a Cat5 cable.
    Thanks for using Fixya
    Proton
    Oct 04, 2010 | Computers & Internet
    Where is the HD so that I can take it out on the HP 873n?
    Turn your computer off.
    Disconnect the AC power-cable.
    Remove the side-panel.
    Look for two wide-and-flat "ribbon" cables connected to the motherboard. One cable will connect to the "back" of your CD/DVD drive. The other cable will connect to the "back' of your disk-drive.
    If you don't see any such "ribbon" cables, look for two wide-as-your-pinky-finger's-nail cables connected to the motherboard. One cable will connect to the "back" of your CD/DVD drive. The other cable will connect to the "back' of your disk-drive.
    There also may be a "ribbon" cable between the motherboard and the "back" of the 3.5" diskette drive; such a cable will have a "twist" in some of the leads in the ribbon-cable. Obviously, your diskette-drive is _NOT_ your hard-drive.
    May 14, 2010 | HP Media Center PC 873n (P9875A#ABA) PC...
    I DON'T KNOW WHERE TO PUT WHAT WIRE TO CONNECT 2 COMPUTERS
    You connect the phone line to the router, then you connect ONE PC to the router via an Ethernet cable and configure router, after that you can remove that Ethernet connection and connect wirelessly.
    Feb 10, 2010 | D-Link AirPlus DI-524 Wireless Router
    Go video model dv-241 hook up to make vhs to work
    There are a fews ways of accomplishing this.
    It sounds like you may reversed your cable connections. Lets try these steps.
    On the back of your cable box and your Go video VCR/DVD there are two coxial connections an (OUT) and an (IN):
    Step 1. Connect the coxial cable from Comcast to the (IN) connection on the back of the cable box.
    Step 2. Connect one end of a spare coxial cable to the (OUT) connection on the back of the cable box.
    Step 3. Connect the other end to the (IN) connection on the back of your GO Video box..
    Step 4. Connect one end of another spare coxial cable to the (OUT) connection on the back of your Go Video Box.
    Step 5. Connect the other end of the Coxial cable to the back of your TV.
    I hope that you find this solution helpful.
    Feb 10, 2009 | GoVideo Go Video DVD/VCR Combo
    How do i connect my basic cable to my dvd/vcr player?
    Is there on the back that say in then another out to tv
    that the way it use to be I hope this works
    Feb 08, 2009 | Philips Magnavox DVD/VCR Dual Player
    I need to know how to run my ps3 thru the optical wire to my hdtv
    Before you start ensure that you read the TV instruction manual to know which resolution supports it. Do not switch on the TV and your console
    You can connect your Playstation 3 to your TV in three different methods:
    1. Connecting with an AV cable
    2. Connecting with an HDMI cable
    3. Connecting with an Optical Cable
    Connecting with an AV Cable:
    1. You are supplied with a Composite AV cable which would typically look like the below image
    2. Connect the AV Multi Out Connector to the socket on the back of your PS3 Console.
    3. Match the colors of the Jacks with the connectors on the TV which says "Video in".
    Connecting with an HDMI Cable:
    HDMI cable is not supplied with the PS3. You need to purchase it seperately. This cable would enhance the audio-video quality of your TV.
    1. Just connect one end of the connector to the HDMI OUT connector socket on the back of the console
    2. Connect the other end to the socket on the back of your TV which says HDMI IN.
    Connecting with an Optical cable:
    You need to purchase an Optical cable if you wish to connect your PS3 console through a digital audio device (Home theater, AV receiver etc.,). You need to connect Video ouput seperately with a help of Video output cable (HDMI, AV Cable etc.,)
    1. Connect one end of the optical cable to "Audio Out" socket on the console
    2. Connect the other end to the audio receiver.
    Note: You can also connect your console to the Internet to use the Playstation 3 internet capabilities. Here's how you do it:
    The Playstation 3 only supports 10BASE-T, 100BASE-TX and 1000BASE-T type networks. It needs a High speed internet connection. Do not connect it to a standard telephone connection or cables that are not supported. It might cause a malfunction or damage to the system.
    Dec 11, 2008 | Computers & Internet
    198 people viewed this question
     Grubhead
    Grubhead
