Question about Huawei Cell Phones
Phone needs fastboot&recovery mode applied,how do i go into hisuite?if i follow the pressing power button &volume up simultaneouslymethod,do i need to be plugged into PC USB?
SOURCE: my razr phone shows a blue screen with bootloader usb init at the bottom. I have tried pressing the power button at the same time as the # and * buttons and holding them down, but it doesn't work. Whe
you used a regular usb cored. i had the same problem you have to send ut in to get a new one its broken you need a dat cord hope i helped
Posted on May 28, 2009
cubataman
  • 178 Answers
SOURCE: pc suite identifies my LG cu920 phone when
LG PC suite is really quite useless for the VU. Try using just a data cable attached to the phone and usb of your pc. The pc will identify your memory card as an external storage device and you can move your files from the card to your pc. You do nee to have a mamory card installed of up to 4 GB.
Posted on Jul 28, 2009
caroldon
  • 17129 Answers
SOURCE: When phone is switched on the following is
Possible that the phone has hung up because there are errors in the software. So to reset remove the battery and the memory card from the phone. Using your PC , scan the memory card for any corrupt files or media files with virus- it is possible when they are downloaded from unsafe sites. If so remove or format the card. Now replace the card and battery and switch on the phone. If the phone hangs up then it is confirmed that the software is corrupt and will need a reinstallation. Seeking help from the authorized service /support centre is most ideal. Take estimate and decide.
Posted on Apr 05, 2011
  • 3278 Answers
SOURCE: My HTC Inspire is stuck
Hello.
Give this a try from HTC Support:
Power the the phone off
Plug it in to the computer and power on. Should boot into recovery.
Reflash the ROM.
Let the phone update.
If still a problem, hold the vol down when its plugged in and then turn it on and it should boot into recovery.
Hope this helps.
Posted on Jul 18, 2011
  • 10 Answers
SOURCE: in my phone when i
In order to change this you have to disconnect the cable and then put it back in with 1mm sticking out as the adaptor inside automatically chooses the recmommened service. Contact me if this doesn't work.
Posted on Aug 20, 2011
Asus zenpad10 tablet stuck in fastboot mode
KEEP HOLDING THE POWER BUTTON UNTIL YOUR PHONES SWITCHES OFF OR PULL OUT THE BATTERY DIRECTLY(If Required) to exit the FAST BOOT MODE and then start your phone normally by pressing only the power button.
Also in case you were trying to enter the recovery mode to wipe cache or hard reset then keep holding the power button and volume DOWN button until you get vibration and release the power button and keep holding the volume DOWN button to enter RECOVERY.
Jun 16, 2017 | ASUS Tablets & eReaders
I got a Motorola Moto E (2nd Gen) from a friend her grandfather that passed away gave it to her. and it got factor reset so now when I power on the phone it ask for the previous email account that was
Found this info to do a hard reset on Android Geek.
Apply the Hard Reset using Hardware buttons
  1. First of all, turn off your phone (press power button and select "power off" or keep pressing the power key for 15 seconds).
  2. Enter fastboot mode on your Moto E.
  3. From fastboot mode use volume down / up buttons in order to scroll up and down.
  4. Highlight recovery option and select by pressing the power button once.
  5. Good; now from recovery select "wipe data factory reset".
  6. In addition you can also choose "Wipe cache partition"; from main menu of recovery pick "advanced" and then select "wipe dalvick cache".
  7. Done.
Nov 05, 2015 | Motorola Cell Phones
How can i unlock screen on motorola droid bionic because i forgot passcode?
This might help
Droid Bionic Stuck on too many unlock attempts Verizon Wireless Community
  • Power the device off.
    • Press and hold the Power button then select Power off
    • If the device isn't responding Remove / replace the battery
  • Press and hold Volume down and Volume Up, the press Power
  • Display shows Available boot modes
    1. Normal powerup
    2. Recovery
    3. AP Fastboot
    4. BP SBF Flash
    5. BP Only
    6. AP BP USB Bypass
    7. BP Tools
  • Use volume down to scroll to "Recovery", press Volume up to select
  • Once display shows Android triage screen, press Volume up & Down at the same time
  • Display shows Android Recovery
  • Options are:
    1. Reboot System now
    2. Apply Update from SDCard
    3. Wipe data / Factory Reset
    4. Wipe Cache partition
  • Use volume down to scroll to Wipe Data/factory Reset, press power to select
  • Display shows Confirm Wipe of all user data - This can not be undone
  • Use volume down to scroll down to YES - Delete All data - Press Power to Select
  • Device will perform format wipe
  • Display then shows Android System Recovery
  • Ensure reboot system now is selected then press the Power button to select
Oct 16, 2015 | Motorola Cell Phones
How can i unlock a Motorola moto g phone that I bought and I don't have the passcode to
If the phone is Verizon you are out of luck. If the. Phone has been updated to 4.4.4. You are out of luck. If the phone has not been active on the carrier for less than 6 months you also will not be able to. Otherwise, you can request directly from Motorola website after you use fastboot to obtain pre unlock code. Or you can follow methods from xda forums.
Aug 03, 2015 | Motorola Mobility GOOGLE 8GB MOTO G XT1032...
How to view system logs motorola photon 4G
We don't provide assistance for this kind of scenarios. You can enable developer mode by tapping on the build number in About Phone and then look in the setting menu for developer options. And then look for USB Debugging and enable it.
Regards
Kenny
Motorola Support
May 12, 2015 | Motorola Mobility Photon 4G Cellular Phone
How to restore to factory default
To perform an External Manual Reset of your handset to restore to factory settings, read instructions below and then perform.
  1. Power off the phone, press and hold volume down button, press power button.
  2. Screen will come up with "Fastboot", press Vol down key to cycle through choices until you get"Android Recovery", then press Vol up key
  3. Wait for the "triangle ! / Android" screen then go on to step 4
  4. Tap on bottom right corner of the screen (may take a few times). a menu will come up
  5. Tap on "wipe data/factory reset", and tap OK. Another Confirmation screen will come. Tap Yesand OK
  6. After userdata is cleared, the "reboot system now" option will be highlighted by Default. Tap OK.
  7. Phone will reboot to initial setup MOTOBLUR screen.
Tip: Once you've reset your device, you can use your existing account to sync your contacts back to the phone.
(Steps on Gingerbread 2.3)
Remove and remount the battery and power up
If the phone still does not boot up to the MOTOBLUR screen, then perform the following Factory Reset instructions:
  1. Power off the phone, press and hold the Volume down button and Power buttonsimultaneously while powering up the unit.
  2. Screen will come up with "Fastboot" at the top of the screen, press Volume down key to cycle through choices until you get "Android Recovery", then press Volume up key to boot in this mode
  3. Wait for the "triangle ! / Android" screen then go on to step 4 android_recoveryscrn.png
  4. Press both Volume up and Volume down key simultaneously. A Recovery Menu will come up
  5. Tap on Volume down key until "wipe data/factory reset" is highlighted, and tap Power button. Another Confirmation screen will come. Tap on Volume down key until coming to Yes and tapPower button
  6. After userdata is cleared, the "reboot system now" option will be highlighted by Default. TapPower button
To Perform a Factory Data Reset through settings menu:
  1. From the Home screen, press Menu
  2. Touch Settings
  3. Touch Privacy
  4. Touch Factory data reset (Read notes for other options)
  5. Touch Reset Phone
  6. Touch Erase Everything
Oct 20, 2014 | Samsung Cell Phones
How to reset my lenovo A269i ?
Hi Anonymous
I trust you are well
This process will remove everything from your phone and reset it to default settings as when you first received the phone including all contacts, apps etc.
1. Turn off your device. Make sure it`s battery above 50%.
2. Now press and hold Power and Volume Up(+) together.
3. It will display Recovery Mode, Fastboot Mode and Normal Mode options.
4. Now select Recovery Mode option using volume keys, android logo will appear.
5. Now press the power button one time it will display the options.
6. Select wipe user data option using volume up button.
reboot your mobile.
Hop this helps
Kind regards
Aug 20, 2014 | Cell Phones
Are there more than 1 way to turn on a Sony Xperia go
there is three ways:
1- the normal way (by pressing the power key or connecting the charger normally)
2- Flash-mode (by pressing and holding the volume down key and connecting the phone through a usb cable and keep holding the button until the phone led goes green)
3- Fastboot-mode (by pressing and holding the volume up key and connecting the phone through a usb cable and keep holding the button until the phone led goes purple)
there is a forth extra way to boot but you have to manually install it first witch is :
4- Custom recovery boot: (by repeatedly pressing the volume down key immediately after pressing the power key to tern the phone on until it loads the recovery) (why do I need to install it? because the sony xperia phones come with no stock recovery so you must install a custom one)
Hope I helped and don't forget to hit thanks!
May 02, 2014 | Cell Phones
Micromax master resetting code all
Hard Reset Micromax Canvas HD A116
  • Switch Off your phone.
  • Press and hold Power button together with 'volume +' and 'volume -' buttons on the side of phone until you get two options.
  • Now, press the 'volume +' button to enter into the recovery mode.
  • This will make a Android icon appears on screen, press power button.
  • This will get you the menu options, use the volume up and down button to choose the option.
  • To select the option, you needs to simultaneously press two touch sensitive buttons on the bottom of your device, left button which is for the Menu and right button which is for going into previous stage. You have to do this for about 3 seconds.
  • Choose the wipe data/factory reset then press the enter button (left button which is for the Menu and right button which is for going into previous stage). Now, phone will get switch off and brings to its initial stage.
Done! with this default way to factory reset you have successfully done with hard reset of your Micromax Canvas HD A116. The hard reset procedure is same for Micromax Canvas A110 also. If you have any questions regarding the procedure to hard reset Micromax Canvas HD A116.
OR
The Instructions
  • Turn Off your device
  • Press and hold the Volume up (+), volume down (-) and power keys at the same time until the screen show the two options
  • You will get the option Recovery mode and Factory mode , to select the Recovery mode press the volume up (+), for the Factory mode press the volume down (-).
  • If you want to hard reset your smartphone, you should select the recovery mode.
  • To navigate it, you can use volume up and down.
  • To select an option, you must press the Menu button.
  • After you hard reset the device, your smartphone will return to factory setting automatically.
OR
Hard Reset:
  • Press and Hold Volume Down + Power Key for 20-30 Seconds.
  • Now you See Warning Logo on screen.
  • Now Download Android Multi Tool
  • Download fastboot driver and install Drivers
  • now open tool and press "8" and enter to wipe data / factory reset.
  • after format remove battery and reinsert battery.
  • power on the handset.
  • Download Driver from Here
  • Download Android Multi Tool from Here
Nov 07, 2013 | Cell Phones
How do i factory reset my zte concord v768?
Just try with the below steps to hardreset your phone:-
1.Switch off the handset, and press the power-key and volume-down key at the same time until get recovery mode;
2.Press home key get into next interface;
3.There will be four choices:reboot system now;apply update from sdcard;wipe data/factory reset;wipe cache partition;
4.Use "Vol+" and "Vol-" to move the cursor up and down;
5.Move cursor to "wipe data/factory reset," press "menu" key to select it.
6.Then use vol- key to move the cursor to " yes-delete all user data" , press menu key to select it.
7.Then choose reboot system now ,you phone will reboot itself.
Mar 24, 2013 | ZTE Cell Phones
Cell Phones Logo
Top Huawei Cell Phones Experts
Computer Repairing
Computer Repairing
honeybun1986
john h
Are you a Huawei Cell Phone Expert? Answer questions, earn points and help others
