Question about Pioneer Audio Players & Recorders
Where do I find error message codes for a DEH11E Pioneer ?
No sound
What does code Soaoo indicate?
Search Results
    S0A00 Set-Top Box Error Message Help - Comcast
    customer.xfinity.com/help-and-support/cable.../getting-error-code-s0a00...
    Learn what S0A00 on your Comcast cable box means and how to resolve this ... A number of signs can tell you if your computer may be infected with a bot, ...Missing: pioneer
    ref code S0a00 - Comcast Help and Support Forums
    forums.xfinity.com/t5/XfinityTV-and.../ref-code-S0a00/td-p/855021
    Jan 18, 2011 - If you getting S0A00 errors, that means you have signal issues, most ...fios is cheaper than comcast, can you give an example of how fios is ...Missing: pioneer
    Comcast Ref Code S0a00 - How Do I Fix It? - GeekDrop
Jan 23, 2016 | Pioneer Televison & Video
Amp error message on Pioneer DEH-15UB. Vehicle was jump started twice would this cause this problem? The receiver is not connected to an external amp. The radio/cd player will work for about two minutes...
I just had an "amp error" message display on my Pioneer DEH-15UB and it quit playing. No sound at all. It happened while I was driving my Jeep. When I got home I removed the passenger side speaker from the sound bar and found the previous owner had used a wood screw to hold the wire to the speaker. That screw came into contact with the metal roll bar and caused the error. When I installed ends on the wires the error message cleared itself and now works fine
Sep 17, 2013 | Car Audio & Video
Failed search for TV Channel Pioneer KRL37 - error code 202
Could be a system corrupted error. This might need attention by a qualified service technician.
Jul 15, 2012 | Televison & Video
I have the pioneer DEH-P7000UB in a Vauxhall Vectra. I put the head unit in the car, connected my IPhone (not the 3G version) set the head unit to USB mode and it try's to read my IPhone then comes up with...
error 19 is a communication error code with the ipod itself so either the cable is bad or the connectiontion on the ipod or deck is bad or the ipod itself may have a bad rom for external use. this info comes straight from the tech support manual for Pioneer that we car audio techs use (even if you call pioneer they will tell you mthe same thing).
try this :
Disconnect the cable from iPod.
Once iPod main menu is displayed, connect the cable again.
Reset the iPod.
Oct 31, 2008 | Pioneer Car Audio & Video
When I try to play a C.D. on my system it gives me the following information. FRMTREAD, Error 15. What does this mean and what do I do to correct this problem? My system is a DEH2000MP S.N....
Consult your owner's manual for error codes. You have a disk/disk reader problem. A similar model Pioneer Manual indicates FRMTREAD as what is displayed while reading a disk. Error 15 equates to "The inserted disk does not contain any data". If this occurs with multiple disks, try the disks in a known good cd player. If they work there, it is likely a reader problem (alignment, bad reader, etc.) which would likely not be worth repairing or replacing in that unit.
Jun 23, 2008 | Pioneer DEH-P2000 CD Player
AVIC-N1 wont read navigation disc
If your error message is reading "insert appropriate disk" or "inappropriate disk inserted" than I have the solution. Can you just let me know exactly what the message is?
Jun 05, 2008 | Pioneer AVIC-N1 Car DVD Player
AVIC-N3
What kind of error message? Sound like you have a "tired"(miss aligned laser). If you be more specific and describe the details of your problem, I think I can help.
Dec 16, 2007 | Pioneer AVIC-N2 Car DVD Player
Error message on display of my Pioneer DEH-P8000R
Try buying a cleaning CD that will clean the laser lens and see if that helps. Otherwise it sounds like a trip to the repair shop for you. Good luck.
Feb 01, 2007 | Pioneer DEH-P8000R
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
