Question about Radio Communications
Is there another reason why the ORB would beep besides needing batteries replaced? If not, is there a pwr adptr for the Orb when not used in the pool?
Paired with android tablet & using Pandora. Worked great! Enjoyed ~72hrs of use not consecutive, then it gave some sort of signalbeep,beep,beep. Put in new batteries, beeping stopped. After 24 hrs of use it is doing it again. The music stops,it beeps,music resumes, only to do it again&again, with less&less time in between. VERY annoying. Have no other blue tooth item to pair it with. Other suggestions? If it is only batteries,is there a pwr adptr for the Orb when not used in the pool? Unable to find any support or contact info.
SOURCE: Zanussi FX1465W aquacycle, beeps 5 times and end light flashes
I have the same trouble with my washing machine did you find a solution i have been told the PCB or motor drive system
Posted on Jun 16, 2007
fridgetech
  • 473 Answers
SOURCE: F1 error code, continual beeping all other oven functions work properly
Here are the error codes for Dacor:
DACOR
Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F0 Clock pushbutton is stuck in a depressed position Check clock buttons F1 Element relay circuit failure Control board may be bad F2 Oven temperature exceeded the clean runaway temperature (self clean only) or the cooking runaway temperature (cooking modes only) Call for service F3 Short Circuit in the oven temperature sensor Check oven temperature sensor for continuity, if no resistance (zero ohms), replace F4 Short Circuit in the oven temperature sensor Check oven temperature sensor for continuity, if no resistance (zero ohms), replace F6 Failure in the EEPROM check comparison (only time of day and timer will operate) Call for service, electronic clock control is usually the cause of the problem F7 Failure of the self- clean automatic door latch system Check door latch and switch(es) F8 Failure of the door latch motor. Occurs when the motor runs for two minutes without the door locking in self-clean mode Check door lock motor and door latch
Posted on Nov 09, 2007
SOURCE: Olympus Stylus 730 Digital - Won't work 60 days old
I'm having the exact same problem. I was in the middle of zooming on a shot and it froze, so I turned the camera off and on, and now I get the 5-chimes+Zoom Error screen. This is nuts, I've only had the thing for six months, and it was $250 (got the Stylus 730). I *think* I got a replacement plan so that's good. But still... I hope circuit city lets me get a different brand b/c I'm not happy with this now. The only problem I had before was the HORRID shutter delay. I want a model that doesn't have that problem .
Posted on Mar 29, 2008
clark_styx
  • 282 Answers
SOURCE: Constant beeping / connect/ disconnected
you need to turn off your bluetooth on your phone,cause as long as its on,its going to try to reconnect to your phone
Posted on Oct 08, 2008
  • 4 Answers
SOURCE: How do I put the Blue Tooth device into pairing mode?
first switch on ur mobiles bluetooth connection......... then switch on ur moto H350..... then it automatically ask to pair with ur mobile jst accept it........ and then enter the pass code 0000.........kkkk... then it get paired... kk..........
Posted on Oct 30, 2008
My alarm beeps at night for a short period
if it is about a smoke alarm with a battery in it, when the alarm beeps for no apparent reason, it is a bult in indicator that the battery is flat or approaching a low voltage and needs replacing
If it still beeps after replacing the battery have it checked out as a fire alarm is critical for your safety
Jun 12, 2015 | Kidde 1276-9995 Hardwire Smoke Alarm with...
Tip
If your computer has a black screen and not booting to desktop
Normally if the computer has the black display then follow these steps:
1) disconnect the pwr cord form the back of the computer //
2) disconnect the printer and the internet cord//
3)hold the pwr button for 1 min and then release// this is called "pwr drain" when the pwr cord is disconnected//
4)connect the pwr cord and restart the computer and see if it boots or not.
5)if not then disconnect the pwr cord again and open the side pannel of the computer//
6)on the mother board you will find the RAM (MEMORY CARD) which will be approx 6 inch long", take out the card/s and plug the pwr cord and restart the computer//
7) if you get the beep sound then the mother board is ok and if you do not get the beep sound then the problem could be mother board//
8)if getting the beep sound then fix the RAM CARD properly and restsrt the computer// it shoul boot//
note** during all this process make sure that the pwr cord is pulled out when you put your hand inside the computer or else you can get power shock..
on Jun 10, 2010 | Computers & Internet
Fi 6000ns beeping
Just went through this. Unit is a mini-ITX pc w/ custom pwr supply, screen, and a cute little USB keyboard. Not going to get into into the disassembly w/ this answer, but the bottom line is a bad RAM stick. Uses PC2700U 333 Class 2.5 DDR, 512MB. Replace that, the beep stops, the machine will POST and pwr up.
Oct 21, 2013 | Fujitsu fi 6000NS Flatbed Scanner
Sb pwr light keeps on / one beep and the PC turns off
Check that keyboard is plugged into correct port.
Can you Enter CMOS setup ? Try replacing battery on main board.
Oct 21, 2013 | Intel Computers & Internet
Unpluged HDD LED PWR S/W and PWR LED for board
it's usually written in fine print beside pins. Failing that get the manual which tells you
Feb 26, 2010 | E-Machines T3958 (827103050974) PC Desktop
SmartParts SP15MW photo frame won't turn on--pwr adptr shows 12 v
It's the power adapter... I had the same problem as of yesterday and today I used the power supply from my HDTV and it worked as good as new. Will have to go out tomorrow and get a new power supply.
Dec 14, 2009 | SmartParts SP15MW (092566981886) Digital...
Beeping wouldn't stop, now it's dead.
F7 means you relay board is bad, you need to replace it.
Jul 23, 2008 | Dacor ECS130 Epicure Electric Single Oven
Fried Pwr Supply
Besides to buy an AC power adapter, you will need to repair the MP3 player too.
The power adapter is cheap in on-line companies (such as Ebay), but still you will need to have serviced your mp3 player.
There are a couple of integrated circuit parts in the battery charging circuitry that are damaged when the impropoer voltage is used.
If you need further assistance to have serviced your mp3 player, after explore different local options, please contact Ebay seller ID Great_tems_2004
Regards,
May 11, 2008 | RCA Lyra RD2840 MP3 Player
Compaq evo d500 does not turn back on
If its powering on, but the screen isnt turning on and the computer starts beeping, try replacing the ram.
Mar 15, 2008 | Compaq Evo D500 PC Desktop
Radio Communications Logo
154 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
