Question about Vtech Lands Phones
What to do when you can dial and receive calls but you can't receive voicemails check caller id etc.?
I am able to receive my calls along with dialing calls but the rest of the system won't work, any ideas on how to fix it?
  • 84 Answers
SOURCE: telephone connection problem with DSL
unplug everthing from all jacks in the house. call your # a couple of times. if the line rings, plug everything in 1 at a time, but call again after each hook up. if the line goes dead or is busy, that phone you just plugged in is the problem. [ a short in the phone, computer, answer machine, or any piece of equipment plugged into the phone line.] if the line is busy when everything is unplugged, call your phone company. there maybe a problem with your inside wire.there also maybe a box [called a nid] inside your basment/garage or on the side of your house, where you can plug your phone directly in, bypassing all the jacks in your house
hope this helps.
wg
Posted on Feb 13, 2008
funkyjacob
  • 76 Answers
SOURCE: No dial tone on handset
It may not be registed with the main unit. You may need to register the handset. With my uniden all i have to do is put it in the main base until it says what handset it is (it should be a number).
If you have any questions please dont hesitate to ask
Posted on Dec 02, 2008
  • 84 Answers
SOURCE: phones don't ring
Caller ID is a service that is provided by your telephone service provider and not the phone. If the phone company isn't sending your line Caller ID data, your phone won't display it. As for getting the handsets to ring, try pushing the volume up key while the handset is off, the more times you push the button, the louder the ring will get until you are at max ring volume. Also, some models have a "Do Not Disturb" feature which turns the ringer off. Without knowing which model phone you have I cannot tell you how to turn this feature on/off. but you can look it up in your manual online at http://www.uniden.com/index/manuals_results.cfm?cat=1
Posted on Apr 03, 2009
SOURCE: partner 18d caller id checking
It should say "Calls" on your display. If not, the caller ID log is not set up.
Posted on Aug 06, 2009
SOURCE: Can't access Vodavi STS Starplus voicemail to program it
THE VOICEMAIL OF OUR PHONE SYSTEM IS NOT WORKING RIGHT...
Posted on Dec 14, 2009
How do i make my phone number visible to my callers when calling from a Vtech phone
Caller ID
If you subscribe to caller ID service, information about each caller appears after the first or second ring. If you answer a call before the caller information appears on the screen, it will not be saved in the caller ID log. The caller ID log stores up to 50 entries. Each entry has up to 24 digits for the phone number and 15 characters for the name. If the telephone number has more that 15 digits, only the last 15 digits appear. If the name has more than 15 characters, only the first 15 characters are shown and saved in the caller ID log. Review a caller ID log entry Press CID when the phone is not in use. Scroll to browse through the caller ID log. When the desired entry appears: Press repeatedly to show different dialing options. Press 1 repeatedly if you need to add or remove 1 in front of the phone number. Press or to dial the displayed number. Dial a caller ID log entry When the desired entry appears, press or to dial. 1. 2. 1. 2. 3. 4. 1. 2. 3. • 1. 2. • • 3. • Save a caller ID log entry to the phonebook When the desired caller ID log entry displays, press SELECT. 2. Scroll to To Phonebook then press SELECT. 3. Use the dialing keys to modify the number, and then press SELECT. 4. Use the dialing keys to modify the name, and then press SELECT to save. Delete a caller ID log entry When the desired caller ID log entry displays, press DELETE. Delete all caller ID log entries Press MENU when the phone is not in use. Scroll to Caller ID log and then press SELECT. Scroll to Delete all and then press SELECT twice.
Call block
If you subscribe to caller ID service, you can set the telephone to block unknown calls and certain undesired calls. The call block list stores up to 20 entries. Block unknown calls Press MENU when the phone is not in use. Scroll to Call block, and then press SELECT. Scroll to Calls w/o num, and then press SELECT. Scroll to choose Not block or Block, and then press SELECT. Add a call block list entry 1. Press MENU when the phone is not in use. 2. Scroll to Call block, and then press SELECT. 3. Scroll to Block list, and then press SELECT. 4. Scroll to Add new entry, and then press SELECT. 5. Enter the number. • Use the dialing keys to enter the number (up to 30 digits). 6. Press SELECT to move to the name. 7. Use the dialing keys to enter the name (up to 15 characters). Additional key presses show other characters of that particular key. 8. Press SELECT to save. 1. • • 1. 2. 3. 4. Review call block list Press MENU when the phone is not in use. Scroll to Call block, and then press SELECT. Scroll to Block list, and then press SELECT. Press SELECT to choose Review. Edit a call block list entry When the desired entry displays, press SELECT. Use the dialing keys to edit the number, and then press SELECT. Use the dialing keys to edit the name, and then press SELECT to save. Save a caller ID log entry to call block list 1. When the desired caller ID log entry displays, press SELECT. 2. Scroll to To Call block then press SELECT. 3. Use the dialing keys to modify the number, and then press SELECT. 4. Use the dialing keys to modify the name, and then press SELECT to save. Delete a call block list entry When the desired call block list entry displays, press DELETE.
Mar 15, 2016 | Vtech V CS6419-2 DECT 6.0 Cordless Phone,...
How do I change the setttings in my phone to ring more times before it goes to voicemail?
look it over many have a button that slides to change that or look thru the setup menu.or manual
Jan 26, 2016 | RCA ViSYS 25423RE1 4-Line Telephone, Blue...
How do I make the green flashing light on the phone go away?
Blinking Light
Two reasons the light on top of your screen might be blinking or on steady.
  • You do not have a voicemail key programmed and the voicemail is alerting you of a new message. Simply dial *8 and check your mailbox.
  • Message waiting has been activated. To cancel:
    • leave handset hung up
    • press call1 key
    • dial 873
    • press speaker key
Blinking light on top of Display NEC Aspire
Nov 13, 2014 | NEC Lands Phones
How do I unblock my phone number
After you enter *67, you hear the dial tone. Dial the outbound number. Your caller ID is not presented on the receiving end.
After you enter *82, you hear the dial tone. Dial the outbound number. Your caller ID is presented on the receiving end.
Sep 25, 2014 | Lands Phones
When using phone I cannot call out , it gives me a fast dial tone , but I can get incoming calls
Does the fast dial tone persist, or do you get a regular dial tone after a couple of seconds? If the latter, then you have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Jan 16, 2014 | Panasonic High quality max 2.4 ghz phone...
UNIDEN TRU8888-CALLER ID DOES NOT WORK
Hi
Thanks for using FixYa. I think you have stored more than 100 Caller ID messages and hence the caller ID is not showing on Uniden Tru8888. In the following cases the caller ID will not be shown-
If you answer a call before the Caller ID message is received (for example, before the second ring), the Caller ID message will not appear.
When the call is received via a telephone company that does not offer Caller ID service, the caller’s phone number and name does not appear. (This includes some international calls.)
When the call is via a private branch exchange (PBX), the caller's phone number and name may not appear.
You may receive any one of the following messages:
When a private name is received; Private Name
When a private number is received; Private Number
When a unknown name is received; Unknown Name
When a unknown number is received; Unknown Number
When invalid data is received; Incomplete Data
The Caller ID list stores information for incoming calls - even unanswered calls. You can store up to 100 Caller ID messages and phonebook entries (including Speed Dials) for each handset and the base. You can view the Caller ID list through the handset or base during a call or when the phone is in standby mode.
Memory locations for Caller ID messages and Phonebook entries (including Speed Dials) are common, you can store up to all 100 entries for each handset and the base. Caller ID messages are not stored when you have 100 phonebook entries. When you have stored a total of 100 phonebook entries and Caller ID messages, the oldest Caller ID message is overwritten.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 16, 2009 | Uniden Cordless Phone
Kyocera candid ii will not send/receive calls.
you have to deactivate your call divert service for all
May 19, 2009 | Kyocera Candid KX16 Cellular Phone
Cannot phone Canada
I had the same problem.
The way around this is to dial the number with one of the following codes in front of it:
*67 or *82
Dialing *67+1+(Canadian Phone Number) <SEND> will make the call to Canada, however, your number will not display on the caller's Caller ID display.
Dialing *82+1+(Canadian Phone Number) <SEND> will make the call to Canada, AND your number WILL show up on the caller's Caller ID Display.
I tried it with my Motorola W375 and it works like a charm as of February 13th, 2009.
Dec 08, 2008 | Motorola Mobility W375 Cellular Phone
Lost power for one second and now cannot get my caller ID to work
unplug the telephone cable from the back of the receiver and plug it a basic telephone to check if there is a dial tone. if there is a dial tone restart the receiver without the the telephone line plugged in. after it loads and u have a picture, plug in the telephone line. call the home to check. if its not working the modem in the receiver has gone bad.
Oct 20, 2008 | Directv Plus DVR DTV Receiver / 100-Hours...
Lands Phones Logo
41 people viewed this question
Top Vtech Lands Phones Experts
David Burbee
David Burbee
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
