Question about Craftsman Garden
How do I put the muffler back on a craftsman 6.75 lawnmower.
Model. 917.370412
    Top Expert:
  • Craftsman Master
  • 52,099 Answers
It either bolts on or screws in
Posted on May 06, 2015
4 Suggested Answers
mowerman1857
  • 389 Answers
SOURCE: how to put brake pads on
Look on the right hand side of the transaxle, behind the front side of the rear wheel and locate the brake arm with a long rod sticking through the top of it. Note there is a 1/2" nut in the center of the arm near the bottom.
Before you start to replace the pads, try adjusting that nut. Put the tractor in neutral on flat level surface, engine off and turn the nut in while rolling the tractor back and forth with one hand, when you can no longer move the tractor STOP and unscrew the nut 1/2 turn. Now check your brakes.
If you still don't have brakes then you go back to that same nut and remove it completely, pull the arm out of your way and you will see a round disc about 3" in diameter beneath a "yoke" There will be 2 bolts 3/*8" head in the yoke, remove those and the brake pads will be right there, one in the yoke and one behind the disc.
Hope this all makes sense to you, if not, let me know and I will try to sort it out further
Posted on Oct 02, 2009
Testimonial: "thanks alot, worked great!!"
  • 11 Answers
SOURCE: craftsman model 536270211 13.5 hp ride on lawnmower won't start
check for water and debrie in float bowl and spark at plug
Posted on Jun 07, 2012
BAMOUT
  • 2478 Answers
SOURCE: oweners manual for craftsman riding Lawnmower lt1000
Try www.managemylife.com
Posted on Oct 09, 2012
Craftsman bushwhacked hedge trimmer model 358795720. Can't get the cover of to replace the muffler
To get to the muffler, the carburetor will have to come off of the machine. Take the air filter cover off and remove the air filter. You will see 2 screws in the base of the filter cover. Take those screws out and this will allow the carburetor to drop off of the engine. You can just let the carburetor hang from the hoses and cable for the time being.
On top of the engine you will see 4 screws; remove them. On the front of the engine (below the spark plug) there is a screw that must be removed. Also, the spark plug will need to come out. The engine shroud should not lift off the engine. Around where the 4 screws come through the shroud, there is an "o" ring, make sure to not lose it.
You should now be able to access the muffler to remove the old one and put the new one in place. Once it's in place, put the "O" ring back and seat the engine shroud. Then put all the screws back in place. Then attach the carburetor back to the side of the engine.
Oct 23, 2017 | Craftsman Garden
How to replace ignition switch on model number 502.254970 craftsman riding lawnmower
should be easy pull the plug off of the switch and the old switches were bolted on the newer ones are just clipped in remove old switch put in the new one put plug back on the switch.
May 18, 2017 | Craftsman Garden
I need to find out how to put back the thermostat and the muffler for a craftsman 917 370410 lawn mower
I don't see a thermostat. The picture IS A MUFFLER AND GASKET. No thermostat in this model.
Mar 14, 2014 | Garden
I need a diagram of how to put the Blade belt on my Yardman 42' riding lawnmower
Yeah, these belts can seem impossible to figure out. There are idler pulleys that press against the back of the belt. The routing is sometimes not obvious. Do a search for your particular model.
May 11, 2012 | Craftsman Bolens Yardman Front Tine Tiller...
How do you replace drive belt on a hydrostatic transmission craftsman riding lawnmower that has slipped off or my be broken.
Its not a hard job just push in clutch and lock it, remove mower belt then replace drive belt and then put mower belt back on and release clutch.
Jul 17, 2010 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
13.5 hp Craftsman lawn mower 5-speed
Here is a picture to help you place it on right. There are two deck designs pick yours.
Aug 28, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman rider lawnmower
i have a rider 48inck cut and i need to know how to put the upper belt on
Apr 04, 2008 | Baby Gear
Garden Logo
57 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
