Question about Baby Gear
Do u have xpedior safety bar - Baby Gear
New GMC electric chainsaw runs until it try's to cut wood. Motor runs but chain dose not turn ? Turns if not on wood.!
problem in the safety clutch area
ensure that the safety bar is fully back and engaged before pressing trigger
the safety bar is that handle at you fingers when you are holding the the saw handle and by moving , flicking your fingers forward it stops the chain action
if that is fully engaged , it will require servicing by any accredited chainsaw repair shop
Apr 23, 2017 | Electric Garden
Strap shot nailer wont shoot it almost seams like it has something to do with the saftey
The safety bar comes not good unter the trigger plate a little plate mount inside the trigger that will lift up by safety valve some brands have has maybe something to do with it.
Special care with this remove all nails before try this look behind backwarts after the trigger in the middle you see a pin that goes up and try to lift it up with a screwdriver you know for shure that if a safety bar is in doubt that it can or will working to test by this example to test where the bar is blocked.
Jan 04, 2015 | Tools & Hardware - Others
Needle bar won't go up or down
Some sewing machines need to be in a certain position to allow this as a safety issue. Look in manual under safety.
Aug 29, 2014 | Sewing Machines
Should I replace the cable that connects from the safety bar cable to the motor?
You should tighten the cable unless it is frayed and/or broken. If it is not frayed, just tighten it. Don't overtighten it or it will keep stalling.
May 14, 2014 | Snapper Garden
Safety bar disconnected
are you talking about the handle or the dead man lever? the safety lever usually fits into two holes in the upper handle and pivots up to meet top handle bar for operation. this pulls a cable tight allowing mower to run. Make sure main handle is up and tight then try to fit one end on lever into one hole and then slightly bend other end to fit into opposite hole.
May 16, 2013 | Briggs & Stratton Garden
Need carseat bar attachment for Safety 1st Acella LX stroller
Hi
This is not a UK product so we're unable to advise on availability of spare part items / cost. Could you advise which country you're in and we can advise the customer care team you need to contact.
Mar 05, 2013 | Safety 1st Acella LX - Navy Stroller
How do i get the bar that helps in attaching both stroller & car seat for Safety 1st Explorer Travel System in Redbrook ?????
Call Safety First/Dorel at
Dorel Juvenile Group
Consumer Relations Department
P.O. Box 2609
Columbus, IN 47202-2609
Phone : (800) 544-1108
Here is a link to their site.
Safety 1st
Aug 30, 2012 | Safety First Safety 1st Explorer Travel...
No gas flow to oven, glow bar ignites no flame no smell of gas. safety gas safety valve was replaced
With the glow bar going and no gas smell that means you have a good circuit from control to valve and glow bar. For that glow bar to work it must change in resistance. If it is weak it won't change enough resistance to make the gas valve bi-metal open. Also the gas safety valve does not come preset and usually is bottomed out all the way for propane. You must adjust the orifice to aprox the same height as the old one to get the propah gas output for natural gas.
if your old valve did not leak and has continuity between the terminals it is fine. The ignitor/glowbar is weak. If it is dim orange that is usually a way to tell. Bumping the stove makes the bi-metal come on also is a sign of a weak glowbar
Jul 14, 2011 | Magic Chef Ovens
For a Poulaln P3314 what position should the movable safety bar be for starting, forward toward the chain/bar, or rearward toward grip. Ted
the safety bar is chainbrake and should be in off position so the chain is free to move on the bar,,, that should be to the rear youdoit
Jul 27, 2009 | Garden
Broiler works, as do burners. The oven will not come on. Gas whirlpool range 2003 year. Model SF367LEKB
jdelvecchio5Does the igniter (glow bar) come on whenever the bake function is selected.?
If the glow bar does not come on the safety valve will not open - no bake burner. check the electrical harness first then Try changing the igniter (glow bar first) before changing the safety valve/regulator.
Dec 02, 2008 | Whirlpool 30" Self-Cleaning Freestanding...
Baby Gear Logo
26 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Are you a Baby Gear Expert? Answer questions, earn points and help others
