Question about Cell Phones
What does ESb or possibly E5b code mean on hot tub
  • Debbie Walker
    Debbie Walker Apr 04, 2015
    Dr. Wellness Lifestyle X2
2 Suggested Answers
badfish6686
  • 563 Answers
SOURCE: fault code on hot tub
Need more information on the tub. Do the circulation and therapeutic jets work?
Posted on May 18, 2013
Hot tub pump will not start back up after cleaning hot tub
When you say the pump won't start back up, do you mean the electrical side of things and there is just no power going to the pump. Or are you saying that the pump is on but not pumping water.
I am going to think you mean the pump is on but not moving water. This is common after you clean and drain your hot tub. You have what is referred to as an airlock in your hot tub line. It is easy to remove the airlock by simply opening one of the unions near the pump. This will allow the air to release and water flow to begin again.
Make sure also that you have cleaned the hot tub filters, if they are dirty and reduce water flow that could shutdown your hot tub pump as well.
If it is the electrical side of things make sure your GFCI has not tripped and maybe you just need to reset this. If it is anything further on the electrical side make sure you involve a professional.
  • open a union to release any airlocks.
  • clean your hot tub filters.
  • check to make sure your GFCI is not tripped.
Hot Tub Repair 101 What is an E6 or Error 6 Code Mean
You may have to change your hot tub filters as well and can find an assortment of filters here. The filters should be changed yearly, and cleaned monthly.
Hot Tub Filters
Jan 30, 2016 | Pool & Spa
What does error code E56 mean?
That error is an E5b error. This indicates a problem with the heating element, the thermistor or the control board. You'll need to unplug the unit and access the wiring. Inspect the heating coil for breaks. Then test the voltage across the element (should see the line voltage) and check the resistance at the thermistor (should be ~50000 Ohms in a room temperature environment). If the above are okay, your control board is probably bad.
If you post a comment with the model number, I may be able to point you the appropriate parts. If your dryer is under warranty, contact Frigidaire.
I hope this helps.
May 19, 2015 | Frigidaire Dryers
What does code ic mean?
I have not seen an ic error code. I have seen ICE several times. So either you do not have the original pack that came with the spa or your display may be malfunctioning.
What is your hot tub doing while the ic code is pressent?
Portable Hot Tubs and Spas On Sale
Apr 12, 2015 | Dream Maker Spas Dream Maker Ez Spa Hot...
What does error code -0.3 mean on an Aruba Hot tub
Don't think that's an error message? Could be letting you know heat is bypassed for Max setting?
Feb 11, 2015 | Qca Spas Majestic Series Aruba Xl Hot Tub
What does the E6 error mean
Hi Cheyenne,
Most of the time an E6 error code refers to a restriction of water in your power pack. When you don't have enough water flow the power pack shuts itself down so it does not over heat.
Possible reasons are dirty filters, air locks, restrictions of water flow,
Solutions are to make sure your water flow is as best as possible, clean your filters often, remove debris from your hot tub, and remove air locks from your power pack.
Dec 18, 2014 | Jilong Inflatable Hot Tubs: Prompt Set...
Fault code on hot tub
May 18, 2013 | Washing Machines
Hot tub pump noisy, heats to set temp, fl error code
This sounds like your motor is going out. When they get noisy and run really hot is when they go out
Rod
US Parts Center
Jan 08, 2013 | Qca Spas Jewel Series Topaz Plus Hot Tub
Affinity aeq7000eeo e5b 006 error code
Probably a stuck button Use this SERVICE manual to locate your tech sheet and it will give you info on errors for your particula machine
Aug 30, 2012 | Electrolux Dryers
Service engine light is on and the ESB light was on
OK!... I assume you mean the ESC light... right? Based on my experience, what you have is a malfunctioning BRAKE LAMP SWITCH... replace it and see if that fixes your problem. Hope this is helpful (since you didn't scan the 'CHECK ENGINE' light issue).Whenever the 'CHECK ENGINE' (Service Engine Soon) light comes on, the ECU (Engine Control Unit) sets a Diagnostic Trouble Code (DTC). These codes identify the particular engine management system which caused the light to come on.
You'll need to use/find an OBDII (On-Board Diagnostic) Scanner to retrieve any code which have been stored in the ECU computer. If, IN FACT, you have a 'BRAKE LAMP SWITCH' code, then you've found the problem and the solution.
Oct 01, 2009 | 2006 Hyundai Sonata
Cell Phones Logo
103 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
