Question about Garden
I have a Troy-bilt tb30r riding mower. Was cutting the grass fine, I turned it off for a minute and it wont start back up. Any clue? I've checked gas, oil, plugs, and battery.
  • Hi jessica anderson, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    Problem Solver:
  • 19 Answers
Did you disengage the mowing deck when you shut it off? If the mowing deck is engaged, it will not start.
Posted on Apr 05, 2015
  • 202 Answers
SOURCE: I have a Troy bilt 17hp 42 inch cut ride on lawn
yes they have a charging system, not like a car but a charging system one the less. as i said before either under or around the flywheel. some newer mowers also have an electronic regulator.
Posted on Jul 31, 2009
  • 24 Answers
SOURCE: Craftsman riding mower starts rides a few minutes then stops
Make sure that when you check the oil that the mower has sat I say for at least 5mins. Your mower might have an oil sencer. If not I think it might be the coil gettin hot and shorting out.
Posted on Aug 23, 2009
  • 62 Answers
SOURCE: Troy-bilt bronco riding lawn mower choke problem
Check your air cleaner...then check fuel line from pump. Pull fuel line off carb make sure fuel is present. :)
Posted on Sep 07, 2009
rtpflh
  • 546 Answers
SOURCE: I have a troy bilt riding mower, 6 years old, 26
many of these units use the starter motor as the generator to re-charge battery. check voltage regulator & wiring.
Posted on Sep 28, 2009
yakuzza2
  • 68 Answers
SOURCE: craftsman riding lawn mower won t cut grass
Does it die when you attempt to engage the cutting deck? If so the you might have a clogged fuel filter, bad gas, dirty air filter, bad spark plug.
Or the mower engage switch may be faulty. They are located in different places on different mowers. But should be attached somewhere along the main pivot of the engage lever. Let me know if you need more assistance. Good Luck!!
Posted on Jun 05, 2012
Why doesn't it start?
Might be a full tank of wet gas from over-winter condensation.
Apr 11, 2016 | Troy Bilt 175HP Manual 42" Riding Mower
Troy-bilt riding mower won't move in forward or reverse
I had a similar problem with my TroyBilt 50 inch zero turn mower. Was cutting grass when it stopped going either forward or backward even though it would start and the PTO would move the cutting blades. Turned out the tensioner spring for the belt that drives the motors near the rear wheels had gone missing. Searched the yard where I had cut and moved the machine but couldn't find it. A new one cost me about $7.50. Put the new one on and it worked fine.
Apr 19, 2013 | Troy Bilt 175HP Manual 42" Riding Mower
I have a troy bilt riding mower. I put a new battery in it last summer. This yr., my son left the key in on positon when he got done cutting the grass. Naturally it killed the battery, I jump started the...
It may not be charging due to a bad connection to the battery or to the generator on the engine. The generator on the engine may be going or has gone bad.
I hope this helps.
Jul 27, 2011 | Troy Bilt 175HP Manual 42" Riding Mower
Have a troy bilt 200 tuff cut mower. roughly a 2004. It wont start. worked fine the other day. pulled cord and nothing. tried starter spray etc. no luck. Also where can i download a manual for this
#1 CHECK THE OIL ! .#2 check for spark you may have flooded the motor. THESE WILL NOT RUN WITH LOW OIL .. or with water in the gas
Jun 06, 2011 | Garden
Our Troy bilt lawn tractor wont start. It seems like a short
Unless something catastrophic has happen internally, fuel and spark are about all you need. If you are sure of the fuel supply, pull the spark plug lead and let it arc to ground so you can check ignition health. You should have a bright blue spark visible. If you do, then pull the plug and replace it; the insulator may be cracked and robbing some of the high voltage. If it still doesn't start, you may have flooded it and when this happens to me, I make sure no spilled gasoline is present but I then pull the plug and use a charcoal or fireplace lighter and place it in front of the sparkplug hole. It should pop and help exhaust the excess fuel.
Aug 14, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Bog when trying to mow
you are cutting to much grass & it isn't kicking it out fast enough out of deck which will bog it down it might help if you clean out the bottom of the deck & also dont cut really low if grass is really tall also cutting wet grass will aslo cause the bogging if i can further help e-mail me wade at wadembly@aol.com
Jun 26, 2009 | Garden
Troy bilt mower won't stay running to cut lawn
You may want to check the gas cap to see if it clogged with dirt. If the gas cap is clear, you more than likely have a carburetor problem. If you need tips on carb. cleaning, feel free to ask.
Jim
May 29, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Tractor?troy bilt/mtd 2002
the electric clutch that operates the blades needs replaced
Sep 22, 2008 | Garden
Garden Logo
59 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
