Question about Refrigerators
Why does my icemaker over fill the ice tray?
There does not seem to be any adjustments on the ice maker or water valve. Should I replace both to be certain to solve the problem? It only overfills the tray by about 1 ounce, enough that it is frozen solid.
  • Refrigerators Master
  • 5,323 Answers
Ice Maker Doesn't Turn Off If your ice maker keeps making ice, even when it is full:
1Lift the bail wireto shut off the ice maker, and remove the ice bin. Then, using a screwdriver if necessary, remove the ice maker, clean it thoroughly, and then reinstall it.
2If the problem persists,consider removing and replace the entire ice maker and valve. With this type of problem, you can have it repaired, but it's often wiser and less expensive in the long run to replace the unit entirely.
Posted on Apr 10, 2015
Ice maker on refrigerator does not work at all
Notwithstanding the ABSENCE of MAKE+MODEL...
(REFRIGERATER or ICEMAKER)...
Nothing came through with your "question"... ERGO
Most, generally & typically should be in front of everything that looks or sounds like a FACT.
Every ICE MAKER (I've ever worked on)has an on/off control...
Find it... turn it off, on, off & on several times (cycle the switch
(like lower the FILL wire ... or operate the on/off switch)).
ICE-MAKER heads are a relatively simple device with motor driven electro-mechanical sequencers that time water fill (adjustable), cube "done-ness" ((firmness by adjustable temperature)... and then "operate the fill valve... fill the tray...
Rotate the tray and eject the cubes.. refill with water...
If you can see or feel ice in your TRAY your...
you have NO ISSUE with your WATER VALVE...
To test this... use an ordinary water bottle and Put some water in your ICE TRAY...
Check back in an hour ...if your cubes have been NOT deposited into your ice bin... your ice-maker is turned off, has a open fuse or is defective & needs repair.
If it has ejected your cubes but you have not been refilled your WATER VALVE is defective...
replace it.
Hope this helps.
Aug 17, 2016 | Refrigerators
Hello! I have a Kenmore refrigerator model #10656576400. It stopped making ice for a while but then started up again. Now it is leaking water and filling up the tray underneath the ice cube mold. Is it...
The first thing to check would be the water fill valve located usually on the back outside of the unit where the water line comes in, these can start leaking water slowy into the icemaker. The icemaker itself tells the valve how long tostay opened, that can be adjusted by a tech or you may need to replace the icemaker
Jun 24, 2011 | Refrigerators
Water started pouring out of the icemaker and out the dispenser. When we opened the freezer door water poured out of the icemaker and down the whole freezer. Opened icemaker flap and water stopped. Turned...
Cindy, it’s either the water inlet valve that fills your ice maker or the ice maker itself that is bad. The ice maker itself controls the valve. It should come on for about 7 seconds to fill the tray. The valves do fail but not as often as ice makers fail. Its also possible that the fill tube to the ice maker is blocked with frozen water but since it made one tray that is unlikely. If you know someone that knows how to test the valve it would eliminate the decision of replacing the ice maker or the valve. Otherwise I would recommend changing the ice maker first. Hope this helps.
Feb 11, 2018 | KitchenAid Superba KSRG25FK Side by Side...
We installed a new subzero side by side 2 years ago and have had problems with the icemake off and on. Now it doesn't make ice and the appliance center does not seem to be able to fix it. The have...
did they check the water valve?does it fill with water?all it does is the ice maker calls for water,the valve fills it,the water freezes,the cubes dump out and it fills again,most of the time it's either the ice maker or the water valve,if they changed the ice maker and the board all that's left is the valve or a broken wire somewhere in the ice maker harness
Feb 11, 2011 | Refrigerators
Ice maker not producing ice. Tried everything in the Troubleshooting section of Users Manual. Replaced water filter. The front water dispenser is working.
the most likely thing would be a bad water valve.try to reset the ice maker and watch to see if the tray fills up the fill tube could also be blocked with frozen water.the last thing is simply a bad ice maker.
Sep 19, 2009 | KitchenAid Superba Architect KSCS25INSS...
My icemaker is not working. Water not filling tray
Probably the valve that feeds water to the ice maker leaks and this water freezes up at the filling tube to the ice maker and the water doesn't go through, but if the filling tube is not frozen and the ice maker doesn't call for water the problem is in the ice maker inside board ,if so you should replace the ice maker.
Jul 14, 2009 | Refrigerators
Ice maker tray does not fill with water
replace the duel inlet water valve on the bottom back of frig.,one side has failed-mike
May 22, 2009 | Kenmore Refrigerators
Sub-Zero 632 Ice Maker Leaking into Ice Bucket
Ice Maker is overflowing and leaking into the ice bucket: There are several things to check for.
Go for the easy stuff first, make sure the icemaker is level, some of the plastic liner fridge's will move and allow the icemaker to tilt over and leak. Other troublemakers..... the fill valve
staying on and over filling the icemaker..... the finish sometimes comes off the icemaker body and all the ice cubes don't come out. This will allow the new water to fill on top of an icemaker
that still has a ice cube or two left inside the body, if you have had trouble with black specs in your ice cubes, this may have been the beginning of your finish problem on the icemaker body.
On the module style ice makers (Whirlpool, Maytag Family, Sub Zero) the printed circuit in the
module head often wears and the contacts become too long and allow the icemaker to over fill = new ice maker or new module head.
Older style icemakers: This gear is bad for breaking and the icemaker quits turning to eject the ice.
You can remove the front cover to see the gear.
This is a common parts breakdown of the older style icemakers
Water fill volume: The water fill adjustment screw will change the fill volumes by changing the fill time.
One half to one full turn usually ( approx ) is equal to 20cc ( 0.68oz ) to 40 cc.
The correct fill is usually 130 to 150 cc ( 4.5 to 5.0 oz ).
When a water valve is replaced the fill volumes must be re-checked!
http://www.SubZeroLosAngeles.com
________________________________________
Sub-Zero Service Experts in LA Metro
Aug 15, 2008 | Sub-Zero 632 / S
Ice machine not making ice
Hi, everak11,
Three possible solutions for you.
1: No water coming in from inlet valve. Check voltage on inlet if you have voltage and no water then replace valve.
2:Icemaker not cycleing. Lift the arm on the icemaker to shut it off and leave it for about an hour. Come back in and turn the icemake back on by lowering the arm. If the icemaker does not begin a new cycle and the arm start rising then the problem is most likely an icemaker. Replace Icemaker
3:Refrigerator not cold enough. If the freezer is not getting cold enough the icemaker will not cycle. Check the temperature in the freezer and make sure it is getting down to 0 degrees. If not then you may have another problem with your refrigerator. I hope this helps you, Let me know if you have any other questions or symptoms. Mike
May 08, 2008 | Refrigerators
Ice Maker Overflowing
i would recommend changing the water valves as they may be sticking or leaking now you can take the icemaker loose get a small baby bottle short the terminals to cycle water fill catch it with the bottle and see how much water it dumps should be about 4 ounces if the valve leaks will over fill the ice maker over a period of time say the valve is leaking a few drops at a time and the bail arm has the icemaker shut off because its touching ice in the bin but the water just keeps dripping down the fill tube till it runs over did you replace the whole icemaker or just the motor module
Jan 01, 2008 | Maytag MSD2434GE Side by Side Refrigerator
Refrigerators Logo
73 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
