Question about Joyetech eGo-t 1000 mAh battery
Is there a code when barttery light bliks three times?
MY LIPI PB2 PASSBOOK READY LED CONTINUOUSLY BLIKS WHEN I SWITCH ON MY PASS BOOK PRINTER
Olivetti Printer Is Required Calibration
1 Open Your Cover Of Printer
2 Than Move Head Left Side
3 Than Push three Key Than Printer Power On
4 Just Some Beep Is Comeing
5 Close Cover Of Printer
6 Press Station 1 Two Time
7 Than Insert Blank Paper
8 Press Station 2
9 Printer Removed The Paper Automatically
10 Than Again Insert Paper
11 Printer Some Printing
12 Than Printer On/Off
13 Than Printer On
Your Problem Is Solved
Regards
yogendra Sharma
Jul 08, 2012 | Office Equipment & Supplies
2000 tacoma wo't start. Turn key nothing. Will rool off and start. New barttery
Could be your starter. If you turn it and it doesn't crank, should be the starter.
Jan 14, 2011 | 2000 Toyota Tacoma PreRunner
Codes 26,28 and 40 on a 94 BMW 525i
You are miss reading the code light, the codes start with a 12 and then the number. to bring them up you need to turn on the ign. press the fuel peddle to the floor 5 times quickly, the light will stay on for 5 sec. then out then on for 2.5, then off for 2.5, your codes will come next if any, there will be four set's of blinks, first should be a 1 then usually 2 bliks then a set of 1 to 8 blinks then and then a set of 1 to 8 blinks, this will give you your code, this will repeat with the next code if there is one. the codes will be 12xx, 1444 or 1000.
May 27, 2010 | 1994 BMW 5 Series
LED bliks twice. stops for a second, and blinks
It's an error code. Check your manual under troubleshooting or call a Sony service shop with the model number and flash code.
Apr 06, 2010 | Sony Televison & Video
Check engine light on 1998 Z3 BMW
BMW engine light
Comes on if DME engine management system self diagnostic fault detected. Will stay on until codes are called up and memory erased.
With OBD read the code as follows. Turn on ignition key, press accelerator pedal to the floor five times within 5 seconds. The check engine light will remain on for 5 sec , blik off, come on for 2,5 sec, go off for 2,5 sec and fault code will begin to flash. If more than one fault exist 2nd fault code will be separated by 2,5 sec pause. after fault codes there will be a 0.5 sec flash and light will remain off. to read codes again do procedure again.
Canceling of codes. make sure fault code is present (short blink and light goes out for long period), depress throttle pedal for at least 10 sec. read fault codes again and check for code 1444 (no faults stored.)
Check also the following, fuel pump, oxygen sensor, fuel injectors, engine coolant temp sensor, idle speed control valve, mass airflow sensor and too many other things.
Jun 16, 2009 | 1998 BMW Z3 Roadster
Check engine light
BMW engine light
Apr 12, 2009 | Pro-Fit Pro.Fit Bm 51 97 Bmw...
Six (6) blinks on the Timer/Standby led
6 blinks means lamp thermal fuse blowing, replace thermal fuse.
See here
Aug 30, 2008 | Sony KP-57WS500 57" Rear Projection...
Sony KDF-E50A10 Green picture.
For BnrMan213,
I believe your issue with Light engine.(KDf-E50A10) If you have warranty on this unit contact seller.
Good luck
Dals123.
Same unit different problem
Customer replaced Lamp ***'y still unit bliks, there is two reason.
1.if your lamp door not closed properli it will blink.
2.watch for ballast ***"y fires the triger to on the Lamp? if not your old lamp is good repalce Ballast..
Good Luck
Dals123
Jul 31, 2008 | Samsung HCN4226W 42" Rear Projection...
Apex Digital GB4308 remote
Programming the Remote Control Remote-control switchover Press VCR/DVD, SAT/CABLE or AUX to select the device you want to control. To program the remote control Press and hold VCR.DVD, SAT/CABLE or AUX for over 2 seconds until the LED on the remote control turns off. Release the button the LED will light again (the remote control enters the PROGRAMMING mode). Enter three-digit code number for your equipment. If the correct code number is entered, the LED blinks three times. If you enter a code not listed below, or you press any other buttons than SEARCH and 100+, the LED turns off. To search codes Press ad hold VCR/DVD,SAT/CABLE or AUX for over 2 seconds unil the LED turns off. Release the button (the LED wil light again) and the remote control enters the PROGRAMMING mode. Press SEARCH. Press CH+/- to search codes downwards or upwards. Each time you press CH+/-, the code number decreases or increases by 1 while the remote control sends the code number for POWER button on your device. If the desired code number is found,press 100+ to program the code for your device until the LED blinks three times.Then the remote control exits from the PROGRAMMING mode and returns to norml operation. Or press any other button to exit from the PROGRAMMING mode after the LED blinks rapidly eight times, and the operation is not active. To check the current code number Press and hold VCR/DVD, SAT/CABLE or AUX for over 2 seconds until the LED turns off. Release the button (the LED will light again) and the remote control enters the PROGRAMMING mode. Press 100+ . You may read the code numder according to the LED display status as follows. * If there is no operation within 20 seconds during the steps mentioned above, the remote control will automatically exit from the appropriate operation. Code Number First - digit 0 1 0 1 Second - digit 0 0 4 5 Third - digit 0 6 3 0 First - digit Blinks rapidly once Blinks once Blinks rapidly once Bliks once Secod - digit Blinks rapidly once Blinks rapidly once Blinks four times Bliks five times Third - digit Blinks rapidly once Blinks six times Blinks three times Bliks rapidly once
Jan 05, 2007 | Apex Digital GB4308 43" Rear Projection...
Joyetech eGo-t 1000 mAh battery Logo
305 people viewed this question
Top Joyetech Electronics - Others Experts
Are you a Joyetech Electronics - Other Expert? Answer questions, earn points and help others
