Question about Vacuums
My vacuum just shut off. There's power to the outlets. vacuum is one year old
  • Vacuums Master
  • 1,510 Answers
If it comes back on after while it is probably overheating due to clogged filters or an obstruction. If it's intermittent it may be an electrical short somewhere.
Posted on Apr 07, 2015
2 Suggested Answers
SOURCE: Kenmore 33721 does not start
Same thing happened to me. After taking the cover off I noticed a wiring diagram on the inside cover. There is a fuse between the on/off button and the motor, sure enough the fuse had blown. There is no mention of a fuse in the manual! The vacuum works great again.
Posted on Sep 02, 2007
Vacuum works but won't shut off
Switch is broken in the "ON" position. Just plug it into a power strip outlet and use the switch on the power strip outlet to turn it on and off.
Nov 08, 2015 | Vacuums
Vacuumwon'tshutoff
It works on battery?
Because if it works fine with the power cord, you can turn it off removing from outlet..
NOT ILLOGICAL: I've been using a vacuum this way sice about 10 years.
Nov 08, 2015 | Kenmore Vacuums
Our cv450 wont turn on when plugging into the wall or using the rocker switch on the unit, there is power to the outlet, the unit is 12 years old,any suggestions to further diagnose?
Check the filter. If it's dirty, the motor will overheat, resulting in the machine shutting off.
Rinse thoroughly in warm water, and allow to air dry thoroughly before reinstalling. I recommend having two filters so you have one to use while the other is drying.
Other problems are possible, but generally entail taking the vacuum to a repair shop for diagnosis and repair.
Feb 12, 2011 | Broan-NuTone CV450 Central Bagged Central...
I have a Riccar 8750, when I plug it in any outlet and turn on the headlight does not come on and the vacuum does not turn on. The reset button does not seem to help. It worked fine when I shut it off last...
An 8750 is likely at least 20 years old but still may have lots of life left. I still have 8600 series Riccar vacuums brought in to my vacuum shop for service. You may have a loose wire, bad switch or power cord. I would take it to my local Riccar dealer to diagnose and repair.
Jan 07, 2018 | Riccar 8650/8625 s Vacuum
It electrically stopped- no blockage or horrid noise just won't work! About 4 years old - and yes I have changed the fuse. Any answers?
have an electrician check the switch on the vac. probably went bad. also look for broken wires or connections.
you have tried a different outlet, right? also inspect power cord for any damage.
Apr 19, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Oreck XL2 Ultra
I have the same problem and mine is less then a year old.
Aug 21, 2008 | Oreck XL Ultra Bagged Upright Vacuum
Hoover only two years old an stopped working!
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=40540&thid=564949
Hoover only two years old and it stopped working!
Posted by baby_nurse on May 02, 2008
My Hoover self propelled wind tunnel was working great until a couple of days ago when it started shutting on and off while vacuuming. I thought it was the outlet but when I plugged it into two different outlets it did the same thing. Then finally yesterday it just stopped working it won't even turn on when plugged in. I thought it was the switch but it is not. Is it the motor? Has the motor burned out? Do I need to buy a new one? Help!!
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Hoover U6616-900 Windtunnel Bagless Upright
I think you are right, if it is not the switch then it would be the motor. Does it smell bad like a burning smell? If so it is definitely the motor and then @ that point you may want to get an estimate for motor replacement, and keep in mind of what you spent on the vacuum versus what the cost of repair might be. My own rule of thumb is if it cost more than ½ of the price I paid for it then you have to decide – do I want to pay the repaired cost for the vacuum or do I want to purchase a new one. Just a suggestion... You may want to check with your local vac dealer. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Don – The Vac Man
Go Ahead. Use Us.
May 02, 2008 | Hoover U6616-900 WindTunnel Bagless...
Hayden Premier Motor Pulses
there are several possibilities here, its possible the low voltage relay is bad, possible that the carbons on your motor are worn, or may even be a thermal sensor in your unit shutting it down, ive even seen improper assembly of motor which cause wires to be pinched and have shorts in them from the manufacture, course always check your power cord to the wall and test your outlet with some other appliance.as you can see several possiblities, most of which unless your knowledgeable in electricity i wound not atttempt on my own. highley reccomend taking to a vacuum cleaner shop to have checked out at least, they may even be able to sell you the part to fix it yourself
Mar 24, 2008 | Hayden Industries SuperVac 6000 Central...
Low voltage wiring
Probably just didn't wire the l/v side of the relay properly. Or forgot to plug the leads from the outlets back in to the vac after you got it all hooked back up. Folks do it to me all the time and then make like it's my fault! Ha ha.
Jump the l/v contacts inside the CV. If it goes: trace outward toward the outlets to see if something shook loose while it was apart. If you can't jump the l/v with a plier/screwdriver at the CV or even inside it, you have an issue on the board (either how you've connected to it or it's defective itself). The prob is that there's dozens of diff board configs, plus the relays and transformers weren't together on the same board in the old days. If you've got one of these models with a massive transformer separate from the relays get out the test leads and make sure you've got adequate voltage coming out of her to power the relay coil.
Aug 26, 2007 | Broan-NuTone CV750 Central Vacuum
Apr 23, 2007 | Kenmore 33721 Upright Vacuum
Vacuums Logo
64 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
