Question about Dishwashers
How do I sort er 07 code - Dishwashers
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 183 Answers
Post way more information. Make, model,etc.
Posted on Apr 05, 2015
The code ER CO keeps coming on, on the display panel. The fridge and freezer still work but the code keeps coming up. Any info on that?
LG Bottom Freezer Refrigerator Error Codes Sears PartsDirect
Select
Use our model number finder
Choose your product type
Common model number plates
Close
LG Refrigerator Error Codes
These error code explanations can help you diagnose a problem with your LG bottom-freezer refrigerator. For repair how-to help, visit the PartsDirect repair help section, which includes repair help for washing machines, other major appliances, lawn and garden equipment, garage door openers, vacuum cleaners and more. You can also search for owner's manuals, get advice from an expert and find refrigerator replacement parts. Error Code
Er FS Error Code
Er rS Error Code
F dS Error Code
r dS Error Code
Er HS Error Code
Er IS Error Code
Er SS Error Code
Er rt Error Code
Er It Error Code
Er gF Error Code Error Code
r dH Error Code
Er IF Error Code
Er FF Error Code
Er CF Condition
Condenser fan motor is defective Check/Repair
Condenser fan motor, wiring or the control board Shop Parts
Condenser fan motor, Power control board, Wiring harness Error Code
Er CO Condition
Communication error Check/Repair
Communication error between main board and display board Shop Parts
Display control board, Power control board, Wiring harness
Jul 16, 2015 | LG LFX25974ST 24.7 cu. ft. French Door...
What means er 07 at Ariston electric oven FD 87.1 E and how can I fix the problem?
THE E USUALY STANDS FOR ERROR THE O7 IS THE ERROR WHICH COULD BE IN THE OVEN,BROILER, OR BURNERS, OR EVEN A TIMER. LOOK UP ON LINE TYPE IN FD87.1 ELECTRIC OVEN MANUAL TO SEE IF A MANUAL IS AVAILABLE THAT YOU MAY BE ABLE TO FIND THE PROBLEM.
Jan 31, 2015 | Ariston Technologies Ovens
Er is on my refrigerator? what does that mean
Does it just show "er" or does it have "er" and two more characters? The "er" means there is some sort of problem, and the other two characters will indicate what kind of problem. If it's just showing "er" alone, I not sure what that means.
May 31, 2014 | LG LFX25960ST Stainless Steel French Door...
I have an error 04 showing on my dishwasher, and the cycle will not run. Please help!
dryer damper problem. there is another post that will help from electrolux personnel.
Thank you in advance for allowing Electrolux to assist you in
this matter.
I apologize for the inconvenience and concerns this dishwasher unit has been causing you. Unfortunately the error "E04" code does indicate an issue with the drying damper. Now this is something that a technician would have to assess because wiring is needed to be checked.
Check wiring between Main Control Board and upper fan. If correct, replace upper fan.
If your unit is brand new it is covered under warranty and you can choose to contact your dealer for a repair technician, or visit www.electroluxappliances.com/servicelocator to find a listing in your area.
Kindest Regards,
Chris Polk
Online Outreach Representative
Electrolux Major Appliances
Er 01
Leak Detector - When water is detected under
the tub.
Er 02
Thermistor - When thermistor/turbidity module
fails
Er 03
Wash Pump - Wash pump not operating
Er 04
Drying Damper - Drying damper not operating
Er 05
Upper Fan - When in the dry cycle, the control
board does not receive proper speed feedback
from the upper fan
Er 06
Lower Fan - When in the dry cycle, the control
from the lower fan
Er 07
Drain Valve - When in the drain mode, the control
board does not receive proper position feedback
from the drain valve
Er 08
Tactile or touch switch - Control board has
verified a switch on the user interface is bad or
shorted
Er 09
Communications - Communication failure between
main user board and power supply
Er 10
Mains Relay - Failure in the mains power relay
Er 11
Drain Valve - Time out before finding a state for
the drain valve
Er 12
Drain Valve - The drain valve is running when it
should be off
Er 13
System wide - Lost control of the State Machine
Jun 23, 2011 | Electrolux Dishwashers
Er 07
i can't help you with this brand but in almost all oven of this type . inside behind the display board is a tech sheet. it will have all the answer's fault codes are a common way for self diag ovens and other appliances .. mm
Jul 14, 2010 | Neff B1421 Electric Single Oven
My Whirlpool Air Conditioner has a blinking light that says ER and does not start. It is a Whirlpool split type Air Conditioner s-07-was5009wca
some times just turning off the main breakers to all of the units and then turning it on it may cleer that falt code but if not let me know what it does after you do this
Apr 16, 2010 | Heating & Cooling
ERROR E32 SHARP ER-A220
hi. E34 means the machine has had a limit programmed into it so that a maximum price can be entered. this stops staff accidentally charging say $1000 instead of $100. Try entering a lower price. The limit can be removed if desired. Mark
Jun 13, 2009 | Casio Parts Cash Register PC Desktop
Error codes er o7, er o9
Had exactly the same problem during Oct 09. Spoke with SAGEM all sorts of solutions no joy. Spoke to currys and tried a new power source and it works fine. Ordered a new source via SAGEM approx £15 and now have a working box. Saved having to buy a replacement and all my recordings are still in tact.
Apr 11, 2009 | Televison & Video
Geen instalatie code
ga naar thepiratebay.org en zoek naar nocd cracks.
hoop dat het werkt
Feb 28, 2009 | EA Sports Tiger Woods PGA Tour 07 for...
Universal remote control ER 480
The ER-480 doesn't have a zero button. It only has numbers 1 through 12. How do you enter codes with zeros? I am trying to tune in a Bush DVD player, but I am having difficulty doing so. Can anyone help? Many Thanks in advance.
Jul 18, 2008 | Televison & Video
Dishwashers Logo
51 people viewed this question
Top Dishwashers Experts
Owen Barnes
