Question about Sharp "LC-65E77UM LCD HDTV"
I was watching when I listen a " CHASSST" and then no more power, on image, all is in dark
    Master:
  • 531 Answers
Most likely the power supply board needs to be replaced.
If you don't know what you're doing, DON'T OPEN THE TV UP TO FIX IT, THERE ARE HAZARDOUS VOLTAGES ON THE POWER SUPPLY BOARD, EVEN WEEKS AFTER THE TV IS UNPLUGGED!
If you don't know how to do it yourself, find some local Electronic repair shops, get quotes, try to find reviews on the shops.
Posted on Sep 12, 2016
I have a 32" Samsung LED TV with not picture. Audio is working.
Do flashlight test - if you can see image you need t con board. If no images seen, inverter board. TV Parts Universal TV Stands DLP Chips ShopJimmy
Sep 18, 2017 | Samsung Televison & Video
My casio protrek 2500t watch is in power saving mode but even after keeping in dark for hours between 10pm and 6 am the display does not go off.Please help.
I own the same PRW-2500-1A (all black).Check if under the hours reading, PS appears.If yes,power saving function is activated.
Normally, Power Saving Function is enabled automatically (if activated) if the watch stays in complete dark for sometime.If after a couple of hours in the dark the watch comes suddenly under bright light,the display goes on immediately.Hour interval (10pm-6am) has nothing to do with Power Saver.
Try the following:
a)Deactivate and reactivate (or vice versa) the PS.
b)Leave the watch in the dark for a couple of hours .Then,still in the dark,try,using a very low power light (just that you can,barely read) to check if display is blank.If not you may have a problem with the light sensor found at the bottom of the display.Will be a very rare case but you have to take the watch to a CASIO authorized service.
Apr 29, 2016 | Casio Watches
RCA Model# LED32B30RQD Tv has sound no picture. Picture went black while i was watching it. Can see image in dark room with flash light. TV has power supply board, video board. Start with video board?
That board right in the middle is the power board and it powers the LED backlights. This is a common failure on this model and the board is not in stock in most places.
Mar 17, 2016 | RCA Televison & Video
Tv has died
When the TV is on, if you look at the screen and can see dark images, then you will need to replace both the inverters. The inverters drive/power the back light inside the LCD to show the images. You may have to try and different channels and or inputs to truly see if you can see dark images while the TV is on. If you are hearing audio from a channel or an input then you should be able to see the dark images if just the inverters are bad.
If the screen is dead black without any dark images, then typically your LCD screen/module is bad.
If the TV powers up (power supply is good), you have audio and the remote will work with the TV (the main board is good), the only parts left is the inverters or the LCD screen/module.
I can get you LG part numbers if you need them.
May 21, 2010 | LG 42LC2D 42 in. LCD HDTV
Hitachi L32HO1UA HD TV blurred images very dark unwatchable scree
Hi Ellie!
Maybe in the manual you can find any information how to resolve this problem.
On this page of the manual there are shown most common receprion problems: http://manualsbrain.com/ru/manuals/979781/?page=72
Apr 26, 2017 | Hitachi 61SWX10B 61" Rear Projection...
Dark area on screen.
i have had the same problem with the dark patch and found out it was because i had a speaker sat too close to the tv!!!
Apr 04, 2009 | Maxent MX-26X3 Television
Ultravision image dark
Good Day, tfarmer;
Since you have replaced the lamp, which is the normal cause for a dark picture. Have you checked your video settings?
The brightness level should be set at about 55 to 60%, the contrast should be set at about 90% and the video temp should be at normal or high.
If all these are set about this way, then I would think that the light engine might be going bad.
Good Luck, big IRISH.
Jul 29, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
NEc plasmasync 42mp2 - dark screen and in the top few pixels show the image
It's either the Y-main or logic board but you would need to do some extensive testing to know for certain which one... It's not the screen..
I would strongly recommend you take it into a shop and have a Tech test it and give you an estimate..
Bill
Nov 17, 2007 | NEC PlasmaSync 42MP2 42 in. Television
Problem with picture it is very dark
hi,
Just a guess,under the power button, inside the the flip[ down cover is a light dimmer,you can turn this on and off,in advanced settings under video,a flash light will trigger the sensor to see if it works the dimmer,if not it could be that circuit or your power supply needs work,I hope this helps!
Dec 01, 2006 | Hitachi 43FWX20B 43" Rear Projection...
Sharp "LC-65E77UM LCD HDTV" Logo
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
