Question about JVC Televison & Video
I think I confused the processor pushing buttons listening to a record the music stopped I hit the delay button as well with many others trying to acheive the sound I wanted
Red light clicking on /off in the standby window mode jvc - 809vtn
Benimur
  • 6966 Answers
SOURCE: Sony KDL-40S20L1 Flashing Standby Led, No pic, No Sound
Hi, If all else fails, try do a hard reset. You can verify from your manual, but in some units, this is merely unplugging the unit from mains for a couple of hours. Try again, if it still shows error codes (blinking lights) you probably have to seek the services of a qualified professional. Hope this be of some help/idea. Good luck and kind regards.
Posted on Aug 26, 2007
SOURCE: lg plasma 50px4d-eb keeps going into standby mode
good grief - my TV just did the same thing - its locked in standby mode - I disconnected power several times - each time i reconnect the green light comes on for about a minute 9nothing happens on the screen) and then returns to the stanby mode
Posted on May 18, 2008
SOURCE: Sharp tv standby button wont switch on
have the same problem .please help.
Posted on Aug 31, 2008
SOURCE: Olevia 437-S11 stuck in standby mode
My classroom TV seems to be stuck in standby mode. Blue light is on but TV won't turn on either by push button or remote.
Posted on Nov 06, 2008
SOURCE: red standby light light blinking
there is in-line fuse that blowes,caused by the fan vents being restricted (smoking can be a big facter) the vents should vacumed a couple times a month. you will need to have it seviced (parts and labor cost me 270$
Posted on Feb 09, 2009
Ge adora washing machine beeps when pushing start with door closed
Hit the power button until there is NO display . Unplug and wait a minimum of 30 seconds , plug back in and within 30 seconds hit SIGNAL button then DELAY START button then SIGNAL button again then DELAY START button again. door should lock and display t01 It is now in test mode . There are 14 different test it can run through in this mode , but all we are trying to do is check for error codes now and maybe get you back to normal, So turn the knob one click clockwise and hit the START/PAUSE button and see if any error codes come up. To exit the diagnostic mode - hit signal button then delay start button then signal button then delay start button and you are out of service test mode and back to normal. Post any error codes.
Dec 07, 2012 | GE WSXH208A Front Load Washer
I've purched the Olympus digital recorder VN-100 VN-2000 a few years ago. I've never really used it. But i recently need to..and for some reason it cant record. Everytime I push the REC button ,the red...
take out the batteries , push the reset button, then put batteries back and try again.
If still not working properly , then it probably should go back to Olympus, if you bought it a few years ago , its probably out of warranty.
You can buy a newer model like the vn-6200-pc , which has way more memory and more features for much much less then it will cost to repair the vn-100 or vn-2000 , f
Dec 25, 2010 | Olympus VN-1000 Digital Voice Recorder
HOW DO YOU BURN A DVD ON A SONY DVD RECORDER RDR
Make sure your Sony input signal is on L1 or L3 (the inputs in back of recorder) or on L2 which is for inputs for cameras(located in front).Once you get a signal, you're where you need to be. Choose your recording mode for recording speed (pull down the flap on the remote control for this button and also the input button).
Choose from between1 hour and six hours. To archive really important stuff, stick with the first 3 speeds. TV recording can be on 3, 4 or 6 hour mode.
Push the record/pause button once. This will put the recorder into the record/pause mode and then it awaits you pushing it again to start recording immediately. Just pushing record will force the machine into a 3 to five second delay before actually recording anything so you might mess up and miss the first few seconds of your input. Suggest you use a dvr-rw or dvd+rw to practice on.
When your recording is done, just push the pause again. It stops recording but allows you to add more on to the first recording without starting a new chapter if you want. Just continue to release the pause button to continue.
If you are satisfied that you are finished, then push the pause button to stop recording. Wait for the info to be written(flashing message on screen). When it stops, you may play the dvd.
Notice- since the dvd has not been FINALIZED, you may only play it back on this unit without finalizing. It will not play on other dvd players unless you finalize it first.
To finalize, look on remote for the TOOL button. Press it once. Now push DISC INFO once. Use arrow keys and enter button on remote for the following. Scroll down to FINALIZE and press enter.
Use arrow keys to scroll to OK. push the ENTER button. Finalizing should take between 30 seconds and 2 minutes.
Warning- if titles or chapters are to typed in, it must be done BEFORE finalizing. Finalizing afterwards cannot be done.
Erasing can be done in part or all if using an RW+ or RW- disc
Dave
azsnoopy1@cox.net
Nov 19, 2009 | Sony RDR-GX300 DVD Recorder
Delay problem
Not sure how you are defining delay. Are you recording to the hard drive using the sound card as inputs? Are you listening to the speakers while you are recording or are you playing a recording back and there is delay or echo in that? PLease let me know
Sep 18, 2009 | Computers & Internet
I hit stop/start button, green light illuminates, hit again, green flashes, but no music. have tried volume controls and both sets of earplugs. i have confirmed that music is loaded.
If a green light is flashing on the player the shuffle button in the middle of the player is being pressed changing the players mode from continuous play to shuffle mode. To activate the player to listen to music you must hold the power button down on the right side of the player for about 3 seconds. If you need further assistance, please contact us directly at (808) 837-0074 or e-mail kevin@intova.net.
Thanks,
Intova
Jul 11, 2009 | Snap Sights H20 Man MP3 Player
Downloading instructions Delphi SKYFi3 unit
You can't download Xm programming, like you can from itunes, where you get a song in 3 or 4 seconds.
Do you mean record music? You must record realtime, either while listening or while the unit is idle in its cradle.
It's easy. while listening to the radio in the cradle (press mode repeatedly to get to Live XM mode), then press the center (play/pause) button.  the menu will pop-up, select Record.  It will give you the option for Song, Channel, and Session.  Just chose one of the first two and press the button.  You should see a microphone appear at the top of the screen.  It's recording.  Follow the same steps to stop the recording.  Setting up a recording session is self-explanatory once you get into that screen.
Oct 21, 2008 | Delphi SKYFi3 XM Radio Receiver
Hit wrong button
press and hold start/cancel button for 5 seconds and machine should reset
Jul 14, 2008 | Frigidaire Washing Machines
Not Able to Record/Playback
can't record on the my Olympus VN-1000
+ I press rec button and it just shows rec in display (no recording time is shown ONLY rec)
+ there is no play back  or stop function
+ i can only stop  rec by removing batteries (stop or play will stop rec only ONCE - but there is no  useful function - such as play or stop or rec.)
+ I tried all trouble shooting tips in manual  with no effect
+  i cleaned the spring contacts inside battery compartment that interface with the  batteries
+ it was barely used - and has not been used for a 1 year ( no batteries were inside it )     it was inside a drawer
THANK YOU
Jun 16, 2007 | Olympus VN-1000 Digital Voice Recorder
Televison & Video Logo
24 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
