Question about Keurig Coffee Makers & Espresso Machines
Hello. My Keurig machine does not come on anymore automatically when timer is set. What could be wrong and is there an authorized repair service in Montreal, Canada?
    Master:
  • 346 Answers
Do a search for nearest Keurig servicecenter.
Posted on Apr 04, 2015
Testimonial: "Okay.....thank you."
4 Suggested Answers
encyphered
  • 11 Answers
SOURCE: Grinder not working on my solis master 5000
Order the replacement boiler, (be sure to empty all of the hot water from the boiler first using the hot water function on the right side of your Solis) take your time and open the machine up, the top comes off. There are 3 mounting screws that hold the boiler in place, remove them, be sure to take hold of the boiler before removing the last mounting screw. Remove and replace the wires and 2 water hoses (w/clips). The orange wires the connect to a unique plastic harness are clipped into the harness. Look closely and you'll see a little window in the plastic harness at the end of each orange wire. Use a tooth pick or a pointed device and push the metal clips thru these windows, this unlocks the wires for removal from the boiler.
http://www.shop.partsguru.com/product.sc?categoryId=-1&productId=937
Good luck and Best wishes
Lane
Posted on Jan 04, 2009
heatman101
  • 43501 Answers
SOURCE: My Keurig machine turns off
Here is a tip that I wrote about how to registeryour Keurig Coffee Brewer, get manuals, and cleaning or troubleshooting guides.
KeurigRegistration, User Manuals, Cleaning, and Troubleshooting heatman101
Posted on Sep 11, 2011
spinella812
  • 4 Answers
SOURCE: water does not heat up
I found another entry online that mentioned that the Breville esp8xl has a connector to the heat chamber that corrodes and can become loose. Sure enough, my Breville esp8xl was fixed by opening it up--from the bottom, 8 screws on bottom, then two screws into the top from near the front, two at the back, and one under the lid, finding the blue wire with the loose connection, tightening the connection, and voila! my machine works like new.
Posted on Jun 09, 2012
Sharp 21ne61
Probable Causes:
(1) Sleep Timer has started (You should get a on-screen Notification in this case, before Auto Turn Off). Turn Off Sleep Timer to get rid of it.
(2) Something is wrong with your TV (Get it checked at Authorized Service Center if Warranty is active, if not, contact any Television Engineer or Electronics Engineer).
Mar 29, 2014 | Sharp Televison & Video
Model Number: mex731cas1 Brand: Electrolux Age:
Hello Tuomas, thank you for allowing me to assist you!
Based on the video you have provided, it shows that your laundry center is experiencing one or two things, an issue with the water valve or a faulty timer. I am fairly confident that an authorized service agent will be able to restore your appliance to its normal operating condition. You can often locate a qualified service technician on the manufacturer website. I hope this information helps to some degree.
Best regards!
Oct 22, 2013 | Frigidaire FEX831CS Top Load Stacked...
How do I get automatic timer off?
try turning on machine,
press menu until you come to auto timer, use plus/negative to adjust.then press menu until out of menu system.
Oct 15, 2013 | Keurig B50 Coffee Maker
Automatic Clean on Spot Bot 1200 dosent work
Ted, it can be bear when the auto settings aren't working. One of our service centers can inspect and fix any warranty repairs needed.
To locate a BISSELL Authorized Service Center, please click on the following link:http://www.bissell.com/service-centers/&=ccsocial
Oct 22, 2012 | Bissell SpotBot Robotic Wet/Dry Vacuum
My Keurig B100 machine is not pumping water thru cofee
Hello Jack, thanks so much for purchasing my service. Sure I can help you no problem. This is common, here is one of my tips I wrote that will help you solve this problem. Get back to me if you have anymore problems. Thanks So Much Mike
Here is the link for my Tip on solving this problem:
How to descale espresso machines.
Oct 15, 2011 | Coffee Makers & Espresso Machines
My Keurig machine turns off by itself on a timer that I did not set. I do I take it off the timer?
Sep 11, 2011 | Keurig B70 Coffee Maker
It doesnt shut off automatically anymore
Sound like a problem with the programming.
Your Instruction Booklet can be found here:
http://www.keurig.com/customer-service/brewer-registration-and-support/~/media/Files/Keurig%20Brewer%20Manuals/Breville_BKC700XL.ashx
Make sure you review the setting and programming instructions.
Mar 19, 2011 | Breville BKC600XL Coffee Maker
Coffee Makers & Espresso Machines Logo
77 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
