Clicking on / off red light in the stand by window
I was playing a record listen to the music the sound was baffled.. I started pushing the processor button changing it to sea level and other options.. I was trying to find the right sound I wanted to accomplish ... I pushed delay button, well I push all of the buttons one after the other, trying to get the right sound .... suddenly the music sound stopped ,the red light came on in the stand by mode window,,, clicking red light on and off
Nightdiver
  • 116 Answers
SOURCE: Won't Power On...
Hello degaff, This is what I would do to try to determine the problem: 1. Disconnect everything from the receiver. The only thing connected should be the power cord. Make sure the power cord is disconnected from power for at least 30 minutes in order to reset the internal electronic software. 2. Then, power it up - still nothing else connected. If it powers up normally and "looks" like it is going to work, then turn it off and connect only the right speaker to its amplifier and try again. If it still looks normal, then turn it off and connect the DVD or CD player and run some music through that speaker. If it still looks normal, then shut it off and connect the left speaker, etc... In other words go one-by-one in checking it out. 3. If it does NOT power up after step ONE, then there is a problem internally. If it powers up only to shut down again, there is still a hardware problem internally. The usual cause is shorted output transistors. And the normal cause of shorted outputs is a short on the speaker line, a short inside one of the speakers or overdriving the amplifier for too long a period of time. If the outputs need replaced, then it will cost an arm and a leg to get them repaired, and you are better off replacing the unit. The clicking sound, by the way, is the power relay which turns the power transformer on. And if there are faults in the amp, speakers or wiring, the protection circuit shuts the relay off; that is the clicking sound you hear. Please let us know how this works, and if we can help you any further. Best regards, nightdiver
Posted on Aug 23, 2006
SOURCE: stand by button flashes but receiver wont turn on
I have vsx-d812 that has an AMP ERR in error menu. the troubleshooting was found to be Q696 and Q697 in the DC prot. area on "C" board, up near front toward diplay in center of c board. You can get access to error codes on VSX pioneer unit by pressing "enter" and "adv. surr." simultaneously for 2 sec. The display should show what error code you are experiencing. I believe there are three diff. error codes. 1) AMP ERR 2) OVERLOAD 3) BOAD ERR (not mistyped) I hope this helps pinpoint error code for ya.
Posted on Jan 12, 2008
Foxyjay
  • 13 Answers
SOURCE: Power Button Flashing Red
If your amp looks like it's going to work as normal (ie the front display lights up as it should etc), but then the amp goes into protection mode when the anti-thud circuit times out, then I know what's likely to be wrong.
It's one of the power amplifier channels which has gone faulty.
I just found this out after having this problem with my AVR-1906.
I took the amp apart and de-soldered the suspected channel power transistors (centre channel in my case).....and hey-presto! it fired up as normal (obviously the centre channel would be out of service).
I have ordered the replacement transistors from Farnell (UK) at a miserly cost of around £2-£3 each.
Just waiting for them to arrive.
An alternative is, if you don't use all your channels, take the transistors from a known working but not needed channel and swap them over with the duff ones.
Hope thats of use!
Posted on Aug 16, 2008
SOURCE: TUMBLE DRYER SUDDENLY STOPPED WORKING.
I have a kenmore dryer, bought used, and it was working good but it now wont turn on. The light inside comes on when the door is opened, but no matter what the setting, it wont start. It's the Kenmore 70 series, front loading electric dryer. Is there a fuse or reset button I can try?
Posted on Sep 22, 2008
SOURCE: Not Able to Record/Playback
can't record on the my Olympus VN-1000
+ I press rec button and it just shows rec in display (no recording time is shown ONLY rec)
+ there is no play back  or stop function
+ i can only stop  rec by removing batteries (stop or play will stop rec only ONCE - but there is no  useful function - such as play or stop or rec.)
+ I tried all trouble shooting tips in manual  with no effect
+  i cleaned the spring contacts inside battery compartment that interface with the  batteries
+ it was barely used - and has not been used for a 1 year ( no batteries were inside it )     it was inside a drawer
THANK YOU
Posted on Nov 23, 2008
MATTEL POCKET UNO GAME INSTRUCTIONS (how to change the number of players)
Here is the information you requested:
GAME OPTIONS The default options for Electronic UNO® are a Level 1, 4-player game with the sound on. If you want to change those options, this is how you do it:
1. Press the Menu button and "New Game" will flash. Press the Select button and "New Game" will stop flashing-Press again and it will go out. If you press Enter/Play with "New Game" showing you will start a new game.
2. Press the Select button then press Enter/Play. The Player 1 icon will flash.
3. Press the Select button to cycle through the number of players, represented by the 2, 3, or 4 icons, and press enter when you choose the number of players you want.
4. After the number of players is selected the, Level will begin to flash. You may change the level by using the Select button to cycle through Levels I, II or III. When you see the level you want, press the Enter/Play button.
5. Once you have selected the level, you will see the musical note icon flashing. This is the sound indicator. You may turn the sound off or on by using the Select button to make the note appear or disappear and then press the Enter/Play button. If you can see the musical note the sound is on. The Hi Score will be displayed and the player that achieved it. Press Enter/Play to start or return to your game.
6. You may start a new game, check the Hi Score or turn the sound on or off at any time by hitting the Menu button.
Jul 15, 2017 | Mattel Toys
Tip
To connect a music player or other audio device to your laptop
<br />If your laptop has a line-in jack, follow the instructions above for connecting a music player to a desktop computer. But to connect a music player or other audio device to most laptops, you'll have to plug it into a microphone jack. To do so, follow these steps:<br /><br />Click to open Sound. <br /><br />Click the Recording tab, click Microphone, and then click Properties.<br /><br />Click the Listen tab, click the Listen to this device check box, and then click Apply.<br /><br />Click the Levels tab and make sure the Mute button looks like this . If the button looks like this , click it to turn on sound for this connection, and then click Apply.<br /><br />Play some music or other sounds on your device to test the volume coming through your computer speakers. Select the slider under Microphone, drag it right or left to increase or decrease the volume of your audio device, and then click OK. You might also want to adjust the volume on your device.<br /><br />Note<br />If you hear noise coming out of your speakers, try reducing the volume on both the music player and in the Levels tab. The microphone jack is designed to receive sound from a microphone, which is different than sound coming from a music player
on Dec 14, 2010 | Computers & Internet
Tip
To connect a music player or other audio device to your desktop computer 1After...
    1After you've plugged a music player or other audio device into the line-in jack and turned the device on, follow these steps:
  1. Click to open Sound.
  2. Click the Recording tab, click Line In, and then click Properties.
  3. Click the Levels tab and make sure the Mute button looks like this
  4. If the button looks like this , click it to turn on sound for this connection, and then click Apply.
  5. Click the Listen tab, click the Listen to this device check box, and then click OK.
    Notes
    • If you don't hear anything, make sure the volume is turned up on the device.
    • You can also change the line-in volume on the Levels tab. Select the slider under Line In, drag it right or left to increase or decrease the volume of your audio device, and then click OK.
How to record music on youtube
After downloading, install and launch the program.
On the main interface, click gear icon and select "Settings" from the menu. In the pop-up window, set the input audio source as "System sound".
Play the YouTube video, back to the recorder interface and click red record button.
While you record YouTube audio online, the software will identify the music info.
Hit "Stop" to end recording, then the recorded audio goes to the target folder.
go this link to download
https://www.apowersoft.com/record-audio-from-youtube.html
Jun 12, 2017 | YouTube Computers & Internet
Why dont i have an internal recording device?
you have an internal recording device. It consists of a built-in webcam and microphone. to make a recording, use the cyberlink webcam program that's pre-installed on your laptop. you'll find it listed somewhere in the start / all programs list in windows 7. also, for sound recording only, the windows 7 audio recorder is located under start / all programs / accessories / sound recorder. select it and click the red record button. also, windows 7 has a feature or program called problem steps recorder. it records activity on your screen including mouse movement. i don't know if it records sound. to access it type psr in the search window and select psr in the search results, then click on start record.
Apr 14, 2014 | Acer aspire 5733z4851 intel pentium...
Sound seems echo when i play music
super...... and need more specific information to what software using to play music and for the windows 7 fault here's the tip: first go to volume button in bottom right click it and open up speakers and go to enhancements and disable all enhancements and go to levels and change the levels L and R equally and if not fixed mail to me adishesha01@gmail.com
have a good day bro :)
Mar 17, 2014 | Lenovo Computers & Internet
Hello, I have a new black jack interface and Sony Acid studio on my PC with Windows XP. when I plug in an instrument, I can hear it in the headphones of the Blackjack, but not in the computer speakers. but...
Look at the setups for voice and audio in the Windows control panel, "Sounds and Devices". Make sure the devices are set to the sources and destinations you want... This is not automatic and is a pain when you are going back and forth from recording and playing...
Aug 19, 2011 | Mackie Onyx Blackjack Premium 2x2 USB...
I tried to record a song but there was no sound that came out it just was recording but when i tried ti listen there was nothing recorded. How can i record something on the MP3 player and/or reset it again...
If the recording you made is not in a mp3 file format then the player cannot play that song/music.
To convert music files and CDs to play on a MP3 player, please click on this link and follow my instructions :-
Normal 0 http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
Oct 04, 2010 | Insignia NS-DV2G MP3 Player
My microphone isn't working. I've checked the control panel, and I have the microphone not muted and set at medium level. This happens a lot, and I can never remember what it is I am doing wrong.
Hi ,
Test the record function on the notebook PC
  1. Click Start , then Programs , Accessories , Entertainment , and then Sound Recorder .
  2. Click Record (the red dot) and speak into the microphone.
  3. When you are finished recording, click Stop (the gray rectangle).
  4. To play back the recording, click Play (the gray arrow pointing to the right).
  5. If the recording does not play back, continue to the next section of this document.
Step 2: Checking microphone settings
  1. Click Start , then Programs , Accessories , Entertainment , and then Volume Control .A Volume Control or Master Volume window opens.
  2. Click Options , and then Properties .
  3. Select Recording , and make sure Microphone is selected.
  4. Click OK . The Volume Control window should change to a Recording Gain Control window.
  5. Click Options again and then click Advanced Controls . If Advanced Controls is unavailable, then an alternate microphone is not available. Proceed to the next series of steps.
  6. Remove the check next to Alternate microphone , click Close , and test the microphone. If there is still no sound, continue to the next step.
Step 3: Ensuring the correct recording device is selected
  1. Access sound properties:
    • In Windows XP, to access the sound control panel applet, click Start , then Control Panel . Click Sounds, Speech, and Audio Devices , and then click Sounds and Audio Devices .
    • In Windows 95, 98, and Me, click Start , Settings , and Control Panel . Double-click Sounds and Multimedia , or Multimedia . The Sounds and Multimedia Properties window opens.
  2. Click the Audio tab.
  3. Under Sound Playback , select the audio device that is installed on the computer (there should be only one).
  4. Under Sound Recording , select the audio device that is installed on the computer. It should be the same as the listing under Sound Playback .
  5. Click OK .
  6. Close the Sound and Multimedia Properties window and test the recording. If there is still no sound, continue to the next step.
Kindly send me you valuable Feedback.
Jan 29, 2010 | Sony ACID Music Studio 7
I have just bought a Technics SH 8046 computer graphic equalizer WITHOUT an instruction manual,HOW DO I PROGRAMME IT!
Darren Kelly-themasterofthrowdown...I've had mine since they came out in 1985. Here's what you do...Each of the 4 channels on the upper right function as an individual equalizer. You set each channel one at a time. So, you have the ability to change channels on your e.q. without resetting your faders(you just push ch. 1 2 3 or 4) and the sound of the music will change according to how you set ch 1 2 3 or 4)DON'T UNPLUG THE SH-8046 WHILE THE MUSIC IS PLAYING OR YOU WILL LOSE YOUR CHANNEL SETTINGS -ALL YOU BLUE LINES WILL END UP STRAIGHT ACROSS AND YOU'LL HAVE TO RESET THE 4 PROGRAMS (AGAIN) you don't have to set all of them*--Now, you set them with your finger (sweeping it up and down on the touch-screen (REMEMBER TO PUSH THE (LOCK) BUTTON FIRST)you have to unlockit it...then you have the ability to adjust you frequencies(the blue lines)once you have a good sound, YOU PUSH A NUMBER...say, 1...then push MEMORY then push 1 again...AND CHANNEL 1 will be set ---do the same thing for the other channels --IF YOU PUSH THE L or R button you can set the E.Q. channels different from each other (if desired --it's just an extra function...and both settings will appear on the screen. But I just keep mine both the same(Left and Right). When you record music(like I do - being a Musician) it is important to be able to listen to the play-back-SO YOU HAVE TO PLUG THE CD RECORDER BACK IN TO (PLAYBACK ON THE REAR OF THE sh-8046-(PUSH (TAPE) TO LISTEN TO YOUR TAPE RECORDERorCD RECORDER)to hear what you recrding sounds like.PUSH -SOURCE- TO GO BACK TO REGULAR PLAY MODE---If you ever walk in and cut you system on and nothing happens, check to see if on SOURCE or TAPE-(rec eq) on the bottom right is supposed to make the music sound better,push it to cut it on/off when you make tapes/CD's the red light should cut on ...Reverse --flips your EQ settings upside down(not such a useful function)....I guess that's all I can tell you, this is the only EQ I need for my overall system and I haven't bought another one for the mixer. IT HAS NEVER MALFUNCTIONED IN 25 YEARS -- I'M USING IT RIGHT NOW FOR MAKING PROFESSIONAL SOUND QUALITY CD's. SO HAVE FUN! Darren Kelly- themasterofthrowdown@yahoo.com
Aug 24, 2009 | Technics Audio Players & Recorders
120 people viewed this question
 Grubhead
Grubhead
