Question about Pool & Spa
What does error code 56 mean - Pool & Spa
  • Anonymous Apr 04, 2015
    Lifestyle X2 hot tub.
    Master:
  • 346 Answers
Call a local Lifestyle hot tub distributor.
Posted on Apr 04, 2015
Why is my affinity dryer not heating and showing error code 56
Good Afternoon Friend,
I understand your Frigidaire dryer, model# ATF7000ES, is not heating and showing an error code 56. The E56 code means there is high motor current, meaning it is possible something is going on with the motor. The other possibility is this is a false error code. Please try resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and try any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 06, 2014 | Frigidaire Affinity ATF7000ES Front Load...
Code 56 on r6,please help?
There is no error code 56 but there is an error code 46, which is power supply not normal
Jan 17, 2012 | 2003 Yamaha YZF-R6
FISHER PAYKEL WASHING MACHINE FAULT CODE 56 DOES ANYONE KNOW WHAT IT MEANS
Error code 56 is mostly the motor controller, SD11 & SD12 brown boards, 3 x 332k resistors near the small transformer go low & need replacing with a 1 meg Ohm resistor will fix the problem.
May 22, 2011 | Fisher and Paykel Fisher Paykel Intuitive...
Have Fisher & Paykel top loader. Error code
fault code 56 is a real code : bowl invalid check clutch in centre of bowl and pressure tube is not kinked,can also mean pressure tranducer on motor control board could be faulty, note check for obstruction between inner and outer bowl( missing a sock perhaps.?)
May 07, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Toyostove laser 56 error code CL02
The CL means that it is in the automatic clean cycle. The 02 means that it has 2 minutes left. It will automatically do this at 2:00 AM. If you don't have the clock set it will do it whenever it thinks it's 2:00 AM.
Nov 05, 2009 | Rinnai Toyostove Direct Vent Heater: Laser...
I HAVE A KONICA 7145 COPIER ANND HAVE THE E-56-1 COPIAR
this code means the system control board and the main control board are not communicating with each other. the new main boards have modified to prevent this code. to reset the code turn the main switch on the left side of the machine off for about 10 seconds then back on
Oct 04, 2009 | Konica Minolta Office Equipment & Supplies
94 jeep grand cherokee v8 5.2
12 is usually a power disconnect, 14 is usually a map sensor 56 I'm not sure of...likely you mis-read it and it was a 55, indicating that the code sequence has ended (nothing code)...right after which, codes repeat.
Jun 28, 2009 | 1994 Jeep Grand Cherokee
Error Code 56 and Yellow Status Light
check the error blink code again as 56 is not a valid error code for the WD62525
Error Code Probable Cause
12 No error detected
22 Recovery from momentary Reset
32 Lamp Cover open
33 Air Filter Cover open
34 Lamp abnormality
35 Chassis Fan failure
36 Exhaust (Back Cover) or Lamp Ballast Fan failure
37 Engine (DMD or Lamp) Fan failure
38 Excess Lamp Temperature
39 Excess DMD Temperature
41 Short Detected
44 DVI Cable (between Chassis and Engine) disconnected
Jan 29, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Heater diagnostic codes (2000 jeep grand Cherokee)
49- dimming input is in error
53-door range travel was to small
56-door range travel was too large
I am not sure what they mean. I just happen to have the book of codes
Jan 14, 2009 | 2000 Jeep Grand Cherokee
Solution for KONICA 7020
E-56 is a main board problem.
Jul 07, 2008 | Office Equipment & Supplies
Pool & Spa Logo
85 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
