Question about Sewing Machines
How do i adjust my machine so i can use the zipper foot?
I need to move the the needle to one side but i dont know how to do it
  • 1,205 Answers
Hi Sarah
I will tell the way I used to do it in the old days, when the modern machines were electrical not electronic.
  • made sure that the right foot was fastened securely
  • took a piece of cloth
  • put under the needle, that was thread
  • moved a circle that was on the front of the machine to zig-zag
  • put the needle down and started very carefully
  • zig-zag she did
Your machine probably has a place where you choose the type of sewing you are doing. Look for a zig-zag sign.
all the best
kolbrun
Posted on Apr 05, 2015
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 25 Answers
If you could tell us what kind of machine you're using maybe we could help you more effectively. Thanks
Using invisible zipper foot - needle hitting foot
We need to know the brand and model of your machine? Some zipper feet slide left or right. If yours does this, then you need to adjust the zipper foot so the needle doesn't hit.
Sep 18, 2017 | Sewing Machines
What type of foot do I need when attaching popper closure tape to a duvet cover.It needs to leave more space under foot for popper height.
You do NOT want to sew over the popper. Instead, use a narrow zipper foot and adjust your machine needle to stitch just on the very edge of the tape. Hitting a popper will definitely break your needle and possibly knock the machine out of time.
Be sure to get the right foot to fit your machine!
Your machine's zipper foot may not look like this, but it should give you the basic idea.
How to Use Zipper Foot Sewing Parts Online Everything Sewing Delivered...
Zipper Foot Adjustable Low Shank 55411
Oct 23, 2016 | Sewing Machines
Pfaff Expresions 3.0. Using my zipper foot with 3 teeth. But can not get the needle to position to sew close to zipper
Um, not sure what presser foot you are using--there are several.
If it is the invisible zipper foot, there is a groove in the bottom of the presser foot that straddles one strip of zipper teeth which positions it close to the needle. Zipper foot #4 snaps to either side to enable the needle to be close to the zipper teeth. The Narrow Adjustable Zipper/Straight Stitch and the Non-Stick Zipper Feet are moveable left or right.
Pfaff Presser Feet
Oct 01, 2016 | PfaFF Sewing Machines
Why is needle hitting zipper foot on left side only?
When the needle is set on the center position, is it centered or is it slightly off center? If so, then the mechanism needs to be adjusted so that the needle is perfectly centered. When it is off-center, you will get the problem you are experiencing with hitting one side of the zipper foot. May want to take it in for service.
Mar 13, 2016 | Singer 4411 - Heavy Duty Model Sewing...
How can I attach a zipper foot to my unidentified machine?
Assuming you have the correct zipper foot attachment for your machine, you should be able to attach it like any other presser foot. On some machines, you may need to adjust the needle position to the right or left so the needle will not hit the presser foot when stitching.
Feb 10, 2016 | Sewing Machines
I am trying to insert a zip. The needle is not moving far enough to the left or right so that it doesn't hit the zipper foot. Please help
try using a 1/2 foot as this will allow the needle to get close to the edge or zip
commonly used for making a rope edge
available from any sewing machine shop
Aug 01, 2015 | Sewing Machines
How do I Fix a Zipper Foot to my Janome sewing Machine
It should attach the same way any other presser foot attaches. If it is the square type with small holes or notches on each side, you move the needle to line up with one of those holes. If the needle does not have a separate side to side adjustment, usually you can move it using the width adjustment on the machine, as if you were going to stitch zig zag. If it is the long narrow kind, it will also have notches or holes on each side that you line up the needle with. Make sure the needle will go up/down without hitting the foot at all.
Oct 09, 2014 | Sewing Machines
Elna needle is not lining up with the zipper foot notches
You ought to be able to move the needle in increments from left to right. Check your manual or the Elna website for help.
May 20, 2017 | Sewing Machines
I have a singer 4552 (portable) and I am having a prblem getting the zipper foot attached. Also I am having a problem getting the design stiching to work. I can get the red design stiches to work but not...
Hi. Here's how to attached the zipper foot.
To Attach the Zipper Foot
1. Loosen the large screw at the left of the presser bar and remove presser foot (You do not need to remove the screw).
2. Hook the prongs of the Zipper Foot around the presser bar from the back, and tighten the presser-bar screw.
3. If the raised edge (zipper or cording) is to the right of the needle, adjust the Zipper Foot by loosening the thumb screw at the back of the foot and sliding foot to the left of the needle. If the raised edge is to the left, slide foot to right.
4. With presser foot down, check its position by lowering needle into side notch, making sure it just clears the foot.
5. Tighten thumb screw to lock foot into position.
When raised edge is placed to right -- adjust foot to left of needle.
When raised edge is placed to left -- adjust foot to right of needle.
Sep 04, 2010 | Singer Sewing Machines
Sewing Machines Logo
59 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
