Question about Motorcraft 2004 Ford F-250 Super Duty Window Regulator 04 Ford F-250
Wont upshift could it be the pcm - Motorcraft 2004 Ford F-250 Super Duty Window Regulator 04 Ford F-250
2004 santa fe won't upshift
this is likely a fault in your powertrain control module (pcm) or either your speed, cam sensors or ecm. worst case is transmission failure.
service the transmission and see if that clears it up for starters.
If you need further help, reach me via phone at https://www.6ya.com/expert/ray_6d6dc1dfa6f18dc1
Jul 02, 2016 | Cars & Trucks
Transmission shifts fine cold but 5 mins later nothing
internal pressure loss when warm??? you mean it wont go? at all? or it wont shift? thats a stickler to diagnose when you cant see smell or touch it...tow it down to the trans man. could be anywhere in the hydraulic circuit, convertor? seal ring ? cracked drum? or if it wont upshift, could be sticking governor? modulator, mod supply line, worn clutches, since we dont know the year, we dont know if its electronic, sometimes sensor input can change with temp. and manual valve position must be accurately reported to the pcm. i can safely bet you dont have test equipment for that. so i must say see the trans man
Apr 17, 2014 | Chevrolet Silverado 1500 Cars & Trucks
Renault codes p0804
ODB Code: P0804
1-4 Upshift (Skip Shift) Lamp Control Circuit
Renault Description:
An ignition voltage is supplied to the Skip Shift Lamp. The Powertrain Control Module (PCM) controls the lamp by grounding the control circuit via an internal switch called a driver. The driver supplies the ground for the component being controlled. Each driver has a fault line which the PCM monitors. When the PCM commands a component ON, the voltage of the control circuit should be low (near 0 volts).
Nov 18, 2013 | Cars & Trucks
Wont upshift
If your bike has shift indexers they could be out of adjustment.
Oct 14, 2013 | 2003 kawasaki KX 125
2003 dodge neon only runs in first gear slips at 1500 rpm , must shut car off an turn on for it to run , wont shift out of first.runs fine in reverse.is it a pcm problem.
No,Your car is in "limp"mode,
there are three sensors on the transmission that tell the computer how fast your going so it knows to upshift,
have someone check input sensor,output sensor,and speed sensor.
Jan 14, 2010 | 2003 Dodge Neon
Car wont upshift out of 2nd gear, sometimes when
it sounds like you have a faulty ignition switch
Sep 11, 2009 | 1999 Chrysler 300M
My 88 chevy with 700r4 wont upshift from 3rd to 4th
you have a valve body problem, some of the speed sonsor controls are malfunctioning... need to get into the valve body... check fluid condition for dirty and burned condition...
Aug 09, 2009 | 1992 Chevrolet C1500
1999 Dodge Ram 2500 4WD, Transmassion will not up shift.
Sounds like a problem i had on my 96. but, check the muffler.If the KAT converter is pluged , it wont shift into 3rd, at 45mph. Witch the OBD and 3 techs couldnt find.This unit only cost me $100.00.Better than 2 grand. Let me know.
Oct 29, 2008 | 1999 Dodge Ram 2500 4WD
HYUNDIA 1997 ELENTRA 1.8
http://www.2carpros.com/how_to/transmission_service_4.htm
Popular Problems Checks
1. Car will not go into gear:
  • Gear selector cable has failed
  • Brake lock solenoid has failed not allowing the gear selector to move out of "Park"
  • Excessively low transmission fluid (note: if car is operated for an extended amount of time with low fluid level the transmission will fail prematurely)
  • Shorted electrical component not allowing the PCM to control the transmission. Example: shorted fuse
  • Flex plate (flywheel) is broken completely not transferring engine power to the transmission.
2. Car goes into gear but then fades out of gear or is slipping while driving:
  • Transmission fluid is low
  • Transmission clutch discs or bands are worn out or burned
  • Faulty transmission shift solenoid.
3. Car goes into gear but does not shift out of first:
  • Blown fuse to the PCM controller
  • Faulty vehicle speed sensor (VSS)
  • Shorted second gear control solenoid
  • Faulty transmission controller (PCM)
Tips About Common Problems and Fixes
Jun 21, 2008 | 1997 Hyundai Elantra
Motorcraft 2004 Ford F-250 Super Duty Window Regulator 04 Ford F-250 Logo
514 people viewed this question
Top Motorcraft Scuba Diving & Snorkeling Experts
jeff5may32
bobalix
Gil Shultz
Are you a Motorcraft Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
