Does anyone have a parts manual for an Executive Machines EPS-611X?
The large gear that fits inside the bigger plastic gear has shredded. I turned it around, so it meshed with the better side, but it's still skipping. I need to order this gear.
fellowesrep
  • 102 Answers
SOURCE: Shredder
your best bet will be to call Fellowes at 1-800-945-4545 we will be more than happy to assist you.
Posted on Apr 01, 2008
SOURCE: Questions on Fellowes Shredder Spare Parts
these guys might be able to help http://wheelermachines.com/fellowes_parts.htm
Posted on Aug 07, 2008
SOURCE: Broken plastic gear tooth - Fellowes P55-C Shredder
hi,
i had the same problem on the fellowes fs5m model. i opened up the machine and found that the plastic gear was completely worn on one side.
i just found this website online for spare parts: http://www.wheelermachines.com/fellowes_parts.htm
haven't called them yet. if they don't have it i might try the belzona compound.
good luck,
marie
Posted on Nov 02, 2008
t_vinson57
  • 58 Answers
SOURCE: Achiever, Model CCS 5000, shredder, need a part (a large nylon gear)
This is how a got my hard to fine gear!
Contact Michael Business Machines for your local dealer 1-800-223-2508
Good luck, Tom
Posted on Mar 27, 2009
SOURCE: Need large nylon gear for fellowes shredder od1500c
Call 1-800-955-0959 they will need serial # of it....hope this will help
Posted on Apr 30, 2010
My Executive Machines EPS 1200X shredder works in reverse, but does not shred.
there should be a forward/ reverse switch that is used to unjam paper being shredded. check that
if it is automatic then check for paper stuck in the shredder causing the reverse action.
May 12, 2015 | Shredder Office Equipment & Supplies
Singer Stylist 477 Top Gear replacement problem - please help me?
The gears should always be replaced in pairs. Do not oil the plastic on the gears. only the metal. Use white lithium on the plastic.
Dec 02, 2014 | Singer Sewing Machines
Cable replacement on six-sheet crosscut shredder Executive Machine EPS-611X?
Fairly simple fix then; figure out what length of cable you need (or would like to have if you need something a little longer (like 1 or 2 feet more)) and run down you your local hardware outlet; a place like Lowes, Home Depot or Ace Hardware and pick up a 2 or 3 wire replacement. Make sure it is th same guage wire inside. This will involve opening the unit to install the new one. Take the head unit off, open it and see where the wires from the cable attach to. Make a drawing or take a picture of it before you take things apart and along the way so that reassembly with be easier. Disconnect the old broken cable, and connect the new one. If it is solder to a circuit board, or soldered to the switch, cut the wire back (the old one) so that you can splice the new cable to it. If it uses little connectors, you can disconnect it, and take them along when you go to get the new cable and see if they have similar connectors you can use on your new cable. Reassemble it, and test it. Should be a pretty simple fix. Let me know how it comes out. If you need any additional help, just post it here. -Coss-
Dec 10, 2013 | Executive Machines SESS640HD 6-sheet strip...
My Royal VF880 shredder is not working. It is not shredding anymore and makes a very loud racket when you try to use it.
Likely-hood is that you have taken the teeth out of a plastic drive gear inside...suggest you open it up to see what is broken then you can contact Royal at 1-800-524-0799 for parts assistance.
Mar 23, 2011 | Office Equipment & Supplies
My Fellowes ps-40 will not shred. The motor is
you have some shredded gears. i don't think fellows has replacement parts for their personal shredder line.
Nov 15, 2009 | Fellowes 3011001 Shredder
Intimus simplex SE
Call the mfg, Schleichner, 919-775-7318. They'll give you the name and number of your local distributor for parts. The part number for the big white gear with the large holding pin is: M-76954.
May 27, 2008 | Intimus Simplex se Shredder
70 people viewed this question
jasbo
jasbo
